#99 |
Drives: Nevermorange FRS
I think the FT needs a cage, without a doubt, and the front needs extra bracing due to those strut towers.
I'm sure you have loads of data with the S2, so when you get data from the FT where are the deltas? Where is it lacking? Entry, apex, exit, straight line... All of the above?
SCCA T4 - FRS
#100 | |
Stig's dark passenger
At this point Im gonna venture to say corner entry and mid corner.
Could be the exit too, but because the entry is so slow, it seems ok Quote:
#101 | |
#102 | |
Even boosted, it suffers a lot. |
#103 | |
#104 |
DK says corner entry and mid corner
CSG Mike says exit and straight. So I was right... all of the above. LOL It's very difficult to fix something that's bad everywhere. Which end works the best? Front or Rear? Is the front roll stiffness addressing the tire's contact patch? Too much/too little camber? Not enough caster to maximize cornering dynamic camber? When it comes to putting the power down (exit) is it struggling with oversteer causing the driver to "wait" or is putting power down causing the front give up like it's lifting up the inside front and outside front is giving up? Any rear suspension bind been identified? I know some others have pointed out potential rear suspension bind. Are spherical bearings being used to make sure the suspensions moves without impedance and there's no funny business going on under load like dynamic toe changes from bushing deflection? edit: You're not trying to use any setup parameters on the FT that worked on the S2 are you? I doubt very little of the S2 setup would be ideal on the FT.
SCCA T4 - FRS
| The Following 3 Users Say Thank You to rice_classic For This Useful Post: |
#105 |
Drives: 2013 ultramarine Scion FR-S
| The Following User Says Thank You to burdickjp For This Useful Post: | EAGLE5 (07-05-2015) |
#106 |
#107 |
D_K,
You should fly me down, I'd be happy to help test it on track. I won't even charge.
SCCA T4 - FRS
#108 | |
Drives: AP2 S2000, S14 240sx
#109 |
Drives: GT86 2014
I'm sorry but you all are talking about the 86? That its a horrible handling car? Or you all are talking about the S2000?
#110 |
#111 |
Drives: GT86 2014
So what they want to say is that the S2000 is better in corner entry, mid corner, exit and straight Then the 86?
Or regardless of the s2000 the 86 is a bad handling car?
#112 |
| best new years ever. | HolyAssertion | Southwest | 25 | 02-23-2015 08:14 PM |
| Me in 10 years | amaciose | Off-Topic Lounge [WARNING: NO POLITICS] | 18 | 02-12-2014 02:37 PM |
| New Years | L3P47 | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 12-31-2012 09:15 PM |
| 6 years from now... | carbonBLUE | Off-Topic Lounge [WARNING: NO POLITICS] | 19 | 02-02-2012 10:42 PM |
