#29 | |
This is why I would think to get grippier tires on the rear and keep the stock tires front. And save some money also.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
| The Following User Says Thank You to stevesnj For This Useful Post: | Sarlacc (02-10-2015) |
#30 | |
Drives: 2015 Scion FR-S (Asphalt)
Anti-dive would do the trick too |
#31 | |
You could swap to shorter travel suspension I guess but on most street cars downward suspension is almost never close to running out of travel. |
#32 |
The Fail Boat
Drives: CWP S.B.
It's a good thing in hands of professional. They call it neutral handling? Since they can induce it when they want to and control the car mid corner. However it's obviously a bad thing if u don't know what you are doing.
| The Following User Says Thank You to chaoskaze For This Useful Post: | strat61caster (02-10-2015) |
#33 |
Drives: 2013 GBS BRZ Limited
I guess this is related to, but opposite from "Snap In Oversteer"?
The way I see it is that "Lift-throttle" oversteer is when lifting off the throttle makes the ass go out the same way it was trying to go out (slight oversteer leads to massive oversteer). "Snap IN Oversteer" is when the ass is trying to go out, and lifting makes the ass come in so quickly that it goes out in the opposite direction. And rapid, repeated interations of this is what we typically call a "tank slapper"? Do I have those terms right? |
#34 |
/dev/null
Drives: Uphill
#35 | |
#36 |
#37 |
Yeh, someone I know got one replaced and I just remember being floored when I heard the price. Just want somewhat softer but stock size.
#38 |
Drives: Supercharged Golf Cart
It is the reason more than half of the wrecked twins have been wrecked...drivers freaking out in a turn and letting off the gas when they should have kept their foot on it.
I spun my moms Mustang GT 25 years ago by doing this... |
| The Following 2 Users Say Thank You to fistpoint For This Useful Post: | sledheadguy (02-11-2015), totopo (02-11-2015) |
#39 |
Car Nut
Drives: BMW 335d, Toyota Echo RS, FRS
I think lift off oversteer being either a good or bad thing really comes down to driver preference. Some people don't like it because it gives them the sense of the being unsettled and unstable and they may lose confidence, other people like it because it may help them rotate the car into the corner without having to resort to other techniques, or they may be trying to have a little bit of fun.
#40 | |
Drives: 2013 Argento
| The Following User Says Thank You to emutcfut For This Useful Post: | strat61caster (02-11-2015) |
#41 | ||
Drives: 370z
here is an example of it: (starts at 12:44) [ame]http://youtu.be/IPQyQgyuNMI?t=12m44s[/ame] just search you-tube for lift off oversteer, you get tons of examples of amateurs spinning at the track. |
#42 |
The Fail Boat
Drives: CWP S.B.
Did someone just linked drift bible?! <3<3<3
| Where to Lift with Two Post Lift? | Don Ivey | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 08-18-2022 09:51 AM |
| Part throttle faster than full throttle | brn12345 | Engine, Exhaust, Transmission | 38 | 10-21-2021 01:20 PM |
| EZCarLift Easy car lift portable super easy car lift | bren5279 | Mechanical Maintenance and Tools | 16 | 09-11-2015 02:57 PM |
| frs oversteer in brz mechanical? | swpbrz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 03-18-2014 10:48 PM |
