| DIY (Do-It-Yourself) Guides For all DIYs. |
#155 |
Drives: Hyper Blue BRZ
When I remove the spring my first thought was to cut it down to about 1/3 of it's original length so it would be long enough to provide some tension while the pedal is at the top position, but short enough so it didn't assist with pedal effort. Then I thought I had a short spring in the draw. The spring is only about 1/4" in diameter and about 3/8-1/2" long. It is just long enough to provide a little bit of pressure so the pedal doesn't sag. The first 1/2'' of pedal travel is softer with the main spring removed. Did anybody else consider cutting down the spring or inserting a smaller spring? See pic.
#156 |
poor man's evora
Drives: Turbod BRZ
After owning my car for 3 years, I decided to finally do this mod. I should have done it a long time ago, I like the pedal feel alot better and i'm sure driving will be smoother shifting between 1st gear to 2nd gear. Anybody on the fence should quit waiting and do this mod. It is not that hard to do.
| The Following 2 Users Say Thank You to malubawla For This Useful Post: | funwheeldrive (07-22-2016), jcw99 (01-09-2017) |
#157 |
Drives: BRZ, STI, GT350R, Supra, 987.2
New thread is live here: http://www.ft86club.com/forums/showthread.php?t=103157
Moving forward, post comments in that thread if possible. This is the best I can do currently. Glad most/all of you are liking the modification! |
#158 |
Guest
Posts: n/a
if anyone in the GTA (Vaughan) area wants to do this for me I'll toss you a beer or a shot of Jack if you'd lik3
haha I don't have the tools and I don't wanna fuck anything up but I really want this done. |
#159 |
Wow, what would a GTA (Vaughan) resident do for a bottle of Jack?
#160 |
Guest
Posts: n/a
#161 |
Drives: 2016 BRZ
If you want to put the spring back in the best way I found was to compress the spring in a vise and use some safety wire wrapped around it twice on two sides you don't even need to compress it all the way for it to fit back in place eaisely I tired some heavy duty zip ties the kind with the metal tang and they kept breaking.
| The Following User Says Thank You to STEWARDORNG For This Useful Post: | funwheeldrive (01-11-2017) |
#162 | |
Drives: Dodge Patitas
Sent from my A1P using Tapatalk |
#163 | |
| The Following User Says Thank You to funwheeldrive For This Useful Post: | jcw99 (01-11-2017) |
#164 |
Drives: 2016 BRZ
#165 |
| The Following User Says Thank You to sato For This Useful Post: | funwheeldrive (01-16-2017) |
#166 |
Drives: 13 BRZL/12 Tundra TURD/09 FJR 1300
So rather than delete the spring all together, I installed an Mtec clutch spring today. I just like the idea of a smoother pedal return and as some have referred to it, no slop at the top. Great product, best of both worlds - I think anyway. I can now feel the clutch... little heavier pedal but with smooth return and positive engagement. Win win.
http://www.modbargains.com/MTEC-Ind-...Z-86-MCS86.htm I have the two shift springs by them and a Perrin rear shift rod bushing in my garage slated for install next. |
| Clutch return spring removal | MikeyBRZ | Engine, Exhaust, Transmission | 186 | 09-16-2020 01:40 PM |
| Car dies after 15-20 minutes? | PolishFrs13 | Issues | Warranty | Recalls / TSB | 28 | 10-08-2015 05:28 PM |
| Toyota 86 in 10 minutes. | KKaWing | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 6 | 03-28-2013 10:06 PM |
| 32 Hours 7 Minutes | Wes B. | Other Vehicles & General Automotive Discussions | 11 | 12-26-2012 10:10 AM |
| How to hack a BMW and steal it in 3 minutes | Dadhawk | Other Vehicles & General Automotive Discussions | 9 | 07-11-2012 01:11 PM |
