86WORX
Old 10-08-2012, 01:21 AM   #57
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Whoot!
http://www.ft86club.com/forums/showthread.php?t=19226
Originally Posted by F1point4 View Post
Got busy this past weekend with
+ RaceComp Engineering Yellow Springs
+ OEM Front Camber Bolts (Subaru Part 901000394)
+ Cusco Rear Lower Control Arms (Part 692 474 L)
Thanks to Andrew/Myles/Dan at @Racecomp Engineering for their professionalism and expertise. Felt like I was making the right choice after our conversations. Very good to work with.
Their starting recommendation to correct the additional negative camber in the rear suspension was the Whiteline Camber Bushings for the upper control arm. I make it a point to do as much as I can DIY so I can learn, however installation/adjustment of these were beyond my skills/tools at the moment. After careful consideration and caution from Myles I went with..
Cusco Lower Lateral Links/Lower Control arm. Much easier to install and adjust, albeit with a higher cost. Since the rear setup is near identical to a 2008+ WRX/STi, this is a proven part. Appreciate Jeremy/Yo @FT-86 SpeedFactory for the assistance/speed in acquiring these arms. As with most Cusco parts, the manual was all in Japanese. Cusco USA has kickass customer service. After a call to them, I had an email with the English instructions.
The OEM Front Camber Bolts are just like the stock bolt except the Camber bolt doesn't have a widened girth to fill the top slot on the strut. Therefore you get some play and can add negative camber slightly for more grip in the corners.
In the end this setup allows me to get some negative camber in the front, and keep from too much negative camber in the rear. The drop is mild so I don't need to run any aggressive settings just to avoid rubbing. Good in my book.
I haven't had a chance to get an alignment yet, so I will refrain on giving detailed feedback on the handling until so. Unlike @AVOturboworld, I installed these in one go. What I will say is the resulting drop is absolutely perfect. Definitely what the car should have been set to from the factory. It is also cool to be able to see the arms when you bend down. Go blue. This is my first lowered car, and it definitely feels like you are hugging the ground while driving. Noticed that most truck's low beams look like high beams now. The install went well, so far no creaks/vibrations/pops so far. Success for the amateur enthusiast.
Here are some car porn and notes from the install
Messing with iOS6 Panorama mode
20121005-RCEYellow-CuscoLCA-1 by VictorN07, on Flickr
20121005-RCEYellow-CuscoLCA-2 by VictorN07, on Flickr
20121005-RCEYellow-CuscoLCA-3 by VictorN07, on Flickr
20121005-RCEYellow-CuscoLCA-4 by VictorN07, on Flickr
RCE Yellow Springs vs OEM Front. The RCE Yellows are much beefier than the OEM one. Definitely feels like a quality product.
20121005-RCEYellow-CuscoLCA-5 by VictorN07, on Flickr
The Rear hats do not rotate freely like the fronts. We had to separate the metal thingy from the rubber piece that grips onto the top of the spring. The rubber has to be rotated to accomodate for the RCE Yellows. Otherwise the hat and the lower attachment point won't line up and can't be re installed in the car.
20121005-RCEYellow-CuscoLCA-6 by VictorN07, on Flickr
This is the proper way to break loose and tighten the top nut on each strut.
Make sure the springs are compressed for safety.
Use a 6mm Hex Key and 17mm pass through socket on the front struts.
Use a 5mm Hex Key and 14mm pass through socket on the rear struts
I could not break the nuts loose by hand. Using an impact driver, I tapped lightly until I saw the socket turn slightly. Then finish with the hand tools.
Using solely an impact driver may spin the inner shaft. If the shaft spins enough, the seals in the shock will break making for a blown strut.
20121005-RCEYellow-CuscoLCA-7 by VictorN07, on Flickr
The Cusco Lower Control Arm has a pillowball bushing and adjustable camber. The stock one (black) has no adjustment. The Cusco is also much beefier than the OEM one. I think it'll take a lot to bend this arm.
20121005-RCEYellow-CuscoLCA-8 by VictorN07, on Flickr
20121005-RCEYellow-CuscoLCA-9 by VictorN07, on Flickr
It's hard to see in this picture; the swaybar endlinks are weaksauce.
20121005-RCEYellow-CuscoLCA-10 by VictorN07, on Flickr
Here is a picture of my car right when I bought it.
