Old 10-17-2015, 07:13 PM   #309
Shady195
Drives: '13 10 Series FRS #1203
Originally Posted by Bramick View Post
I get this too.
Just sounds like a light tapping right? It's been driving me nuts lol everything seems spot on but maybe im missing something.
Shady195 is offline   Reply With Quote
Old 10-17-2015, 10:26 PM   #310
HMX-92
Drives: 2015 FR-S Ultramarine
Originally Posted by shiumai View Post
you'll need LCAs to adjust the rear camber. my alignment shop recommends SPL (i have cusco). I just had these installed last week and i'm about 1.25 lower than stock. my rear camber is 1.75°.
Nice Ride btw
Also, I'm probably going to pick up a set of Flex Z's to slap n my car once it comes out of winter mode next spring, take it from your post I should probably get a set of LCA's along with them then? Looked through this thread a bit, and have been talking to a couple people about their experience, was told I shouldn't need to adjust camber, but that sounds like a pretty big camber change on yours. Planning for 1~1&1/4 inch drop
HMX-92 is offline   Reply With Quote
Old 10-18-2015, 05:38 AM   #311
RacerX
Drives: Subaru BRZ
Originally Posted by HMX-92 View Post
Nice Ride btw
I'm in the same spot as you.
For those who have not installed a set of LCAs with these, hows your tire wear? And how much did you drop?
RacerX is offline   Reply With Quote
Old 10-19-2015, 10:13 AM   #312
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Nice Ride btw
many of our cars will end up with uneven rear camber (different on both sides) after lowering. that's what prompted me to get the LCAs. if you're getting coilovers vs. lowering springs, chances are that you're interested in handling. if handling is important to you, then you want to be able to dial in your alignment to suit your driving needs, which you can't do without LCAs.
shiumai is offline   Reply With Quote
The Following User Says Thank You to shiumai For This Useful Post:
Bramick (10-19-2015)
Old 10-20-2015, 04:41 AM   #313
jdiego
Drives: WRX 2015 Subaru BRZ
Is it present at low speed on uneven surface (small bumps but high frequency)?
jdiego is offline   Reply With Quote
Old 10-20-2015, 11:23 AM   #314
shellslinger
Drives: Whiteout FRS
I had this light tapping noise in the back when the coilovers were installed. I had to re-tighten the bolt that connects to the lower arm. Noise went away after that.
shellslinger is offline   Reply With Quote
The Following 2 Users Say Thank You to shellslinger For This Useful Post:
93Targa (10-24-2015), CSG Mike (10-20-2015)
Old 10-20-2015, 02:23 PM   #315
Shady195
I've checked the torque on them both in the air and on the ground but I guess I'll give it another go just to be safe.
Old 10-20-2015, 03:12 PM   #316
shellslinger
Are you using a socket wrench? I used a breaker bar to tighten the bolt
Old 10-20-2015, 03:27 PM   #317
Shady195
A proper torque wrench lol.
The Following User Says Thank You to Shady195 For This Useful Post:
Old 10-20-2015, 08:43 PM   #318
nickg
Drives: 2014 Whiteout FR-S Manual
How do the Flex Z compare to the Fortune Auto 500 for a DD that might see a few track days or autox events per year?
nickg is offline   Reply With Quote
Old 10-21-2015, 06:41 AM   #319
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
What torque specs are you using?
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
Old 10-24-2015, 07:03 PM   #320
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Damping pressure is a bit lacking for "performance driving" but it has compliance like a camry. Easy adjustments and a damn good value. How are these things only $800 a set? Tein and Tomei are kicking some serious asses. Must have something to do with the exchange rates.
Intent > Content
Old 10-24-2015, 07:37 PM   #321
93Targa
Brown rice
93Targa's Avatar
Drives: 93' Supra TT, 13' FRS
I had the light tapping noise in the rear when going over speed bumps. Re-torqued the following bolts and the noise has disappeared for now:
Strut to Control Arm Nut Torque: 59 ft-lb
Hub to Control Arm Nut Torque: 59 ft-lb
Above info taken from DarrenDriven's DIY.
93Targa is offline   Reply With Quote
The Following User Says Thank You to 93Targa For This Useful Post:
shellslinger (10-24-2015)
Old 10-24-2015, 08:10 PM   #322
solidONE
solidONE's Avatar
Those torque specs look a bit low. Particularly the strut to knuckle hardware torque. Were talking about 19mm and 17mm hardware. They can take much more torque than 59 ft lb.
Intent > Content
Tein Flex A and Z!!! breadcrumbz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 05-24-2016 04:44 PM
Tein Flex Z Bigmaxy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-27-2015 04:22 AM
WTB - Tein Street Flex and some LCA's Sugi Want-To-Buy Requests 1 01-25-2015 04:12 PM
25% Off Tein Street Flex's!!! RallySport Direct Brakes, Suspension, Chassis 0 12-31-2014 05:52 PM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 02:10 PM
