Old 03-12-2015, 02:15 PM   #15
ls1ac
ls1ac's Avatar
All tire choices are tradeoffs. Each of us like different things. So in the for what it is worth-- I have been using Yokohama Advan AD08 tires for, well since they came out.
Great dry traction and good wet (well good for a high performance tire) traction. I had them on a slightly modified Mini S. Summer DD and many weekend track car. I went through many sets and can not give a mileage guess as the track eats them at high rate. The first gen did not winter over very well (in storage). Since then no problem. I took off the stock tires when I got the BRZ and have been running them since. The only problem was on a hot day at Mid Ohio it did roll the rubber off the tread and got greasy. Since then got some other track tires, but still drive and like them for DD.
The Following User Says Thank You to ls1ac For This Useful Post:
N_A (03-12-2015)
Old 03-12-2015, 02:34 PM   #16
Ashikabi
Ashikabi's Avatar
Well tire rack has the Ventus RS3 v2 for 20$ less than the others so I'll probably get those. Thanks for the input guys
Old 03-12-2015, 03:03 PM   #17
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by Shutter View Post
wait, you got 30k(miles?) out of Kumho XS tires, and expect to go another 15k?
I was under the impression the Kumho XS was similar to re-11a, star specs, rival, rt615k etc and would be 20k, at best...
I just might look into the XS again, if thats the case.
I thought like you did but checking tire rack there are a quite a few people with 20k+ on these. If only they were 200tw I would just run these year round. Damn stx rule change....
continuecrushing (03-12-2015)
Old 03-12-2015, 03:06 PM   #18
Ashikabi
Ashikabi's Avatar
I thought I read somewhere the R1R tread wear rating was getting updated to 200. Is that true?
Old 03-12-2015, 03:10 PM   #19
finch1750
finch1750's Avatar
Yes, its rolling out certain sizes at a time. I was referring to the Kumho's though
Old 03-12-2015, 03:16 PM   #20
Ashikabi
Ashikabi's Avatar
Yeah just reminded me of the R1R
Old 03-12-2015, 08:44 PM   #21
orangeblue
Drives: Whiteout
I have the XS that I use for track days, and they work great for that. As a DD tire, they're not great: loud, not great wear characteristics, and notoriously bad in the rain.
orangeblue is offline   Reply With Quote
Old 03-13-2015, 08:07 AM   #22
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
I only got about 8k miles life out of my Kumho Ecsta XS - That's with only 1 track day and all other mileage normal daily driving. This is what they looked like after ~ 8k miles:
I have noticed one thing about the FR-S and my driving style, the rear tires wear twice as fast as the fronts - I HAVE to rotate the tires within every 2k miles to keep wear reasonably even. My Kumho Ecsta Sport LE's are almost as worn down in about the same mileage as well...but they are a much better daily driver tire with phenomenal wet weather handling.
To OP, just get a good inexpensive tire from the Maximum Performance category to get the best possible daily driver tire and just work on solidifying the fundamentals. You can worry about which higher performance tire is the better tire to have for class once it's really something that is stopping any further progress. I wouldn't recommend Kumho XS as a daily driver tire when Kumho has the cheaper Sport LE which is better in basically every aspect. You give up dry grip...but gain phenomenal wet weather ability while also being better in the cold (below 40 - XS grip starts falling off a cliff when you push below 40 degrees...)
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 04-19-2015, 08:37 PM   #23
ShadowTS
Drives: Toyota GT86 SWP
How much noise do the Kumho Ecsta XS produce? The official dB rating is not much higher than many other tires, and definitely lower than the AD08R. Is it comparable to directional tires?
ShadowTS is offline   Reply With Quote
FS: Motegi Racing TRAKLITE 16x7 with Kuhmo Ecsta XS ft86Fan Wheels and Tires 8 03-04-2015 10:00 PM
FS: Motegi Racing TRAKLITE 16x7 with Kuhmo Ecsta XS ft86Fan NY / NJ / CT / PA 2 02-28-2015 11:43 AM
FS : NJ:OZ Superleggera::Kumho XS::5x100::17x8::245/40/17 Fastcarz4life Wheels and Tires 0 05-09-2014 06:15 PM
Kumho Ecsta 4x hanabie Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 10-12-2013 09:16 AM
Thoughts on Kumho Tires? brillo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 06-05-2013 04:51 AM
