#15 | |
Drives: Neptune GR86
| The Following User Says Thank You to Andrew025 For This Useful Post: | DAEMANO (04-03-2015) |
#16 |
Driving Coach
Give me 7-9 psi at redline built up progressively through the power band, batteries that last 30 minutes at Road Atlanta where I'm WOT for 75% of every lap, and a waiting list that's not almost a year long.
| The Following 5 Users Say Thank You to ATL BRZ For This Useful Post: | Boofneenee (04-03-2015), Chimera (04-20-2015), DAEMANO (04-03-2015), Dipstik-sportech (04-04-2015), raven1231 (04-03-2015) |
#17 |
This would all be nice. That being said ,as a previous phantom owner, for the price the kit is unbeatable. Really changes the car.
| The Following User Says Thank You to raven1231 For This Useful Post: | DAEMANO (04-03-2015) |
#18 | |
| The Following 2 Users Say Thank You to raven1231 For This Useful Post: | DAEMANO (04-03-2015), DarkSunrise (04-03-2015) |
#19 | |
Time Traveller
As a few ppl have mentioned @Shiv@Openflash has taken this a bit further, and will very soon be releasing (weeks?) an electronic controller that replaces the partial throttle switch entirely. This controller makes the ESC kit full time F.I. This is under his Proceed brand. Details for NC Miata are here: http://forum.miata.net/vb/showpost.p...&postcount=303 . For FT86 I believe @fenton is either testing, perhaps he can chime in. In the meanwhile, here is a big box o' Proceed controller stuffs.
| The Following 3 Users Say Thank You to DAEMANO For This Useful Post: |
#20 | |
Time Traveller
92 people for FT86 http://www.ft86club.com/forums/showp...postcount=8449 ...and I don't know how long for Miatas. http://forum.miata.net/vb/showthread...567709&page=13 The wait will be determined by production rate. Currently Rob is committed to a slow production rate, but that could change. Rob has a plan that's for sure. 2. Yes, I can take you on a test ride, don't mind at all. We just have to get together. PM me and we can figure it out. |
#21 | |
Drives: 2007 MX-5 Miata, 2015 VW Golf GTI
Yeah yeah. Anybody who criticizes what you do is a troll right?
Like I said, the Phantom Electric Supercharger is not ready for primetime. Last edited by xuimod; 04-03-2015 at 12:21 PM. |
#22 | |
Time Traveller
What will be available (as soon as the Proceed controllers are out) is 5.0lbs of non-parasitic boost (about 230 WHP/ 205 WTQ on e85) that peaks at 3400 RPM and drops to 1.7-2 PSI at redline progressively through the powerband that could last your full session (with the Aux charger upgrade) but would have to be tested at your track with your driving style to know for sure. This is something that could be done if I could either, get my car to ATL or get you to CA, haha. |
#23 | |
Drives: 2013 Asphalt 6spd
Regardless of the amount of pressure it creates, It is one of if not the best dollar per whp ratio modifications available on this platform. Following your argument, a large percentage of all the intake and exhaust mods don't make sense either as they only gain ~5-20 whp and can and do cost thousands of dollars. (of course to be considered is Where the power is being made)
| The Following User Says Thank You to Target70 For This Useful Post: | DAEMANO (04-03-2015) |
#24 | |
Driving Coach
I'm already at 205whp on E85. I'm not sure +25whp is worth 2 grand and a year of waiting plus lots of DIY solutions to existing issues with the system. The extra low end torque is nice but again the way the boost tapers off on this thing and the time my car spends in the upper RPMs on track just doesn't make sense. A Rotrex SC kit for ~50% more cost is the best solution as the boost ramps up progressively and holds 9psi at redline and makes over 300whp with E85. |
| The Following 2 Users Say Thank You to ATL BRZ For This Useful Post: | boredom.is.me (04-21-2015), Dipstik-sportech (04-04-2015) |
#25 | |
Time Traveller
