#29 |
Only users lose drugs.
Drives: All the time
#30 |
Sweeper
it is origins?
#31 |
#32 |
Sweeper
just poking fun of your use of "it's" when you mean "its"
#33 | |
Whoops - missed that, both times...lol |
| The Following User Says Thank You to venturaII For This Useful Post: | Koa (03-09-2015) |
#34 |
Sweeper
sorry for trolling this earlier.. J series V6 definitely would be unique, but the K series honda engines are just soooooo godly. Rev-happy 100hp per cyliner, reliably on stock internals, with a proper setup FI... what more could one ask for?
It's no wonder why members here will recommend them over this build. Will be keeping my eyes out for a J series if anyone does it, though. I love engine swaps and am all about individualism/hacking/expressing oneself to be different. Call me ignorant here, but I just don't like Honda. I don't like what the fast and furious turned the brand into (not Honda's direct fault, of course). Except their motorcycle unit. If I didn't get my R6 for $2000 and a backbreaking day of labour, I would have held out for a CBR. |
#35 | |
Fair enough. Personally, nothing beats the sound of a well tuned 60 degree V6, and there is plenty of aftermarket available to turn the J series into a real screamer, if so inclined. I grew up working on Capri-based Ford Colognes and Alfa V6s (as well as lots of other Euro oddballs...), so I have a soft spot for that sound. Displacement of the Honda motor is a nice compromise between I4 screamer and LSx, and the ample torque reflects this. But I'm not trying to compare it to an LSx - I think the 275-300 bhp/250 ft-lb range would be perfect for our transmissions to live behind and not be blowing them and axles up all the time. There's plenty of potential in the motor to go well up into the 350+ range when you add cams and head work, etc, but then you're opening a new can of worms to deal with at that point. Simple bolt-ons and a tune would be more than enough to put it on par with a supercharged FA20, and have 3x the reliability. Plus you'd have a nice sound and less weight than a F/I FA20. |
| The Following 2 Users Say Thank You to venturaII For This Useful Post: | civicdrivr (03-10-2015), Koa (03-09-2015) |
#36 |
So elite I'm 1338
Drives: WRB Subaru BRZ
That swap is just a bad idea :P
-Jack Burton |
#37 |
| The Following User Says Thank You to venturaII For This Useful Post: | civicdrivr (03-10-2015) |
#38 |
do you have any official weights? They could have just removed 40lbs of a/c.
#39 |
Grassroots Motorsports lists the converted NA Miata they tested as 40 pounds heavier than the factory setup. Given the conversion includes subframe, adapter plate, a custom steel oil pan and a few other items in addition to the motor itself, it's a fair guess to assume the J series motor is not much heavier than the OEM Miata motor, and certainly no heavier than the FA20 lump. I'm sure they removed the A/C from the donor motor before it went into the Miata since it came out of vehicles that aren't available without A/C, but whether the Miata had A/C to begin with is unknown. The manufacturers statement is also that the conversion adds 40 pounds to the front axle.
#40 |
Drives: RAVEN
| The Following User Says Thank You to NOHOME For This Useful Post: | civicdrivr (03-10-2015) |
#41 |
Swaps "can" be a good idea if executed properly. Can the FA20 match a stock J with a few mods and e85? Yeah... but what about those same mods on the J? Lots of people hate Honda and hate swaps for no reason but the truth is, Honda makes damn good engines and the power potential of a J easily eclipses the FA20s... but it'll be a lot of work. I found an article where some folks in New Zealand stuck 2 i4 motorcycle engines together to make a v8 with a 12k(i think) red line. You can buy this swap. It isn't cost effective or easy, but it's cool and unique and fast. That's what it's all about right? If you want it to be easy, get a rustang and add boost. Otherwise, swap or boost, or both to make your vision a reality. Stay classy.
| The Following User Says Thank You to Ashikabi For This Useful Post: | civicdrivr (03-10-2015) |
#42 | |
Drives: 2015 Series.Blue
NA Miata motors are quite heavy (cast iron block with aluminum head), so I'm betting the FA20 is far lighter. Regardless, V6's in general suck (not going to get into the design reasons, but they're ONLY good for packaging) |
| Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 11:54 PM |
| BRZ headlight swap to Monogram Series *UPDATE:10/12/14 w/ Pics* | JDis3 | Cosmetic Modification (Interior/Exterior/Lighting) | 31 | 04-12-2015 06:31 PM |
| 10 Series / Series.Blue rear view mirror | 86-ADL | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 11-16-2014 08:32 PM |
| FRS 10 SERIES GLOWING BADGE SWAP? | IgnitionGundam | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 11-29-2013 01:00 AM |
| 3 upcoming Honda VTEC motors from Honda!! | RRnold | Other Vehicles & General Automotive Discussions | 10 | 11-19-2013 10:27 PM |
