86WORX
Old 05-15-2015, 11:32 AM   #71
GT86_PRAGUE
Drives: GT86
Originally Posted by HaDDeS View Post
Here it is, mind you this is caught with a very bad phone, and it is outrageously loud due to the full decat , but i'll make sure to get a better capture soon
Is there a dyno or some other information about how much this car gets better after install?
GT86_PRAGUE is offline   Reply With Quote
Old 05-15-2015, 12:24 PM   #72
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
This is one wicked car!
.....new oil pump assembly, and tweak of the pump to insure a stronger pressure.
This is the bit I'm curious about. Can you give some details on what exactly you have done to help with oil pressures?
Thanks!
BatStig is offline   Reply With Quote
Old 05-16-2015, 06:30 PM   #73
HaDDeS
Touge worship
HaDDeS's Avatar
Drives: Forester STi SG9
@GT86_PRAGUE compare to stock , it added 220 hp and 154 Ftlbs of torque at the wheels
On a dynapack here in Japan, a BRZ / SCion Frs / FT86 , stock, generally reads average 145whp, mine is over 366 now ... I know some will just laugh at the numbers, but dynapacks read low, and we don't use correction factors. What is important is to see the power has been more than doubled over stock, and there is a lot of meat left on the bone, but we made the decision not to fry the transmission too fast. Plus, trust me it is already an animal.
So all in all we are above 500hp cranck.
@BatStig first the assembly has been changed for a fresh new one ! full timing timing chain cover integrating the pump, second, you can tweak the gearing of the pump and beef it it up a little bit, and there is some more know how, but that's more of the sorcerers secret.
HaDDeS is offline   Reply With Quote
The Following 3 Users Say Thank You to HaDDeS For This Useful Post:
BatStig (05-17-2015), CxG (08-05-2015), GT86_PRAGUE (05-17-2015)
Old 05-17-2015, 07:29 AM   #74
GT86_PRAGUE
Drives: GT86
Thanks. I didnt mention I was wondering more about gains without supercharger. Any idea?
Old 05-17-2015, 08:11 AM   #75
HaDDeS
Touge worship
HaDDeS's Avatar
The stroker kit, HKS one at least is really aimed towards a supercharged engine, on a N/A setup, gaisn will be marginal, there will be gains, but not more than 25-30hp with the help o the Vcams
For a N/A setup, the toda 2.3 stroker is a far better proposal
The Following User Says Thank You to HaDDeS For This Useful Post:
GT86_PRAGUE (09-04-2015)
Old 05-17-2015, 08:56 PM   #76
troek
troek's Avatar
Drives: 2012 Toyota 86
HKS shows the stroker kit and cams only gaining around 10 hp NA. I would assume that is untuned.
Also, awesome build, im very jealous, if your ever down in the tokyo area, i want a ride!
Old 07-17-2015, 12:11 PM   #77
ChrisD
ChrisD's Avatar
Drives: GT86
Such a well done build, and it looks so nice too!
I've currently got a stage 3 AVO turbo on mine and looking to get a bit more out of it so I'm looking at engine internals now. Someone recommended the HKS 2.1 stroker kit, and it seems like you're pretty happy with it. One thing I'm curious about is the new oil pump and pressure you mentioned. Any more details on that?
Oh and a tuner I spoke to said they haven't seen a need for new valve springs on these cars even at higher power figures but I thought I'd seen a few people on here mention valve float being a problem after boosting these things. Did you replace your valve springs or not?
ChrisD is offline   Reply With Quote
Old 07-19-2016, 05:55 AM   #78
blindfold
Drives: brz
would you mind sharing where did you install your hks oil cooler? I am in process of installing everything and it seems behind the foglight is not an idea location for air to travel pass through the core, thank you.
blindfold is offline   Reply With Quote
Old 01-15-2018, 11:58 AM   #79
lostpanda
You build very nice car. I am using the HKS V3 kit in China, 110mm pulley.
now my full boost almost 0.85 BAR 12psi so I just worry about my engine and what you said about the "tendency" bend.
could you give me a recommend for my car do I need install hks 2.1 now?
lostpanda is offline   Reply With Quote
Japan members....anyone else out there? Chokonen888 ASIA 137 12-01-2022 04:07 AM
need help from Japan... alexmotrix Other Vehicles & General Automotive Discussions 4 05-19-2012 03:52 PM
guy tearing it up in japan in his new 86 :D carbonBLUE FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 25 05-07-2012 10:16 AM
Some stuffs I've got in Japan yajin BRZ First-Gen (2012+) -- General Topics 16 04-12-2012 09:51 AM
So I was in Japan...(PIC HEAVY) solidsnake4119 Scion FR-S / Toyota 86 GT86 General Forum 40 04-03-2012 04:28 PM
