Old 03-30-2015, 11:45 PM   #15
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Are you fat? (lol joke. I am) It does it to me if it clicks all the way when buckling up...
Make sure its not stuck on door too. Get a boob/chest cushion, it'll give you little bit of play.
Packofcrows is offline   Reply With Quote
Old 03-30-2015, 11:46 PM   #16
cycleboy
Drives: 2013 Scion FR-S - Argento
Originally Posted by mav1178 View Post
While I would normally agree, most interstates in CA aren't designed this way.
One exception may be the 110 north of the I-5, which isn't technically an interstate:
Even the 110 (onramps are essentially a stop sign + a drag race up to 55MPH) isn't THAT bad for purposes of blind spot discussions.
Very curious to what section of road OP was on...
-alex
For those unaccustomed to it, we SoCal people put "the" in front of our highway/freeway numbers. . .
cycleboy is offline   Reply With Quote
The Following User Says Thank You to cycleboy For This Useful Post:
mav1178 (03-31-2015)
Old 03-31-2015, 12:29 AM   #17
MikeM7
Drives: 2013 BRZ Limited White
Originally Posted by extrashaky View Post
The diagram is to show what you can see and what you can't, not to assume that there's always a car conveniently located in the next lane to keep you from moving over. If you take the diagram in the context of this thread, it might make more sense.
There are three situations in which this comes into play for me:
When I'm in the right lane on a three-lane freeway and want to take the center lane. Sometimes there will be someone pacing me in the far left lane in the blind spot. If that person tries to take the center lane at the same time I do, a collision could result.
When I'm on an entrance ramp, attempting to merge into traffic. Because the ramp doesn't begin right next to the travel lane, someone in the travel lane could be in the blind spot and suddenly appear in my properly-adjusted mirrors when I'm right alongside him. At that point my options are more limited than if I had seen him before reaching that point in the acceleration lane.
When I'm in the far left travel lane and someone is approaching in an entrance ramp from the left. We have those here, and people tend to just blow right out into traffic without looking. It's bad enough to have them suddenly appear out of the blind spot into my properly-adjusted mirrors, but it's worse when they just blast into my lane with no regard for life or property.
All of these situations require looking over the shoulder rather than relying on properly-adjusted mirrors that still leave a huge fucking cone of blindness out the driver's side of the vehicle. Does that explanation work for you?
I guess, I'm just kind of surprised anyone needs a diagram to let them know they shouldn't rely on their side mirror to view traffic that's diagonally backwards and two lanes to the side. Seems like kind of a given.
You can see the lane right next to you just fine, and that's all the side mirror is for.
I also think it's a little funny that the blind and visible cones overlap each other to create a paradoxical blind/visible triangle
Edit: After re-reading and paying close attention to context, the post you responded to said "This car's side mirrors, if adjusted properly, should not require you to turn to see blind spots to the point where the seatbelt lockup comes into play."
Looking at your diagram, I'd agree, you shouldn't need to turn your shoulders to view that blind spot, just your head.
I did pick up on the whole merging onto highway at a distance from travel lane part, which would potentially put the cars he's merging with in that blind spot, so I get your point there.
MikeM7 is offline   Reply With Quote
Old 03-31-2015, 02:30 AM   #18
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
But there is STILL a blind spot in this car, even with properly-adjusted mirrors, that in many circumstances requires looking over the left shoulder to ensure that the way is clear. The better habit is to always look, so that you don't bang into someone the one time you're wrong about whether the mirrors alone were sufficient.
I always look, but the whole thing about moving your entire body is completely unnecessary.
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
stugray (04-01-2015)
Old 03-31-2015, 03:18 AM   #19
8R6
8R6's Avatar
Drives: FRS
with properly adjusted side mirrors, a quick GLANCE is all that's needed to double check that nobody is in the "blind spot" or someone approaching really quickly. if you have to shift your whole body like batman or an owl just to look to the side of you, you're doing it wrong.
8R6 is offline   Reply With Quote
The Following 4 Users Say Thank You to 8R6 For This Useful Post:
JB86'd (03-31-2015), ravisraval (11-26-2016), RobertPaulson (04-01-2015), stugray (04-01-2015)
Old 03-31-2015, 03:56 AM   #20
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Sounds like your improper use of mirrors almost got someone else killed.
chulooz is offline   Reply With Quote
The Following User Says Thank You to chulooz For This Useful Post:
Old 03-31-2015, 01:32 PM   #21
kch
Senior Misanthrope
kch's Avatar
http://www.ft86speedfactory.com/rexp...rrors-852.html
these help a lot.
The Following User Says Thank You to kch For This Useful Post:
ck-GT86 (04-01-2015)
Old 03-31-2015, 05:30 PM   #22
spatcha88
Drives: 2013 Scion FRS Whiteout
Bro I've been driving for 8 years and have never had a single accident or minor colision. I use my mirrors but due to my heights and I can't 100 % rely on them. Hence why I always look over my shoulder and check my mirrors.
spatcha88 is offline   Reply With Quote
Old 04-01-2015, 01:30 PM   #23
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
Originally Posted by kch View Post
+1 to the convex mirrors.
.ck
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
Old 04-01-2015, 01:46 PM   #24
stugray
Drives: 2013 GBS BRZ Limited
I have >30 years driving experience (not that that matters in this discussion) and I also look over my shoulder when required.
Which is not that often because I have one convex mirror on the driver's side.
Even when I DO look, I never have to turn my entire torso.
Maybe you need to work on neck flexibility.
Or are you this guy:
The Following 2 Users Say Thank You to stugray For This Useful Post:
MikeM7 (04-01-2015), Tcoat (04-01-2015)
Old 04-01-2015, 05:22 PM   #25
spatcha88
Where did you find this pic of me...
The Following User Says Thank You to spatcha88 For This Useful Post:
Old 04-01-2015, 08:08 PM   #26
RobertPaulson
Hisnamewasrobertpaulson
RobertPaulson's Avatar
Drives: 2017 Golf R
Well, my take on driving these days, is sort of like playing a game ...... with one player looking at his/her smart phone, texting; another player talking on a cell phone; another player is drunk/on drugs; another one is old and gets the gas & brake mixed up; yet another is young and bullet proof and the last one is asleep ..... and there you are ..... in the middle of them all ...... your move .....
humfrz
sorry for being the young bullet proof one that drunk/ondrugs while sexting confused about what that third pedal is all while punching babies.
This is your life and it's ending one minute at a time.
RobertPaulson is offline   Reply With Quote
Old 04-01-2015, 08:25 PM   #27
2much
I wanna go fast
Drives: 2013 FR-S 6MT
I am not sure why some people are trying to convince people that looking over your shoulder properly is bad practice
2much is offline   Reply With Quote
Old 04-01-2015, 08:27 PM   #28
MikeM7
Not bad practice, just not necessary when you can view the entire blind spot by turning your neck.
CG Lock Seat Belt Lock Biggins Interior Parts (Incl. Lighting) 0 02-03-2014 09:41 AM
Passenger seat belt warning when I put phone on seat!??? Kayzer Soze BRZ First-Gen (2012+) -- General Topics 20 09-13-2013 12:29 PM
Request: Magnetic seat belt lock funbeatsfast DIY (Do-It-Yourself) Guides 3 03-15-2013 12:11 AM
CG Lock - Seat Belt Retainer to Hold You Firmly in Seat Jimbo Miscellaneous 0 07-23-2012 02:27 AM
