#71 |
Drives: Scion FR-S Ultramarine
there are posted pictures(by me) in the thread about the resistor. 3mm leds work fine. or you can buy flat ones on ebay. which i would suggest since they spread light better. not sure what you mean by t3, t4, etc.
#72 |
86TUP
Drives: 86 GT
ok.
The t4/t4 i refer to are the wedge LEDs for the two outer dials |
#73 | ||
Couple older questions or tips I thought I would add for people looking up information on removing the evil orange....i hate that orange.
![]() If you already have round LED you can sand the tip flat and also the sides to make them look frosted is the best way I can describe it. This will help spread the light evenly and you're less likely to get hotspot where the light is brighter or dimmer. I do this with the flat LEDs as well. |
| The Following User Says Thank You to Shanahan For This Useful Post: | civicdrivr (04-08-2013) |
#74 |
Custom User Title
Drives: Asphalt FR-S MT
This part. I am trying to do something else, but this panel needs to be removed. How much force should I use and how should I pull on the panel? The side with the bucket doesn't seem to want to come out.
#75 |
Drives: 2018 Golf R
Its very tight. You pull it straight out towards the shifter. It takes a good bit of force.
Sent from my Nexus 4
Parting out HERE
| The Following User Says Thank You to civicdrivr For This Useful Post: | boredom.is.me (04-23-2013) |
#76 | |
It helps if you wedge a trim removal tool or a small screwdriver between the top of it and the HVAC panel. There are 3 clips across the top there that hold it in.
2013 Asphalt FR-S 6MT - Perrin 2.5" Catback Exhaust - Grimmspeed Strut Tower Bar - Grimmspeed Master Cylinder Brace
Grimmspeed Hood Struts - Grimmspeed 86 Oil Cap - Grimmspeed Boxer Battery Tie Down - HID - Pioneer AVH-X5500BHS - Infinity Basslink 10" Sub |
| The Following User Says Thank You to mottor For This Useful Post: | boredom.is.me (04-23-2013) |
#77 |
something plastic like a trim removal tool doesn't sound bad, but i don't think i'd use a screwdriver. you could end up messing up the cosmetics of it. i say just pull hard with your hand. it'll eventually come out. after you've pulled it out once then it comes out pretty easily after that in case you need to go back in for something else.
#78 | |
#79 |
Drives: GT86
I want to do this, but im scared lol. My dad has the tools, but I have no experience. Could someone help me out with details on the soldering part?
#80 |
Drives: GT86
im going to order these:
http://cgi.ebay.com/ws/eBayISAPI.dll...m=161009232477 and http://www.ebay.com/itm/100-LWT6SC-W...item2eb48e34a2 Would that do the trick? |
#81 |
Yes, those are the correct LED's for the project. Make sure you have some resistors with the flat top LED's otherwise you'll blow the bulb. You should only need 2 flat tops and around 20 SMD's.
As far as soldering, what details do you need? It's basically just a remove and replace procedure. Touch the soldering iron to one side of the SMD that is currently mounted and use tweezers to pry that side up. Then do the same on the other side. Then mount the new SMD's by placing them in the same spot and soldering them down. Make sure the positive and negative sides are in the same direction as the original ones were mounted. It all takes practice. Let us know if you have more questions.
| The Following User Says Thank You to mottor For This Useful Post: | mandi (04-25-2013) |
#82 | |
Drives: GT86
Im going to give it a shot. Whoever said we girls dont have the guts to work on our own cars was soo wrong. I noticed that on the first page showing the DIY there were 2 surface mount SMDs attached to the twist type base. Whats the go with that? Do i need the other type of LED (i think it was a 3mm)? Dont want one to be brighter than the other. Sorry for the basic questions... Im still learning =) |
#83 | |
Are you referring to this picture? If so, this is where a few of us used 5mm flat top LED's with a resistor instead. Either method will work. I'm not sure which would be brighter or more evenly spread out, but I can tell you that a 5mm flat top blends in perfectly with the rest if you go that route. Props to you for working on your own car. Good luck with the project. :happy0180:
#84 | |
Drives: GT86
I'll probably do it this way...with the 5mm flat ones. Blending in perfectly with the rest sounds like the way to go. How did u guys attach the led like in the pic above? both to the resistor and the twist base? |
| Changing Premium to Limited? | zygrene | BRZ First-Gen (2012+) -- General Topics | 32 | 10-09-2012 12:58 PM |
| I'm changing my order from World Rally Blue to Lightning Red | Subie | BRZ First-Gen (2012+) -- General Topics | 26 | 06-12-2012 01:59 PM |
| Changing order, does it require a new order? | xwd | BRZ First-Gen (2012+) -- General Topics | 11 | 03-21-2012 01:57 PM |
| LEDs that convert heat directly into light... | serialk11r | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 03-10-2012 01:08 PM |
