| BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 |
Drives: ms3
Temp gauge on most cars are useless, might as well just use a light to indicate when cold or hot. Coolant temps constantly fluctuate about 40 degrees in normal driving which is like 1/4 of gauge range, so a true gauge will tell you when there is a potential problem with your cooling system if you start to see larger variation.
![]() BRZ STi on order |
#16 |
Drives: '79 Datsun 280zx
Thank you for bringing this up - I'm always amazed at how few people realize how useless their temp gauge is.
And basically repeating a recent sentiment of mine, this is another reason I love my old Datsun. The coolant gauge actually follows the coolant temperature, so it's actually worth referencing, and is a usable tuning tool. Any dyno operator worth his/her salt knows that engine temperature has to be consistent from run to run, or a comparison is useless - moreso with modern cars than with older ones. ECU's do a whole lot of tinkering with varying coolant temperatures. And you can't use a stock gauge to tell. |
#17 |
Drives: 2013 DZE/01 (sold for MX5 ND1)
Unfortunately, it's a dummy gauge.
Gotta respect Mazda for bringing a real oil gauge back to the Miata with the NC (though it still has a faux temp gauge). I would've happily paid $100 more to have real oil and temp gauges in my BRZ.
#18 |
I Love custom Turbo kits
Drives: Limited BRZ
It's not about money, its about having a gauge to accommodate the masses a.k.a. dumb people who see the gauge move a mm and come screaming their car needs to be fixed.
#19 | |
Drives: RX8 S1
the gauge will stay at cold untill operating temp reaches around 70 degrees Celsius then it will move linearly untill temperature reaches operating temperature (different for different cars but lets say 95 degrees Celsius for argument sake) and it will stay in the middle of the dial until the temperature is about to hit boiling point (different depending on what the pressure of the system is)
#20 | |
Drives: 2017 Subaru BRZ PP
#21 | |
Drives: scion tc
What kind of question was that OP? |
#22 | |
Drives: scion tc
#23 | |
Drives: scion tc
#24 | |
Registered you sir
Drives: 99 impreza coupe
#25 | |
Site Moderator
Drives: Stuff
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#26 |
1st86 Driver!
I guess the term "dummy" threw me off in this discussion. To me, that means it doesn' work at all, like those prop electronics they use at a furniture store.
What is being described here matches the fuel gauge. It's not accurate but gives you an overall "impression" of whats going on at determined critical point. (there was a whole other thread where I ranted about the accuracy of "E" on modern cars). I agree it should be accurate, or it should not pretend to be accurate by putting numbers on the gauge. Just a Red/Yellow/Green range. Last edited by Dadhawk; 06-12-2012 at 02:13 PM. Reason: Spelling... what is with me, this forum and spelling? |
#27 |
Site Moderator
Drives: Stuff
The fuel light comes on early for sure, but my fuel gauge actually does seem pretty good.. a hell of a lot more accurate than my Integra which takes 3/4 tank to move from fuel to half, then drops like a rock from that point...
-Dave
#28 |
Drives: 2015 Halo FR-S
Sure, there are "dummy" gauges out there that have 3 positions: cold, normal, new-engine.
I've been monitoring the coolant temps in my civic via a scan-gauge for over 3 years and the dash gauge is accurate. I get my second "bar" when the temp hits 130°, and it warms up to about 185° within 3 minutes. I've never seen temps higher than 195°. I think that wildly fluctuating coolant temps are a thing of the past and we are confusing poorly designed sensor feedback with rock solid modern cooling systems. |
| Seat heater temperature? | milenko11 | BRZ First-Gen (2012+) -- General Topics | 29 | 09-20-2012 02:19 PM |
| Aftermarket gauge placement | CyberFormula | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 08-18-2012 02:01 AM |
| European fuel/coolant gauge face | arbnpx | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 05-31-2012 01:23 AM |
| Gauge Sweep? | himbo | BRZ First-Gen (2012+) -- General Topics | 17 | 12-12-2011 12:39 PM |
