#113 |
Drives: White out FRS
[ame="https://www.youtube.com/watch?v=w2fhRgMXve0"]https://www.youtube.com/watch?v=w2fhRgMXve0[/ame]
Instagram: schen_86
3SGE FRS Build Thread: http://www.ft86club.com/forums/showthread.php?t=114039 |
#114 | |
Drives: Q5 + BRZ + M796
I found one you could love. I’m sure that if you destroked the FA20, built and ported the heads, lowered the compression, added a turbo and ran e85 that there would be lots of revs to be had. You can’t really blame Toyota or Subaru for only making a 200hp 7400 rpm motor on a $25k car budget. |
#115 | |
Only happy when it rains.
Drives: series.blue
| The Following User Says Thank You to why? For This Useful Post: | Irace86.2.0 (04-30-2018) |
#116 | |
Anti stance.
That turbo on that engine at 42psi should be making 600whp at half the RPM. I would believe 600 whp at 12,000 rpm at <12psi... |
#117 | |
It may be conservatively tuned considering the uncharted territory too. |
#118 |
Anti stance.
Then my next question is, what's the point?
There are far more proven, arguably more reliable, and cost effective ways to make 600 wheel. |
#119 | |
Ask Synergy why they sell a 12k rpm redline 2.5L V8 that only has 405hp for like $45k. There are far more proven, arguably more reliable, and cost effective ways to make 405 hp. http://www.synergypower.co.nz |
#120 | |
Anti stance.
| The Following User Says Thank You to Tokay444 For This Useful Post: | CxG (05-04-2018) |
#121 |
I would prefer the Synergy motor too, but you noticed I repeated your quote for a reason. The point is that there is a market and an application for motors with these characteristics, kind of similar to a NASCAR vs F1 argument.
Another example would be my Kawi 636 vs my Ducati 796; the Kawi made 130hp and 45tq, the Ducati 90hp and 55tq; the Kawi's rev limiter is 15k and the Duc's is at 8.5k. The Kawi has two extra cylinders, twelve extra valves, but the benefit of those revs is very noticeable and usable. As the video states, the motor has a flat torque curve from 6k on. That is potentially 4k to 6k usable rpms with the same torque output. |
#122 |
Anti stance.
I'm still not impressed.
#123 |
Drives: 2013 FR-S(Traded in) 2018 Toyota 86
Well, 86 swap here I come
#124 |
Drives: Pearl White '13 ZN6
has this swap only been done with the haltech? Has this been done to keep stock gauge cluster and read obd2 ready?
#126 | |
| High beams | DjDATZ | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 09-10-2014 08:49 PM |
| 3000k HID low beams | WolfsFang | Cosmetic Modification (Interior/Exterior/Lighting) | 26 | 08-21-2013 10:41 PM |
| 24 Watt LED DRL/Hi beams! | Ironsquid | Cosmetic Modification (Interior/Exterior/Lighting) | 23 | 05-20-2013 03:45 PM |
| High Beams | DC-FRS | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 01-12-2013 11:44 PM |
| High beams?!?! | gmanculb | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 10-02-2012 05:51 PM |
