Member's Car Journals Car journals by our members. |
01-20-2015, 08:05 AM | #43 |
Touge worship
Drives: Forester STi SG9
As stated, the BRZ changed a lot last year, biggest updates were the built engine with the help of a HKS stroker kit, and Vcams, we also fitted HKS injectors, and V2 supercharger kit.
For those not familiar with the HKS stroker kit, it is composed of Forged pistons, forged rods, forged crankshaft, everything works together to increase the stroke of the engine, therefor pushing the capacity to 2.1L. The engine is also fitted with HKS Vcams to accommodate the new stroke, and offer a better output as well. We also used HKS 1mm head gasket to lower a litle bit the CR. Aside from that, every single moving part in the engine has been changed. New srpings, valves have been treated, new oil pump assembly, and tweak of the pump to insure a stronger pressure. It was a lot of work, but it was totally worth it ! Here are the HKS parts: The monstruous Crankshaft The intake and exhaust Vcams The Pistons And rods (they are actualy fractured on the pictures gives you and idea of the quality) https://lh3.googleusercontent.com/-H..._Drag_0001.jpg Here is the build process The different elements on the bench Opening and pre-fitement of the rods on the crank The pistons in place: Heads with new springs And short block closed: The process took a month and a half, we had to wait some time to recieve all the new parts, oil pump assembly was the hardest to get. Then everything went back in the shell, and they started to upgrade my V1 HKS superchager with the new pipes, inter-cooler, and we got rid of the restrictor. As we moved everything out, I decided to upgrade all the bushings and mounts (engine, transmition, diff, subframe , rear-subframe) with STi parts After being properly broken-in, we putted the car on the dyno for the final settings, and after more than 30 pulls To explain the results, Dynapack is well known to read low, my car didn't have cancer stock, its just the way it is, what is important is the delta, the progression, and mind you it is just insane. The car is now 366 whp , considering it was dynoed 145 whp stock, and 27 lb/ft (40 kg/m) of torque at the wheels. It is a monster, the chassis mods made it even more focused and precise ... I just adore it, its monstrously good. Sadly, being winter here, I can't really go bonkers, but as soon as the weather will be a litle more forgiving, trust me i'll upload some videos. I really want to thank Chiba-san the boss of SCREEN here in Japan, for the patience, passion, advises he offers me through the development of my car Last edited by HaDDeS; 01-20-2015 at 08:22 AM. |
The Following 30 Users Say Thank You to HaDDeS For This Useful Post: | 10Stars (02-13-2015), 636 (03-26-2015), 93Targa (02-14-2015), akahenry (02-19-2015), botbs (02-23-2015), CAMBAM_6 (05-15-2015), CxG (08-29-2015), DarkSunrise (05-28-2015), Defuser (01-21-2015), DocWalt (01-21-2015), Efferalgan (01-21-2015), GT86_PRAGUE (01-20-2015), JOMO422 (06-15-2015), JS + BRZ (05-09-2015), M-17 (01-23-2015), Metabrz (04-24-2015), new2subaru (01-18-2016), NLSP (01-20-2015), NyC Zn6 (02-19-2015), pcuerpo (11-12-2015), R2RO (01-22-2015), RedReplicant (09-10-2021), SamCruz33 (06-23-2015), Scottemad123 (01-20-2015), Slipstream (01-20-2015), spdfreak (03-26-2015), stoked_on_spool (07-19-2016), TM (01-20-2015), Turbowned (02-13-2015), Turdinator (02-09-2015) |
01-20-2015, 08:16 AM | #44 |
Touge worship
Here is the updated part list of the BRZ:
INTERIOR Prova Steering Wheel Defi CR type Gages for Oil temp, Oil pressure, Boost pressure Defi Advance control Unit Blitz Gage Side panel SCREEN shifter knob HKS OBD link Type FA20 ENGINE ----- HKS 2.1 stroker kit ---- HKS Forged Pistons HKS Forged Rods HKS Forged Crank Shaft HKS Vcams set HKS 1mm Metalic Headgasket Nismo RB26 rod bearings Coated Valves HKS high volume fuel injectors HKS rev2 Supercharger Kit -unrestricted- HKS compressor independant oil cooling system HKS upgraded intercooler HKS oil cooler S type SCREEN Oil catch tank HKS L.A Clutch HKS Flywheel HKS Spark Plugs TWOSYSTEM's custom made baffled Oil pan SCREEN dyno tune with ECUTek RaceRom EXHAUST HKS Spec R EL manifold TOMEI 70mm Over pipe BLITZ 70mm straight pipe HKS High Power Spec L muffler CHASSIS / WHEELS / BRAKES D2 racing spec brakes , 356mm slotted rotors front and rear, 8 pistons front, 4 pistons rear HKS Hypermax SP coilovers -35mm front and rear STi engine bushings STi Steering bushings STi gearbox bushings STi rear subframe mounts STi Differential mounts, and bushings STi control arms and links TWS T-66F Forged wheels, 18*9 front and rear Hankook Ventus RS3-V2 tyres 255/35 R18 front and rear EXTERIOR TOM's LED Tail light Last edited by HaDDeS; 01-20-2015 at 08:51 AM. |
The Following 11 Users Say Thank You to HaDDeS For This Useful Post: |
01-20-2015, 08:34 AM | #46 |
Touge worship
Well, I am not really sure of the price in the USA sorry but with the Vcams probably around $4.500 ...