I don't think there was ever an Aux charger that overheated on the track. What you may be remembering is the Primary controller on nlowell's car many months ago that reached it's thermal limit during his lapping sessions. The thermal limit on the primary charger shuts off boost at a specific limit. So two improvements were made here, the addition of the Aux charger to split the charging load across two devices as well as the new primary controller has had it's thermal limits increased (i'll let @fenton or @Robftss speak to that). The only DIY solution I've ever seen for any issue was nlowell building a duct to pipe fresh air to his Primary controller. This was his experiment alone. Importantly, when you mention "lots of DIY solutions to existing issues with the system" what other issues are you referring to? On power output, I think it's great that people have their own choices of power options. Let's look at costs. E85 running on a flex fuel sensor and ECUtek tune - 205 WHP at what total cost of the sensor + tune + license + cable + installation? $1000 - $1500? E85 running on OFT + Phantom ESC, easy self install, with OTS tune - apx 230 WHP at $2200.00. Don't get me wrong. I would love full flex fuel support (E0 to E85), and I could get that if I switched tuning options. OpenFlash gives me e50 to e85 which has been livable at no extra cost. One day this may be available on the OFT or with the Proceed controller. We'll see. On ESC vs Rotrex FI What Rotrex solution is available for 50% more? That would be roughly $3350. The JR Kit is generally about $5000 with a tune and $4000 without one. Add tune and install (let's say 5-7 hours @ $100/hr. for a decent shop) and you're knocking on the door of $6000. http://counterspacegarage.com/jackso...s-brz-frs.html The Kraftwerks kit is $4795 with a tune as well, not including installation. Add installation and you're in the area of $5500 http://store.kraftwerksusa.com/super...ng-ecutek.html Getting back to the OP's question about why more companies aren't pursuing ESC's qualified by it being perfect for the street, my answer would be: 1. R&D takes a lot of time and money. Rob's aftermarket kit has been in development for over 5 years (if my internet sleuthing is correct). Also other people have attempted to make general purpose kits, but have not taken the time to do FULL integrations with specific platforms (make/models). This is what makes Rob & Shiv's kit more ready for mainstream adoption than previous attempts. They're plug and play, inexpensive, and they work exceedingly well for what they're intended for. 2. Marketing is both critical and expensive. Most people, even gearheads, won't take the time to self educate. Instead they'll form opinions based off of what other people they trust might say. To people without this kind of info the decision gets distilled even further stock car = street car, and modified = track car. Rob's original Phantom ESC kit was intended for use on the street where 99% of car buyers spend their time. HOWEVER, the kit's evolution is expanding it's capabilities. The kit is miles more capable today than even where I first purchased, and it's roughly half the cost of traditional FI. Understand this gray area requires time, attention and patience. Most casual buyers won't invest it. Last edited by DAEMANO; 04-03-2015 at 03:24 PM. |
| The Following 5 Users Say Thank You to DAEMANO For This Useful Post: | 0351USMC (04-03-2015), 07jazzrs5gt86 (04-03-2015), ATL BRZ (04-03-2015), Phantobe (04-03-2015), Wolfdogelite (04-03-2015) |
#26 | |||
Driving Coach
Unfortunately OFT cannot do FlexFuel and the reference the custom maps required. Quote:
| The Following User Says Thank You to ATL BRZ For This Useful Post: | DAEMANO (04-03-2015) |
#27 |
Drives: '02 GS300, '12 S80 T5, '15 BRZ 6MT
+1. Hell, I wouldn't even mind the waiting list if this were possible.
#28 | |
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
50 % increase would 2000 plus 2000/2=3000
| Open Source Electric Supercharger | neutron256 | Forced Induction | 913 | 08-22-2021 06:16 PM |
| Phantom FTS Electric Supercharger Owners Thread | TM | Forced Induction | 1206 | 12-15-2019 03:33 PM |
| FS: Phantom ESC (Electric Supercharger) *SOLD* | SloS14 | Engine, Exhaust, Bolt-Ons | 13 | 01-13-2015 10:18 PM |
| Phantom Electric Supercharger | cuddefred | AUSTRALIA | 2 | 07-11-2014 02:13 AM |
| Anyone with Phantom Electric Supercharger? | frslee | Mid-Atlantic | 0 | 06-19-2014 01:29 AM |
