86WORX
Old 04-07-2015, 10:25 AM   #57
fika84
fika84's Avatar
Originally Posted by Bobblehead View Post
I'm willing to bet that your oil leak is because your engine's rear main seal is borked. It'll probably need replaced. I don't know what all that entails, but it definitely won't be fun or cheap.
He's already done the hardest part! You don't have to split the cases to replace the main seal.
fika84 is offline   Reply With Quote
The Following User Says Thank You to fika84 For This Useful Post:
Bobblehead (04-07-2015)
Old 04-07-2015, 01:41 PM   #58
Ultramaroon
fabulous
Ultramaroon's Avatar
I get what you're saying but how many miles does the engine have? If the seal is still nice and supple.... Meh, either way...
fika84 (04-07-2015)
Old 04-07-2015, 02:25 PM   #59
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
Just because he's done all the hard stuff doesn't mean it'll be easy and fun
Bobblehead is offline   Reply With Quote
Old 04-07-2015, 02:28 PM   #60
stugray
Drives: 2013 GBS BRZ Limited
It may not be fun, but it is cheap and easy:
$20 - https://www.parksubaruoemparts.com/p...%20MAIN%20SEAL
To remove that kind of seal I drive a nail through it right where you can see the "XXXX" and make a hole. There is metal in there so it takes more force than you would think.
Then I run a drywall screw in the hole, then use that to pull out the old seal.
You can do one on each side.
Use engine oil only to lube the new seal and press it in evenly flush with the case like the old one.
There are tools that help you install it straight but it is essentially a giant washer and a couple bolts to use to push in the seal.
While you are in there see if that center piece is a bushing or bearing that you might want to replace at the same time (that bronze colored section in the middle).
My other car has a pilot needle bearing and a felt washer in there.
The Following 2 Users Say Thank You to stugray For This Useful Post:
SciOnDrifTtSlIdeR (04-19-2015), Valentino (04-08-2015)
Old 04-07-2015, 06:05 PM   #61
Valentino
Drives: GT86 2014
Car has about 6k miles on the clock...
Valentino is offline   Reply With Quote
Old 04-07-2015, 06:16 PM   #62
Ultramaroon
fabulous
That's a keeper of a trick, Stu. I'm going to remember it for sure.
Old 04-07-2015, 06:20 PM   #63
Ultramaroon
fabulous
Jeez, transmission isn't even broken in yet. Well, we all learned Stu's cool trick today. That's a big plus. Those seal removal tools suck.
If you're going for it, do NOT drill. Use a good clean nail.
Old 04-19-2015, 12:18 AM   #64
Valentino
Drives: GT86 2014
Finally i installed everything back, and the car is moving again.
Thanks to all for your help.
Old 04-19-2015, 01:21 AM   #65
stugray
Did the nail trick work?
Old 04-19-2015, 01:25 AM   #66
Ultramaroon
fabulous
Wait, you didn't know if it would work?
Guff (04-19-2015)
Old 04-19-2015, 05:01 AM   #67
SciOnDrifTtSlIdeR
Drifter
Send a message via MSN to SciOnDrifTtSlIdeR
wow killed a clutch in 6000 miles that's nuts never ever let your friend even look at your car again, i have one friend i let drive my car, he treats it with more respect then his own vehicles, end of the day your car is now repaired and im hoping not all of the costs came out of your pocket... also thank you to whom ever posted the nail trick i will keep that in memory if im ever in there changing seals lol
SciOnDrifTtSlIdeR is offline   Reply With Quote
Old 04-19-2015, 10:32 AM   #68
Valentino
Drives: GT86 2014
I did try the trick. But I didn't read your instruction correctly.I missed the part where you said that i have to make a hole before i use the screw, and I slightly scratched the outside face of the crank trying to force the screw in with an impact. So i just removed the seal with a flat head screwdriver. But I will try your method next time.
If you don't have the proper tool to install the new oil seal. and you want to install it with your hand and a hammer.
Wipe the inner crankshaft wall and the inner crankcase wall with a clean cloth till its dry. also wipe the outside of the oil seal, and only apply engine oil or grease to the inner ring of the oil seal.
Or this will happen to you all day long.
I bought 2 new oil seals. so this was the first one. and i kept practicing on it till i got it in perfectly. Then i installed the second new oil seal.
Old 04-19-2015, 10:53 AM   #69
stugray
It works for me every time. I wanted to know if he used my method.
Old 04-19-2015, 03:02 PM   #70
Ultramaroon
fabulous
Gotcha
weird noise from my clutch stevemp5 Issues | Warranty | Recalls / TSB 3 08-12-2014 05:58 PM
weird noise from clutch pedal area... mongiamc10 Issues | Warranty | Recalls / TSB 5 08-08-2014 07:04 PM
Wilwood Failure SubieNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 46 04-09-2013 09:32 PM
Ringland Failure? iLuveKetchup BRZ First-Gen (2012+) -- General Topics 9 01-30-2012 01:25 PM