IMG_0301 by VictorN07, on Flickr
Oh my how have things changed
20121005-RCEYellow-CuscoLCA-11 by VictorN07, on Flickr
Pre-Drop with the Weds
21020923-RallyArmorMudGaurd-01 by VictorN07, on Flickr
Post Drop
20121005-RCEYellow-CuscoLCA-12 by VictorN07, on Flickr
Playing with the filters in Camera+
20121005-RCEYellow-CuscoLCA-16 by VictorN07, on Flickr
20121005-RCEYellow-CuscoLCA-17 by VictorN07, on Flickr
My Favorite Picture!
20121005-RCEYellow-CuscoLCA-18 by VictorN07, on Flickr
F1point4 is offline   Reply With Quote
The Following User Says Thank You to F1point4 For This Useful Post:
SkAsphalt (10-11-2012)
Old 10-08-2012, 01:35 AM   #58
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Car looks great. If those wheels are still available when my BRZ gets here I'll have to check out a set. Great choice of wheel.
Coheed is offline   Reply With Quote
Old 10-08-2012, 01:36 AM   #59
F1point4
Photo Specialist
F1point4's Avatar
Thanks. Those are a great choice, must have for weight weenies!
Old 10-08-2012, 02:00 PM   #60
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
Was also thinking of rce yellow since I don't want a huge drop but when I get my new wheels/tires next summer I don't want that huge wheel gap.
SubaSteve is offline   Reply With Quote
Old 10-11-2012, 02:16 PM   #61
Jayde
Jayde's Avatar
Curious, but did the oil drain valve come with the red safety clip?
FR-S looks great btw!
Jayde is offline   Reply With Quote
Old 10-11-2012, 05:07 PM   #62
F1point4
Photo Specialist
F1point4's Avatar
THey are great springs, stiffens up the suspension quite a bit. Keep in mind they haev high spring rates. If you want a smoother ride you may need to consider other options.
Old 10-11-2012, 05:08 PM   #63
F1point4
Photo Specialist
F1point4's Avatar
I ordered them separately and purchased them here. They are cheap, but man the shipping will get you.
http://www.qwikvalve.com/5-8-Safety-Clip.html
Old 10-11-2012, 07:15 PM   #64
just86
just86's Avatar
Drives: 2013 genesis rspec
still no exhaust...
just86 is offline   Reply With Quote
Old 10-11-2012, 07:20 PM   #65
Jayde
Jayde's Avatar
Shipping for me is either $4.29 or $7.89, depending on what type I want. Then again, it's coming from the same state, so I'll have to pay sales tax too.
I take it the valve on that site, the F-108 is the same as what you/everyone else has?
Old 10-11-2012, 07:33 PM   #66
F1point4
Photo Specialist
F1point4's Avatar
Originally Posted by just86 View Post
still no exhaust...
Not yet....
http://www.ft86club.com/forums/showthread.php?t=19503
Old 10-16-2012, 12:18 AM   #67
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
looks great on the springs
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline   Reply With Quote
Old 10-16-2012, 12:26 AM   #68
F1point4
Photo Specialist
F1point4's Avatar
Have some more updates
Perrin Headerback Review
20121012-WhitelinePerrinBushing_Headerback-12 by VictorN07, on Flickr
Whiteline Positive Shift Kit DIY
http://www.ft86club.com/forums/showthread.php?t=19782
20121012-WhitelinePositiveShiftKit_DIY16 by VictorN07, on Flickr
Perrin Rear Shifter Bushing
http://www.ft86club.com/forums/showthread.php?t=19767
20121012-PerrinRearShifterBushingDIY-01 by VictorN07, on Flickr
Old 10-16-2012, 12:50 AM   #69
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
I also did the shifter bushing but I'll have to also look into the whiteline. For such a cheap price how can it not be worth it? I'll probably wait till I can do both that and the positive traction kit at the same time.
Old 10-17-2012, 10:57 AM   #70
F1point4
Photo Specialist
F1point4's Avatar
That's a good idea. It is worth it.
Asphalt Scion FR-S aznsensazian FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 21 03-17-2014 02:13 PM
Asphalt FR-S pics Rob_g CANADA 24 09-03-2012 06:01 AM
Asphalt in the snow Double4Free Scion FR-S / Toyota 86 GT86 General Forum 5 06-10-2012 02:56 PM
Asphalt 6MT FR-S Symbiont Southern California 22 06-06-2012 08:47 AM
ant08 Asphalt MT ant08 Member's Car Journals 3 06-04-2012 05:16 PM
