#141 | |
Drives: 2013 Whiteout FR-S
I would agree, It just seems like the dip is a little more pronounced on the FRS. I dont think its a problem, but is this what other people are experiencing or is there a different issue? |
#142 |
Drives: 13' Scion FRS MT
So if I understand things correctly now this is what it should NOT do? My FRS seems to sit at 500-750 RPM a decent amount of the time and otherwise near 1000 RPM. Should I be worried? Honestly, it hasn't made any bad sounds like the engine is struggling or tended to stall whilst idling in nuetral or with the clutch pedal pressed in. EDIT: In any case, it doesn't seem to bounce around or "dip" uncontrollably |
#143 | |
Drives: Subaru BRZ LT
| The Following User Says Thank You to DantKR For This Useful Post: | Re~Mix (06-13-2012) |
#144 | |
#145 |
Drives: Whiteout FR-S
The car isn't idling low all the time. If it sat for 2 mins at the same rpm then it's fine, but ours seems to do it when slowing down. As far as I know, it's not normal to stall when coming to a light, or even drop low enough in idle to nearly stall and shake.
#146 | |
Drives: 2018 Golf R
Parting out HERE
#147 | |
#148 |
| The Following User Says Thank You to DantKR For This Useful Post: | civicdrivr (06-13-2012) |
#149 |
Loves the Smell of Track
Drives: '13 86
I was thinking the same thing. Maybe the OP can edit the 1st post, listing username, last 5 of VIN #, production date and delivery area. My frs mt is running fine so far @ 500 + miles.
2020 86 Hakone MT build thread: https://www.ft86club.com/forums/show...31#post3326231
2013 Toyobaru 86/FR-S 6MT, Red, aka Candy O SOLD http://www.ft86club.com/forums/showthread.php?t=7934 |
#150 |
What you are describing sounds like a vacuum leak or a MAF problem. MAF turbo cars with BOV's have this same problem if the BOV is set too "soft", ie, the system doesn't close. Either way, I'd have it checked out by a dealer. Chances are some of the intake routing hoses are loose or cracked.
#151 |
#152 |
Drives: Nevermorange FRS
My s2000 did this sometimes after a big change in weather. Example: Seattle has a very temperate climate and doesn't see anything "warm" until July then bam: 85 degree days. The S2000 would have to "re-learn" the ambient air, would stumble a bit at idle, "pop up" then come back down and it's all good. It might do this a couple times after the start of the warm season.
Ok, but this is of now value to those where the CEL's were coming on or the car was dying... That's a bigger problem I suspect and if it happens to me when I buy mine I will be back in the dealership IMMEDIATELY. |
#153 |
Drives: 10 VW GTI
I once drove a modified S2000 with turbo. If I quickly release the gas when the car in station, the RPM can drop to very low, the higher I rev it, and release quickly, the lower it drops and can stall very easily. However, it I release gently, there is much less chance for RPM to drop lower than it should be at idle.
So, can you guys with MT FR-S try to see if you gently release the gas, coasting rpm back to about 800, is the problem is still there? |
#154 |
Drives: 10 VW GTI
That should be normal. Every car does it so it can warm up quicker. Don't sit and wait the car to warm up, drive it. This warms the engine up quicker. Sitting there does more harm to the engine and is bad to the environment.
| A Small Easter Egg | avusblue | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 06-29-2012 12:38 AM |
| Subaru BRZ - The biggest small car ever | Laika | BRZ Photos, Videos, Wallpapers, Gallery Forum | 7 | 06-09-2012 02:21 AM |
| Received my FR-S with a small ding | Neurytic | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 06-03-2012 01:53 PM |
| Isn't 6-10 miles on a new car kinda high? | houseofsuffering | BRZ First-Gen (2012+) -- General Topics | 45 | 05-15-2012 01:32 PM |
| Kinda make me worry! (Radiation related thing) | EJ20 | Off-Topic Lounge [WARNING: NO POLITICS] | 32 | 05-09-2011 01:58 AM |
