86WORX
Old 07-24-2015, 06:18 AM   #71
churchx
churchx's Avatar
Drives: 2014 GT86
canadaRS1.0: not if skills are not there to do it safely enough to not risk oneself, totaling car and even more so - others on roads, and if it's not cheap beater car but instead only one and daily driven at that, of whatever gender owner is. VSC is compromise, but imho not at best limit/level, there should be another intermediate step between it and fully of, or it should be tunable imho.
Old 07-24-2015, 09:06 AM   #72
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Originally Posted by Bergen23 View Post
Well, if he has an AT, sport mode holds gears for longer before up shifting and (apparently) rev match downshifts during hard braking, but that's never happened to me before.
Hahaha!! Your not driving hard enough!! Go out on a back road and give your brakes a good squeeze but not to the point ABS kicks in and it will down shift. Only time its annoying is when a dumb kid runs out infront of you and it downshifts and you look like a ass. However I normally throw it in "manual" and downshift to help slow down before the corner when im driving spirted.
Old 07-24-2015, 10:35 AM   #73
RFB
RFB's Avatar
Drives: FRS
Likewise. However -
After a FULL Eneos flush + replacement, my slush box, for the first time and ever since, auto down shifts and rev matches noticeably and loudly, on sudden braking.
RFB is offline   Reply With Quote
Old 07-24-2015, 02:00 PM   #74
avishenoy1
avishenoy1's Avatar
Drives: 2015 FR-S Release Series 1.0
Hmm, my 2015 FR-S 6AT auto downshifts with rev matching in manual mode every time at around 1500 RPM if I don't do it myself. Also, if you go below 7mph, in 2nd, it auto downshifts to 1st every time unless you're in snow mode.
avishenoy1 is offline   Reply With Quote
Old 07-26-2015, 10:53 AM   #75
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Originally Posted by xjohnx View Post
Pretty sure EcuTek racerom can do this[/MENTION] ?
Yup, we call it "transition control" because it is really designed to alter the power output based on slip percentage. We can then also bias it based on steering angle input which gives you--slip angle (provided you countersteer).
Xero-Limit is offline   Reply With Quote
Old 07-27-2015, 01:30 PM   #76
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
People make it sound like if you turn off the traction control your call will start sliding everywhere.
I have owned the car now for 1 year (don't do winter driving) and I always drive with my traction off on dry days and the car doesn't slide unless i really floor it like a crazy person and even then sometimes it doesn't slide or give out. Maybe because it's a 2015 model.
The only time i turn on VSC is if it's light rain.
If it heavy, then i keep all the traction controls on.
But seriously, on dry days, you can drive with everything off and be fine.
2018 Subaru WRX STI ~ The Weekend Car ~
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
Old 07-27-2015, 05:04 PM   #77
mid_life_crisis
Drives: FR-S 10 #103 AT
What makes it more fun trying to sort this out is that Automatics have two Sport buttons. One for traction and one for aggressive shift points.
Old 07-28-2015, 01:10 AM   #78
churchx
churchx's Avatar
Drives: 2014 GT86
@Mr.Impreza : In dry days, yes, imho safe enough with vsc off. With not deliberately trying drifting/power oversteer, careful driving and being able to correct if needed with countersteering, full tc/vsc off imho is safe enough even in winter and rain.
My point - to still have some safeguards to correct biggest mistakes if one deliberately/intentionally TRIES to drift/oversteer, to not spun out even if mistaken too much, when still learning/when skills are not there on reflex level yet. To have vsc kick in at bigger slip angles then at stock, not having it completely off or interrupting even at very slight slips.
Nice to hear, that it seems to be possible with EcuTek racerom, thanks @xjohnx & @moto-mike . Going to search more info on that, as sounds like something i wished.
The Following User Says Thank You to churchx For This Useful Post:
Mr.Impreza (07-28-2015)
Old 07-29-2015, 01:55 AM   #79
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Originally Posted by mixedjuice View Post
SPORT MODE Activated at all times is the way i like it,
had the care for about a full tank of gas, and ran it with all nannies on.
Now i used the sports mode a bit, and could really feel the playfulness.
That's how I have it as well, except when it's raining. Then I leave all the nannies on.
^GT5 Replay Photo Mode^
Old 07-29-2015, 02:28 AM   #80
phrosty
Nannies aren't there for when driving is easy. They're there for that "oh shit" moment where you've got a too-quick-to-think aggressive correction to make.
You might have a lot of HPDE time and be 100% comfortable with everything off. I'd wager most people, even if they have some notion intellectually of how to keep their car under control, and may have done so under controlled circumstances, will completely fail in an emergency situation.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
The Following 2 Users Say Thank You to phrosty For This Useful Post:
Bergen23 (07-29-2015), Createddeleted (07-29-2015)
Old 07-29-2015, 02:41 PM   #81
mixedjuice
Drives: 2015 BRZ - sold & 2014 Legacy Sport
I live in Alaska where it rains 90% of the year.
I probably have to keep the nannies on at all times, but i like to live on the dangerous side sometimes so i click them off for fun!
mixedjuice is offline   Reply With Quote
Old 07-29-2015, 03:12 PM   #82
Bergen23
Drives: '15 Halo FR-S
In my opinion, no reason to turn the nannies off when driving on public roads. Too many uncontrolled variables that you wouldn't see on a track. I wouldn't want to be cruising along at 50, only to need to slam the brakes and swerve, then spin out because someone pulled out in front of me.
Bergen23 is offline   Reply With Quote
Old 07-30-2015, 02:01 AM   #83
churchx
churchx's Avatar
Drives: 2014 GT86
From my experience even on very wet or icy grip-less roads VSC on gave enough time to correct in even worst conditions. I wouldn't be so sure that absolutely all nannies needs to be on for those 'oh-snap' moments. It still doesn't help much with learning those limits by driver or rather may give wrong reflexes of 'i can keep flooring accel, or swing it too fast, as nannies will cut accel and correct slip anyway'. Yes, switching it off completely will let learn .. but without any safeguards left at all instead of making them more slack.
Old 06-28-2016, 12:43 AM   #84
FX86
i agree it must be a 2015 thing because they changed the suspension and i'm in a automatic ...on dry days i drive in vsc sport and i push the heck out the car through corners and i never feel any of the assists kick in and slow the car down..i'm not even sure how much harder to push it that would require me to turn off trac
maybe downshift to 1st and do a scandinavian flick and floor it or yank on the handbrake ...vsc sports seems to be just right
Search this Thread:
Advanced Search
sport mode... pr086 Scion FR-S / Toyota 86 GT86 General Forum 6 06-01-2012 12:50 PM
Question about VSC and Trac? Liquidsnake Scion FR-S / Toyota 86 GT86 General Forum 1 04-24-2012 12:24 AM
FRS Spread in D Sport Mag GodSays Scion FR-S / Toyota 86 GT86 General Forum 32 01-05-2012 06:13 PM
G-sport FT-86 driving during GT5 dalli FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 12 10-17-2010 04:16 AM
G Sport @ AIMS ft86cbx FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 19 10-13-2010 02:00 AM
