Old 02-02-2015, 04:21 PM   #15
markkisl
markkisl's Avatar
Drives: Subaru BRZ - GBS
I've seen this technique used at various detailing places. I tried it out myself and it worked great. Spray down the windshield with some water, then go over it a few times in circular motions with some steel wool. Should take everything right off.
markkisl is offline   Reply With Quote
The Following User Says Thank You to markkisl For This Useful Post:
KelvinBRZ (02-02-2015)
Old 02-02-2015, 04:27 PM   #16
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
Razor blades, extra fine steel wool, and small amounts of paint thinner are my usual methods of cleaning the stuff that regular glass cleaner won't get off.
murdoc is offline   Reply With Quote
The Following User Says Thank You to murdoc For This Useful Post:
Old 02-25-2015, 07:03 AM   #17
SurfAndSand
8SiX
Drives: FRS 10series
Use the least intrusive method possible, and then work your way to the more aggressive cutting stuff. It looks like you were following a cement truck or something. :p
Clay bar, lime away or deposit/acid wash, steel wool, blade, and if all else fails a random orbital buffer, glass pad, and some good cutting creme will take care of it. If not, a replacement windshield isn't crazy expensive. :p
SurfAndSand is offline   Reply With Quote
The Following User Says Thank You to SurfAndSand For This Useful Post:
KelvinBRZ (02-26-2015)
Old 02-25-2015, 01:33 PM   #18
jayhoang
jayhoang's Avatar
Drives: 2014 Scion FRS
You should pick up some glass polish - it gets rid of most of that stuff if used properly with an orbital or some time of machine polisher to break the compound up and fix it. Works similarly to paint polish... In fact, you could probably get away with using paint polish as well.
Glass cleaner or claybars typically don't get that stuff out. They look just like small little pits and stuff from small stones. An aggressive compound can usually take some of it off.
http://www.lifewithjson.com
Instagram: jayhoang
jayhoang is offline   Reply With Quote
The Following User Says Thank You to jayhoang For This Useful Post:
Search this Thread:
Advanced Search
Windshield wipers NMMI89 Cosmetic Modification (Interior/Exterior/Lighting) 34 09-22-2016 12:26 AM
Windshield scratches joshxdodie Issues | Warranty | Recalls / TSB 6 08-17-2014 09:25 PM
Cracked windshield baadshah Issues | Warranty | Recalls / TSB 11 09-17-2013 09:09 PM
Windshield chip Mr.Corvus Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 14 06-20-2013 08:52 PM
Windshield IloveBaldEagles Mid-Atlantic 3 12-05-2012 02:19 AM
