#855 | |
Drives: 2013 Whiteout FRS
I have the same issue, but only when the AC is on. This happens when I coast to a stop when my shifter is on neutral. Without the AC, this does not happen.
#856 | |
That sounds like detonation, which has me concerned on 12.5:1 motor. I want to add a supercharger, but not till this issue is solved. The last thing I need is a blown motor leaning out and detonating. |
#857 | |
Drives: Ultramarine FR-S MT
Same here. Something like 1 in 5 times when coming to a stop with the AC on it will happen. Does it with clutch disengaged or with clutch engaged and car in neutral. Naturally, the dealership have been unable to replicate
#858 |
I don't know if I'm too early to say this, but after I install catback exhaust, it never happen to me for about two weeks. Except I put silencer on it tho. Who knows it might be coincidence. Lol
#859 | |
Drives: 2015 Mustang GT (on order)
#860 |
Drives: 2013 Scion Fr-s
SO is there a fix?
#861 | |
Haven't used AC for a while, as it's been pretty chilly at where I live, but I guess I'll see what happens when I get a chance to use the AC in the upcoming summer. |
#862 | |
Sent from my Galaxy Nexus using Tapatalk |
#863 | |
Drives: 2013 WR Blue Limited Manual BRZ
| The Following User Says Thank You to Deathalo For This Useful Post: | Marrk (05-14-2014) |
#864 |
Drives: swp brz limited
I have identical issue as in video too
#865 |
Drives: 2014 Whiteout TRD FR-S 6MT
mine does the same thing with the AC on
"I love dinosaurs so much that I’ve based my life on burning as much black melted dinosaur flesh as I can on a daily basis...even the screaming sound of prehistoric reptilians being burnt through any of the classic Japanese four cylinders gives me great joy."
#866 |
Drives: 2013 BRZ Limited
Fixed in 10 minutes after 2 years plus. Throttle body coolant bypass. No kidding. No change to routine but this. Amazing.
#867 |
Drives: 2013 FRS Whiteout
Idle issue?
I believe this has to do do with the idle speed being set to low and the AC compressor kicking in, dropping rpms to a stalling point then ecu compensating. I highly doubt it's for anything to do with coolant or throttle body. I've confirmed this with several tuners. If in doubt, turn off your AC, at least in my case that makes the issue go away.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
#868 |
It is what you say based on load. For some reason in my case in doing the bypass solved the issue. Tested it back and forth and on my AT that is what solved the problem. Not the throttle body plate per se, but possibly less strain on system? I was surprised as heck too. AC on no change to my routine or weather. I couldn't believe it also. It worked for me and still surprised. Especially when I swapped back and forth reproducing problem non bpass then problem went away with bypass. I did this 3x.
| A Small Easter Egg | avusblue | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 06-29-2012 12:38 AM |
| Subaru BRZ - The biggest small car ever | Laika | BRZ Photos, Videos, Wallpapers, Gallery Forum | 7 | 06-09-2012 02:21 AM |
| Received my FR-S with a small ding | Neurytic | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 06-03-2012 01:53 PM |
| Isn't 6-10 miles on a new car kinda high? | houseofsuffering | BRZ First-Gen (2012+) -- General Topics | 45 | 05-15-2012 01:32 PM |
| Kinda make me worry! (Radiation related thing) | EJ20 | Off-Topic Lounge [WARNING: NO POLITICS] | 32 | 05-09-2011 01:58 AM |
