#43 | |
Drives: Skoda Yeti DSG diesel 4x4
The gearbox will free up over time but it wouldn't hurt to ask the dealer to check the oil level. If they question that, point out that one has already been found with virtually no oil from the factory, after it destroyed itself. |
#44 |
Drives: 2013 Ultramarine FR-S
**I posted this in another thread but I think it applies to the OP***. The transmission is Aisin and it's a very close relative to the manual gearbox in the RWD 6MT used in the Lexus IS250. I drove a 2006 MT IS250 for two years, from brand new until 2008 (approx 35,000 miles). From my experience, I have heard VERY similar noises as described by the OP. I even had the infamous "jar of marbles" sound when shifting lower gears at slower speeds. I never had any mechanical problems with the IS MT clutch or tranny. I sold it to a work colleague and she and her husband drove it another 25k miles with no issues. I'm not saying you don't have an issue to be addressed, but I can say from my experiences the tranny and clutch did have a few quirky noises in my IS. BTW - I drove that IS hard and loved every minute of it.
#45 | |
Drives: Whiteout Scion FR-S
http://www.amsoil.com/storefront/mtg.aspx http://www.redlineoil.com/product.aspx?product=50304 Note that the manual specifies a 75W-90 gear oils with grade GL-3. From what I can find, GL-3 has been mostly superseded by the GL-4 specification. In any case, excellent synthetic GL-3 oil does not seem to be very available. My research also suggested that GL-5 gear oil would not be appropriate for this transmission.
#46 |
Drives: 2013 VW Scirocco R
thiner transmission oil fixes all these issues
#47 | |
It doesn't seem to be much of a penalty, to have a tight shift for a couple of minutes, to then have superb shift quality when the oil viscosity reaches its optimum in its normal operating temperature range. |
#48 |
The floppy paddle shifter FR-S/BRZ uses the same IS250 slushbox as well.
#49 |
Drives: ITR
I have this issue as well, do you guys think a high quality synthetic transmission oil will resolve or improve this problem?
#50 | |
Drives: 2017 Subaru BRZ PP
| The Following User Says Thank You to Bristecom For This Useful Post: | Bonburner (07-23-2012) |
#51 |
Drives: 2013 Scion FR-S MT
Second gear feels off to me. It is the only one though. I had the dealer look at it and they came up with some excuse, needless to say I will be keeping an eye on it.
#52 |
By doing the double clutch can solve the problem. However, try not to shift it to 1st gear while the car is still moving. It applies to all MT.
#53 |
Drives: 2012 Tornado Grey Toyota 86 GTS
To the OP its is prefectly normally for the gearbox to feel Ike that. My IS200 is the same and I had a TRD short shifter. Which feels identically to the box in the 86/FRS. For those who don't know it's based on the same box as the IS200 but just upgraded. Similar boxes are also used in the MX5s and S15 Silvia's all have felt the same. Just do regularly oil changes and you should be fine.
Cold mornings let the car warm up before driving off and also the use of heel toe and double de clutch in the morning should see it easier to slot in.
#54 |
I wonder if there is air trapped in the clutch system or just a adjustment under the dash at the pedal would fix this?
I am going to go walk out and see if the pedal travel is adjust able. Both these ideas would explain why some have problems and some do not. Since those parts are installed at the factory by people. |
#55 |
What the op is explaining is prefectly normal behavior for that gearbox cold. Which has been around for 14 years.
There wouldn't be any air in the clutch system it's hydraulic. As soon as there is air in the system your going to know about it. Want to stop it feeling a bit notchy when it's cold. Start the car in the morning let it warm up. Make yourself a coffee and then in enjoy the drive
#56 |
Ha! I tried The car is up in the air. No luck till it comes down from the lift.
| A bit of a problem | Gost | Other Vehicles & General Automotive Discussions | 13 | 02-12-2013 08:07 PM |
| A problem with new rules in SCCA/NASA regarding FIA seats | CyberFormula | Other Vehicles & General Automotive Discussions | 3 | 11-09-2011 10:13 AM |
| Help me track down my braking problem :( | #87 | Other Vehicles & General Automotive Discussions | 32 | 09-26-2011 01:49 PM |
