Old 02-25-2015, 12:39 PM   #113
HunterGreene
Hail Magnet
HunterGreene's Avatar
Originally Posted by mav1178 View Post
... so basically your power steering ASSIST went out. You can still turn but it's harder to turn.
Again, if it's not a lock issue then it's not a true safety issue.
-alex
Or "isolated" issue would be a better descriptor.
It has priests in it?
Old 02-25-2015, 01:26 PM   #114
Ultramaroon
fabulous
Ultramaroon's Avatar
Originally Posted by Tomking View Post
1: When the problem occurred, the steering just stiff but not pulling either left or right.
2. No, it does not resist to pull it back to the center. It was just extremely hard to turn and only went inch by inch when I tried to steer it. It feels as hard and resisting as if you have your car park in the garage with the engine off.
3. It happened twice in that one drive but after I rest it overnight, it does not happen again.
Thanks. I think we can consider this resolved. Whether it was a true overtemp condition or if it was a false positive, this was as we first, albeit harshly, concluded - a loss of P/S.
This was not a lockup or an otherwise hazardous condition.
The possibility of P/S loss is clearly stated in the owner's manual. We should all be aware of it.
Old 02-25-2015, 02:11 PM   #115
I still stand by my original armchair diagnosis of an over temp cut out!
OP said was "hot" that day. I have never experienced it but understand that in most of Australia if a native says it is "hot" that means "freakn' hot" to many of us. ( @Captain Snooze ?).
Steering hits thermal overload and cuts out.
OP pulls over waits a few seconds and tries again. Still in overload.
Waits a little longer. Has come down enough to work.
Drives a few more minutes. Heats up again and goes to overload.
Waits and cools enough to keep going until reaches home.
Car sits overnight and cools completely. Works fine.
Does not drive under the same conditions (ambient air temp, location/angle of sun striking dash and creating radiant heat, same amount of time spent in conditions, etc) and symptoms do not repeat.
Old 02-25-2015, 03:29 PM   #116
Ultramaroon
fabulous
OP said was "hot" that day. I have never experienced it but understand that in most of Australia if a native says it is "hot" that means "freakn' hot" to many of us. (@CaptainSnooze ?).
I agree with you. Just trying to be diplomatic.
Old 02-25-2015, 03:44 PM   #117
Well stop it! You know how easily I get confused!!!!
Old 02-25-2015, 06:42 PM   #118
Ultramaroon
fabulous
Duuuude, my bad.
Old 02-26-2015, 01:48 AM   #119
Tomking
Drives: FT 86
The power steering unit should be working normally under that temperature (was about 38-40C) because that is the normal temperature in Australia's summer.
I think we all agree that the Power steering is faulty and should be replacing under new car warranty which it did...
Thank you all for participating, this case can now be closed,
Tomking is offline   Reply With Quote
The Following User Says Thank You to Tomking For This Useful Post:
Ultramaroon (02-26-2015)
Old 02-26-2015, 01:57 AM   #120
themadscientist
Hotlink Terrorist
themadscientist's Avatar
Drives: 2015 WRB BRZ Spec S
Can the assist be removed to convert to full manual steering?
Old 02-26-2015, 03:01 AM   #121
Ultramaroon
fabulous
Anything's possible but I just flipped through the relevant pages in the service manual and hory sheet, electronically, everything runs through everything else.
BTW, @Sarlacc, tons of trouble codes dedicated to P/S control.
Sarlacc (02-26-2015)
Old 02-26-2015, 03:20 AM   #122
themadscientist
Hotlink Terrorist
Welcome to the modern automobile. Don't forget your car can now be hacked and taken over wirelessly. http://www.detroitnews.com/story/bus...king/23094215/
Think about turning off the TCS, I mean really turning it off. Kind of remind you of a Playstation game?
Old 02-26-2015, 03:31 AM   #123
Ultramaroon
fabulous
In the worst ways. I'd be in nirvana if I could just rip out all that shit.
Without the pedal dance, pushing the throttle is literally asking the computer for permission to go faster. Fuck that noise.
themadscientist (02-26-2015)
Old 02-26-2015, 03:41 AM   #124
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
No, I think YOUR power steering is faulty and it was replaced under warranty.
Mine works fine.
-alex
Old 02-26-2015, 05:39 AM   #125
Tomking
Drives: FT 86
Mine works fine.
-alex
Yes, I am only talking about mine!
Old 02-26-2015, 08:39 AM   #126
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
I disagree. And I'm not very diplomatic :-)
OP says he's in his 50's and have driven lots of cars w/o PS, just like you and me. Granted, a car designed for PS will feel a lot harder than old cars with big wheels and higher gear ratio on the steering, but he should be able to steer with no problem at speed.
Toyota doesn't replace the PS unit and PS ECU just to please a customer, there was obviously something wrong. And this fault caused the steering to almost freeze up, to a degree where OP (a sensible guy in his 50's with lots of driving experience) were not in control of where his car was pointed.
This all suggests there is a possible error condition where the power steering does more than stop working, it actively resists steering.
But I will agree that further debate on the subject is futile. I just hope this is not the way the PS unit fails by design, but rather an isolated issue.
Thanks for sharing your experience, @Tomking.
power steering feel adjustment brillo Engine, Exhaust, Transmission 29 11-06-2017 04:41 PM
power steering ender2664 Engine, Exhaust, Transmission 32 03-21-2015 05:16 PM
Electronic Power Steering Failure tjdiz92 Issues | Warranty | Recalls / TSB 17 06-18-2014 02:34 AM
Electronic power steering Mathewgzlz Issues | Warranty | Recalls / TSB 9 01-22-2014 02:50 AM
Electric power steering madfast Scion FR-S / Toyota 86 GT86 General Forum 33 10-13-2011 11:11 AM
