#113 |
Residential computer repair. That just taught me to question everything. I learned the do-it-wrong then do-it-right method as a homeowner. I've been working on my own cars since I was 16. That taught me that manufacturers make compromises.
#114 | ||
There's only about 2.5" of bump travel, so I don't know how much extra movement you think you're getting. Plus, the shocks are dampening the movement of the body vs the wheels, not just the wheels against the road. The sprung weight is WAY bigger than the unsprung weight, so a lb or so per wheel isn't going to make a big difference in damping. What you will get from 16's is taller sidewalls (assuming same overall diameter) which will soften the ride from the tires being squishier. Quote:
Like I said before, sway bars only have an affect on anything if only one wheel is moving. Over a bump that both wheels hit (ripple in the pavement, etc), the sway bars just pivot freely. So even if you were correct, the only time you've eliminated shaking is when only one of the rear wheels hits a bump (highly unlikely). The compromise from the factory is being almost too soft for great handling. They definitely didn't compromise it towards stiffer.
| The Following 2 Users Say Thank You to wparsons For This Useful Post: | Captain Snooze (04-10-2015), Ultramaroon (04-10-2015) |
#115 |
Because compromise ®
Drives: Red Herring
Of course they do. As I have said 4.2x10^5 times everything's a compromise. They are unavoidable. Pick a spring rate, any spring rate. Go on, think of a spring rate. Have you chosen one? Ok, that spring rate you have chosen is a compromise.
| The Following 3 Users Say Thank You to Captain Snooze For This Useful Post: |
#116 | |
Drives: 1993 Impreza w/ WRX Swap + FWD!
#117 |
Drives: 2015 CBS WRX 2014 D4S Mono(R.I.P.)
Quit wasting money and time. I think your "tuning" time and money would be better spent on a simulation. Sure it isnt as complex as real life... but why should it be. buy a machine that can play Gt6 (probably a ps3) and tune it to your hearts content. I feel its pretty spot on for what it is.
| The Following User Says Thank You to TougeSlug For This Useful Post: | wparsons (04-16-2015) |
#118 |
Drives: FRS
i totally understand this method is sometimes necessary for some people but dood... if that's your default method... holy shit. that's the most intentionally inefficient method ever! LOL!
| The Following 3 Users Say Thank You to 8R6 For This Useful Post: |
#119 |
Drives: 86
i balanced my 86 by removing front and rear sway bars
but i run it with high spring rate 12.5kg rate front 10.2kg rate rear with 36 stiffing ways. daily drive and drift weekend |
| The Following User Says Thank You to aagun For This Useful Post: | KoolBRZ (04-16-2015) |
#120 |
Why do people keep running stiffer springs up front? Do they even look at the geometry before making decisions?
The effective wheel rates put that as incredibly front biased, it must understeer like crazy at turn in. 12.5 * 0.95^2 = 11.3kg/mm at the front wheel 10.2 * 0.75^2 = 5.7kg/mm at the rear wheel if you flipped the springs front to rear it's still front biased, but not nearly as bad: 10.2 * 0..95^2 = 9.2kg/mm at the front wheel 12.5 * 0.75^2 = 7.0kg/mm at the rear wheel
| The Following 4 Users Say Thank You to wparsons For This Useful Post: |
#121 | |
Frosty Carrot
Drives: The Atomic Carrot
This is how I imagine their R&D teams:
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX Wall of Shame - aFe Takeda, Wilwood, FA20Club |
| The Following User Says Thank You to Shankenstein For This Useful Post: | wparsons (04-16-2015) |
#122 |
I think it's pretty clear some companies just throw rates they use on other platforms at it and don't even test, or do math.
| The Following User Says Thank You to wparsons For This Useful Post: | Tcoat (04-16-2015) |
#123 |
For the same width and overall diameter, a 16" tire will be heavier than a 17". More rubber, and more sidewall reinforcement.
#124 |
| The Following 6 Users Say Thank You to Racecomp Engineering For This Useful Post: | 8R6 (04-16-2015), CSG Mike (04-16-2015), gramicci101 (04-16-2015), Hyper4mance2k (04-16-2015), Ultramaroon (04-16-2015), wparsons (04-16-2015) |
#125 |
Drives: Lightning Red 2015 BRZ;F150 Limited
I'm loving this thread for the sheer entertainment value. And while I would never bother with all the effort the OP is putting into his car, I must applaud his ability to stay on track and not get all defensive with all the flaming that is going on here. Well done. Do what makes you happy, just don't hurt anyone else and all will be well.
| The Following 2 Users Say Thank You to DGM33 For This Useful Post: | Tcoat (04-16-2015), Ultramaroon (04-16-2015) |
#126 | |
| Say no to SWAY with our Anti-Sway Bar and Sway Bar Bushing Special. | FRSport.com | Brakes, Suspension, Chassis | 0 | 01-23-2015 01:38 PM |
| FS:NY RCE Anti-roll/Sway Bar kit $250 | snky_snky | Brakes, Suspension, Chassis | 2 | 08-19-2013 10:42 PM |
| FS: NY RCE Sway/Anti-roll bar kit $250 | snky_snky | Engine, Exhaust, Bolt-Ons | 2 | 08-18-2013 01:09 PM |
| ST Suspensions Lowering Springs & Anti-Sway Bars Now Available @ BMS! | Boston Motorsports | Brakes, Suspension, Chassis | 84 | 07-24-2013 12:42 AM |
| How to pick anti-sway bars | FastLane1000 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 19 | 07-12-2013 06:06 PM |