The Following User Says Thank You to HaDDeS For This Useful Post: | GT86_PRAGUE (01-20-2015) |
01-20-2015, 08:53 AM | #47 |
Drives: Scion FRS
I'm planning on getting the HKS V2 as well, how did you like it with the stock engine? any recommended supporting mods?
great build! one of my favorite cars on here. |
01-20-2015, 09:24 AM | #48 |
Drives: DGM BRZ 6MT
Your BRZ is a MONSTER! Amazing build.
01-20-2015, 10:01 AM | #49 |
Not knocking on the shops that we have here in North America by any means but I just love the culture of passion and workmanship available at tuning garages in Japan.
The Following User Says Thank You to 1Cor10:23 For This Useful Post: | CAMBAM_6 (05-15-2015) |
01-20-2015, 07:57 PM | #50 | |
Touge worship
That said, you have to be careful on stock internals, the stock oil is way to thin to maintain a proper lubrication at high revs / temperatures, and some parts will suffer fast, rod bearings for example. We had a very bad surprise when we opened the block, two of my bearings were ... dead basically, so it was about time. If you go for the HKS kit, don't boost too much (7-8psi max), and you have to install a oil pressure, temp, and boost gauge. If you have the possibility, I would strongly recommend a full build, with forged internals, and revising of the oil pump, baffled pan ... to make sure the engine won't suffer of any form of oil starvation / lack of efficient lubrication. Once boosted, HKS recommends 10w50 grade oil ... anything lower won't be enough. But obviously this way over stock spec of the engine ... on stock internals. Also, under high boost (15 psi and over) , stock rods have a "tendency" to bend, but they were not designed for that ... My BRZ is now getting 15psi of boost at max, and the supercharger is unrestricted. Last edited by HaDDeS; 01-21-2015 at 06:55 AM. |
The Following 7 Users Say Thank You to HaDDeS For This Useful Post: | CAMBAM_6 (05-15-2015), CxG (08-05-2015), Efferalgan (01-21-2015), Flasher (02-01-2015), FRSCanuck (01-21-2015), GT86_PRAGUE (01-21-2015), MVLSCROWNZ (01-22-2015) |
01-21-2015, 08:10 AM | #51 |
Drives: Toyota GT 86
Amazing build! I have a V2 SC with the Delicious tune (still not final) with stock internals though and HKS injectors and 43 mm restrictor. Max boost is 11 psi. Now thinking what oil to use. 10w50 seems a bit too extreme given the stock recommendation 0w20. So I'm choosing between Motul 5w30 and 5w40...
Even now with 0w20 oil I don't see critical oil pressure drop (Defi gauges installed). However, it's winter now with tempratures below zero, so I can't push the car really hard - not enough grip + I have an oil cooler. |
01-21-2015, 08:22 AM | #52 | |
Touge worship
Still, this HKS SC is a wonderfull solution, and if you have a chance I can just really encourage you to go for the Stroker kit + cams, its mental. |
The Following 3 Users Say Thank You to HaDDeS For This Useful Post: |
01-21-2015, 01:06 PM | #53 |
Hooner in training... eh?
Drives: 2013 Scion FRS
Sub'd for a totally unique build! Awesome job
**Dunno what to put here yet... Imagine something witty...** |
01-22-2015, 01:39 AM | #54 |
Touge worship
In my case, it is function over form, anytime, yet I like to have a bit of style ... that's what i tried to achieve here. Not saying its a sleeper, but its certainly not outrageous ... yes yes i know it has yellow calipers, and white wheels
I like the fact it doesn't look at all, as mean as it sounds and goes ... |
01-22-2015, 02:18 AM | #55 |
Drives: 2015 AOZORA EDITION
Awsome build!!!! what do you do in japan anyways?
01-23-2015, 03:00 AM | #56 |
Touge worship
Here is a nice feature of the BRZ from my friends at 9tro
http://www.9tro.com/features/tuned-c...he-blue-rocket |
The Following 6 Users Say Thank You to HaDDeS For This Useful Post: | 93Targa (02-14-2015), CAMBAM_6 (05-15-2015), GT86_PRAGUE (01-23-2015), Metabrz (04-24-2015), new2subaru (01-18-2016), SuperDave (04-10-2015) |
Similar Threads | ||||
Japan members....anyone else out there? | Chokonen888 | ASIA | 137 | 12-01-2022 03:07 AM |
need help from Japan... | alexmotrix | Other Vehicles & General Automotive Discussions | 4 | 05-19-2012 02:52 PM |
guy tearing it up in japan in his new 86 :D | carbonBLUE | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 25 | 05-07-2012 09:16 AM |
Some stuffs I've got in Japan | yajin | BRZ First-Gen (2012+) -- General Topics | 16 | 04-12-2012 08:51 AM |
So I was in Japan...(PIC HEAVY) | solidsnake4119 | Scion FR-S / Toyota 86 GT86 General Forum | 40 | 04-03-2012 03:28 PM |
