#827 | |
Drives: Whiteout FR-S
#828 | |
Played with the brakes on my way home today, no effect. I swear the engine idle is entirely the AC compressor kicking in and this is a Toyota "thing" |
#829 |
Drives: Whiteout FRS
@vubaru Have you tried going back to N/A or have the kit re-installed to see if the problem still occurs? Hopefully it's not an oem issue despite the fact that other people who did the same DIY/vendor install with the kit didn't get the same issues as you did.
| The Following User Says Thank You to Bach415 For This Useful Post: | strat61caster (04-19-2013) |
#830 | |
You've got a lot of hoops to jump through to prove it's an OEM defect and not a result of your mods, best of luck to you but the odds aren't in your favor. Maybe if something comes to light on a bunch of cars you might be in the clear but that hasn't happened yet. Idle dipping below standard rpms with noticeable vibration is not an issue that Toyota/Subaru care to correct. Installing aftermarket engine modifications and then having issues is kind of on your plate. Just my unneeded thoughts. |
#831 | |
Drives: car
| The Following User Says Thank You to radroach For This Useful Post: | strat61caster (04-19-2013) |
#832 | |
My money says the dealer techs will write down your problem, open the hood, see the turbo, shut the hood and say there's nothing they can do. It's out of their scope. Best of luck and apologies if I came across a bit rude. |
#833 | |
#834 | |
Drives: FR-S 6MT
But the turbo pretty much affects everything engine wise as far as voiding the warranty.. You can pretty much count on it.. |
#835 |
Drives: Fr-s
I have problem
2013 fr-s ac on have same problem coming to a stop is stalls for a secon under 500 then comes on right back but w out ac on dosent to it ?????
#836 |
Drives: 1995 Ford Probe
i had the idle issue after the "Warranty Recall" flash of the ecu.
ecu was flashed with my first ny state emissions inspection last saturday... noticed yesterday and today that the idle stutters every 10 seconds when in park or in drive with the brake on... like the engine is having a mini stroke.. i took an iphone5 video and sent it to my service advisor at westbury toyota... he said he would look into it.. especially since my video caught it perfectly on the rpm needle. ughhh ![]()
#837 |
Drives: GT86 Pearl White
Just saying, this is what my car did just before CEL problems kicked in, just after my drive in was finished.. A quick stint at the toyota garage fixed it right up, and after 2 months of giving the car the "drive it like you stole it" treatment, they stuff they changed seems to have worked really well.
#838 |
Drives: 2013 FR-S Hot Lava
Still having mildly unstable idle. 10,000 miles after the CEL fix now.
I would like to sit in the car with the engine running and not feel like it's running at all. Instead, I get a lot of vibration/stuttering through the chassis. I know this is not a luxury car but still..
Live to drive another day
#839 |
Drives: slow
My idle is fine the the car shakes a bit at about 1800 rpm when I rev it up in neutral (6mt).
The VQ's always got a bad rep for being Thrashy, I'm honestly not sure why that term isn't thrown around more regarding the twins. |
#840 |
I am noticing I have the rough idle only with the A/C on. Anyone experience this?
| A Small Easter Egg | avusblue | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 06-29-2012 12:38 AM |
| Subaru BRZ - The biggest small car ever | Laika | BRZ Photos, Videos, Wallpapers, Gallery Forum | 7 | 06-09-2012 02:21 AM |
| Received my FR-S with a small ding | Neurytic | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 06-03-2012 01:53 PM |
| Isn't 6-10 miles on a new car kinda high? | houseofsuffering | BRZ First-Gen (2012+) -- General Topics | 45 | 05-15-2012 01:32 PM |
| Kinda make me worry! (Radiation related thing) | EJ20 | Off-Topic Lounge [WARNING: NO POLITICS] | 32 | 05-09-2011 01:58 AM |
