#43 |
Drives: '02 GS300, '12 S80 T5, '15 BRZ 6MT
I do not even have a 86 yet. Haha. I am just researching about possible options as I plan tp buy my car around fall of this year. If I do go FI after I buy a 86, OTS tune like Cosworth 2.3 or e-tuners like Delicious are pretty much my only option since there are no good fa20 tuners around in Korea.
#44 |
Drives: GT86 Cosworth
Im no expert on exhaust systems, but arnt the silencers one of the biggest restrictions?
I would have thought restrictive silencers on a 3inch bore system is worse than less restrictive silencers on a 2.5inch system? The Cosworth Exhaust is VERY loud = less restrictive |
#45 |
Drives: toyota mr2/ Toyota GT86
As long as the silencers are straight through type then there's no difference in restriction levels
the noise reduction then comes down to the volume of the box a big box = quieter exhaust |
| The Following User Says Thank You to 350matt For This Useful Post: | ajc209 (04-02-2015) |
#46 |
Thats good to know. Cheers.
Given the price and noise of the Cosworth Exhaust, I will probably get Hayward and Scott to add a big silencer(s) to their manifold back and get a stepped cermaic coated mainifold from P&L or JDL. Cosworth Exhaust costs £3500!!! I dont plan to go stage 3 (though I am eagerly awaiting their stage 3 unvail - soon I hope) so 2.5inch is probably fine. If it 260hp with stock exhaust, I imagine a full 2.5inch system should make up most of the 20hp for alto less than £3500... |
#47 |
I wouldn't expect the full 20Bhp for a 2.5" exhaust, for that much power you need a big pipe , hence Cosworths use of 3" pipe
you'll probably get an extra 10-12Bhp over the stock exhaust though |
#48 |
Drives: GT86
#49 |
Drives: 2013 BRZ black
@RallySport Direct Im interested in the MAP sensor Cosworth selected for this charger. Its hard to tell from the photos, I think this is the part number: 0 281 002 437? Is this MAP the same size and fitment as the OEM 5psi unit? It also looks like a 4pin connector (I'm assuming for integrated IAT) vs. the stock 3pin. Was there a jumper pigtail harness that came with the kit to connect the new MAP to the old harness?
Thanks! Awesome build by the way. |
#50 |
its a new Bosch 3bar sensor with integral temp sensor
and yes the kit includes a jumper harness to point the new temp input back into the ECU , replacing the temp input from the original MAF sensor |
| The Following User Says Thank You to 350matt For This Useful Post: | xkalelx (08-20-2015) |
| Cosworth FA20 Stage 1 Power Package | DaDr00 | Engine, Exhaust, Transmission | 84 | 06-10-2016 04:02 AM |
| Cosworth Stage 1.1-1.3 Power Package BRZ 2013-2014 / FR-S 2013-2014 With Videos! | RallySport Direct | Engine, Exhaust, Bolt-Ons | 104 | 07-02-2015 11:10 AM |
| Stage 2 Cosworth Kit Preview!!!! | Titanmotorsports | Forced Induction | 377 | 04-01-2015 08:29 AM |
| Stage 1.1 Cosworth FRS | FR-S89 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 17 | 12-22-2014 02:23 PM |
| Cosworth Stage 2 | v86 | Software Tuning | 2 | 11-05-2014 08:47 PM |
