#15 |
Drives: 2013 BRZ limited WRB
I installed my turbo for under 5k. Including tuning and catch can
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
| The Following User Says Thank You to kbogarto For This Useful Post: | CSG Mike (02-02-2015) |
#16 | |
So far, only 2 turbo cars have withstood this challenge, and both of them had significantly more than 5k in their drivetrains. |
#17 |
No it would not. I daily drive my car and it is fine for the street but wouldn't survive a track day. I don't think a 5k budget is enough for any FI 86 for the track. But for a street car it can be done.
#18 |
Dismember
Drives: 2013 Red Scion FR-S
On a hot day, the stock car can't do all that many hot laps without an oil cooler. With a turbo, you need extra, extra, extra cooling, and then your brakes need to be bigger. And you probably need more rubber. And that stock suspension is now looking a bit overwhelmed. Oh, your clutch is gone. Get a new one. Hey, you didn't put in a new fuel system? Are you nuts? Gee, I hope the oil pressure can stay up with all that horsepower. Oh snap! There goes a rod because you drove it like you meant it with 300whp.
If you wanna go to the track and don't want to spend lots, a stock car with upgraded pads, upgraded fluid, a tune, and an oil cooler are all you need. If you want more than that, spend shit loads of money. Now if you want to stay on the street, no problem with a turbo, or at least fewer problems.
#19 |
NASA SpecE30 Racer
When you say "low speed driving" do you mean Hittin The Streets? If so, then a Vortech/JR/Kraftwerks SC might be the right answer. If you instead mean low RPM driving or accelerating at a lower RPM, then turbo is the answer. Those SC kits don't produce max boost until redline where a properly sized turbo can produce max boost in the 3000 RPM range right where you need it. You will get a surge of torque and acceleration with no need to rev it all the way to redline.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following User Says Thank You to King Tut For This Useful Post: | CSG Mike (02-03-2015) |
#20 | ||||
Drives: Searching
all! I believe I replied to most. Or at least those with questions or ones I could answer to.
#21 |
Drives: Honda accord v6 coupe
Its not slow by any means i mean its fast enough to kill you, if you want power get a mustang or like an accord coupe with the v6. The frs/brz is about as fast as a civic or elantra but its handling is great and looks better then either of those 2 cars. Long story short of you want a fast cat, get a faster car from the start
#22 |
Seņor Member
I am so impressed with this forum.
![]() OP, I 100% agree with the majority of people in this thread. If you like the car drive it for a while before laying out any cash on FI. A few of things I have noticed during my ownership: 1. The car will feel slow when new. When you are breaking it in and keeping the revs low it does ok but is far from its best. Also it felt like after the first 6 months it loosened up further so first impressions aren't exactly accurate. 2. The car needs to be driven. It is not one that you can be lazy with. If you want to accelerate change down some gears, above 5k rpm it is a much happier beast. 3. Learn to drive around the torque dip. Unless you get the right header and tune (or go FI) there will be a dip in power between about 3.5k and 4.5k rpm. Use the gears and stay out of this area. Also don't expect much below 2k rpm. 4. Get an E85 tune
1974 TA22 Celica
2013 86 GT |
#23 |
Drives: 2014 BRZ MT (Sold); 2006 V70R
FWIW,
I don't suggest FI w/ a 5k budget. There's way more to just power as others have said (ie rubber, brakes, cooling, dyno time, etc.) This is what I have done in terms of powertrain, and I love it so far. -EcuTek off the shelf tune -Supertek intake tube and panel filter -Complete exhaust system (catted EL header, uncatted front pipe) -Motul and AmsOil fluids That should use up about 3-4k depending on your selection in exhausts. Spend the rest on other things that you'd fancy, such as stereo upgrade, clear bra, cosmetic kits, rear view camera, dashcam, floormats, etc.
'14 BRZ LTD MT DGM
#24 | |
Drives: FRS, Supra, Colorado D, GLC63
What kind of times do you do at laguna or thunderhill in the CSG car? I kind of want you to try that in my own car(there is more then $5k into the car, but not into the engine/turbo kit), but I want to be in the car when it happens. So its not a completely comment,OP, I will say I have done the full N/A bolt on and Forced induction route, I still occasionally regret going FI because of how fun this car is with just bolt ons, tires and good brake pads and how annoying it can be to try and keep these cars cool on the track. |
#25 | |
What's done to your car? I can probably give you an educated guess on the result. |
#26 | |
It has the SBD/Zage turbo kit, 2.5" catless nameless, ceramic coated charge pipes, lava wrapped headers, lava blanket on the turbo, koyo radiator, kate shrouded non-thermostatic oil cooler, ducted bumper and radiator foam, Tein Streetflex coils, Tired RE050a run flats(waiting on rs3's to come into stock), whiteline front sway, STI brembo's on all four corners, Winmax W4's, whiteline bushings everywhere, Southbend clutch, MAP VTA catch cans, and I'm sure I'm forgetting things. 100oct when Im at the track and boost turned down to 9psi. |
#27 | |
I'm 100% sure I can overheat your car based on your mod list; I can't determine in which order the car will overheat though. With 91, coolant and oil is a tossup, depending on cooling and ambient temps. On 100, it'll likely be engine oil first. With E85 and enough power, the trans may come into play. You should come play with us at 86CUP Round 2 at Buttonwillow on Feb 28th ![]() I'm definitely glad to see you guys are open with your setup, unlike some others on the FI subforum |
#28 | |
Btw, I cooked my brakes BAD at Laguna 2 weeks ago on some stop tech pads. I would love to come out there and play with you guys, it's definitely in my head to try and make. I would like to at least show my face at a few 86 cup events this year. I love sharing my setup, as well as our other car(my boss's) running a similar setup but on e85. I'm not a fan of secrecy like these other places, we are out there testing for our own benefit and the customers, and I like my customers to know when sh*t doesn't work! |
| The Following User Says Thank You to The Racers Line For This Useful Post: | CSG Mike (02-04-2015) |
| BRZ holds its own in Auto-X with rookie driver | mtimney | Tracking / Autocross / HPDE / Drifting | 4 | 08-11-2013 01:24 PM |
| Adventures of a rookie in Autocross | djfuller | Tracking / Autocross / HPDE / Drifting | 9 | 04-01-2013 10:30 PM |
| Houston SCCA Autocross Rookie Skool | hankster | Southwest | 3 | 09-26-2012 11:17 PM |
