#393 |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
My DGM BRZ vid: https://www.youtube.com/watch?v=0OL9OhxexAA
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 |
#394 |
Drives: 10 Series Scion FR-S
What's the eta on this coilovers, everyone seems to be out of stock
#395 |
Drives: 2013 FR-S Hot Lava
#396 |
Drives: Satin White BRZ Limited
Anybody know the total weight of these coilovers? I want to see if these are lighter than oem.
#397 | |
Drives: 2015 FRS Steel (manual)
Springs are all 6k |
#398 |
#399 |
Rear: stock 8.16#, Tein 10.18#
Front: stock 14.73#, Tein 13.95# Fronts are lighter Last edited by stock; 07-03-2016 at 09:09 PM. Reason: Accidentally reversed data, now fixed |
| The Following User Says Thank You to stock For This Useful Post: | shattered_memory (07-03-2016) |
#400 |
Drives: SWP BRZ
hmmm i should sell mine here lol
mine is sitting in basement since didnt have time to install as well as my LCA lol most people went to default setting as manual, my goal is lower 1-1.2 inch and dont want to spend so much time adjusting height while its on car. can anyone share setting? |
#401 |
Drives: MY11 Maxima 350st, MY15 BRZ
Just pulled the trigger on a set of Flex Z's and the EDFC Pro + GPS module this morning, but it's coming the slow way by ship from Japan. Will give impressions once installed. The Tein distributor for AU advised mine is the first twin he heard of going with the top EDFC Pro unit (win).
MY15 CWP A/T BRZ | Leather heated seats | STI CAI filter, A/T leather shifter, strut brace, V-brace, draw stiffener, battery tie down, Radiator cap, Oil cap, push start button | TRD door stabilizer | YoSpeed STI console garnish | Pioneer AVIC-F70DAB + Rev-camera, TS-WX710A sub | JL speakers, Amp | TOMS' Clear Brake Lights | Cusco 4.556 FD | Driveshaft Shop aluminum shaft | Tein FlexZ, EDFC AP+GPS | Crawford BPB
| The Following User Says Thank You to Mim For This Useful Post: | Wayno (08-14-2016) |
#402 |
Drives: Scion FR-S A/T, Whiteout
Question for @CSG Mike or anyone else for that matter:
The topic of swapping for a different spring rate on the Flex Z has been brought up previously, but I was curious if you could provide more insight into what I'm looking to do. The pavement in Seattle proper is absolute garbage, but it's less about potholes and more about weird bumps and deformations all over the place. I'm trying to smooth some of the worst, crashiest crap out of the experience. I've gone up to 11 clicks from stiff with the rebound adjustment, but I don't like the general boaty feel that comes with it. I've noticed that Tein offers 5K springs in their Standardized lineup that have the same free length and inner diameter as the 6K springs that come standard. So my question is, and I know it's subjective, would swapping to a 5K spring rate provide enough of a difference in comfort over bad pavement to be worth the effort? Would the softer springs start bottoming out over large bumps? Will the dampers still be able to do their job effectively when changing the spring rate this much (I'm assuming the optimal damping setting would shift more towards the softer side)? Thanks for looking! |
#403 | |
I do not recommend changing spring rates on *ANY* one way damper, no matter how entry level or high end. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | PantsDants (07-12-2016) |
#404 | |
#405 |
Drives: Brz
Tein Flex Z opinion
Asdd
#406 | |
Drives: 2013 FRS
| Tein Flex A and Z!!! | breadcrumbz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 25 | 05-24-2016 04:44 PM |
| Tein Flex Z | Bigmaxy | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 01-27-2015 04:22 AM |
| WTB - Tein Street Flex and some LCA's | Sugi | Want-To-Buy Requests | 1 | 01-25-2015 04:12 PM |
| 25% Off Tein Street Flex's!!! | RallySport Direct | Brakes, Suspension, Chassis | 0 | 12-31-2014 05:52 PM |
| FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut | kvnchu | Brakes, Suspension, Chassis | 26 | 12-09-2013 02:10 PM |
