Old 07-16-2015, 09:09 PM   #15
poolboy54
Drives: Scion FRS. Silver with black badges
Alright. I'm using v2.08 xmls from openflash but nothing's showing up
poolboy54 is offline   Reply With Quote
Old 07-17-2015, 12:51 AM   #16
poolboy54
Nevermind. I figured it out. Thanks!
New question though. I atempted to put my new tune on my car, it started up then died.... Is there a special way to save the tune before installing?
Old 07-18-2015, 03:55 PM   #17
itsjustdavep
itsjustdavep's Avatar
Drives: Asphalt Scion FR-S
Originally Posted by stevo585 View Post
Do you go to the Orlando 86 weekly meets? (on facebook). I'm sure someone there could help you.
I don't. Sadly. Work prohibits lol.
2013 Asphalt HRI Tuned-K&N DropIn-Tomei UEL-Tomei OP-Invidia FP-Nameless Muffled Trackpipe...and corn
itsjustdavep is offline   Reply With Quote
Old 07-18-2015, 07:28 PM   #18
poolboy54
I'm getting "ERROR - Checks failed" box, saying ROM image may corrupt or has been hex edited manually. The checksum can be corrected when the ROM is saved.
Is this normal or should I redownload the defs?
Old 07-18-2015, 11:35 PM   #19
steve99
not all oft tuned roms are checksum corrected so you often get this error when opening.
romraider will correct it or oft\ofm will correct it when you load rom into oft
Old 07-19-2015, 08:24 AM   #20
poolboy54
Thanks, Steve
I'll eventually get this thing working haha
Old 07-23-2015, 07:52 AM   #21
mid_life_crisis
Drives: FR-S 10 #103 AT
Question on right/wrong defs. I'm working with @Wayno defs/tune for A/T cars. When I open the oft tune using the oft def, there are lots of missing tables that he modified. If I use his def for the same tune, the missing tables are there. Is this safe?
Second question. How do you copy and paste tables? I can edit okay, but I can't paste tables or large chunks of values.
Old 07-23-2015, 08:08 PM   #22
steve99
i dont know which defs your using but if they match you rom calid and when you look at some known tables like OL FUEL TABLES and BASE TIMING B and they look ok you should be fine
the oft defs are a bit behind the romraider defs hence the missing tables.
However read the Romraider Tips link below
Old 07-24-2015, 04:47 AM   #23
Kodename47
Kodename47's Avatar
Drives: UK GT86
Due to the OFT definitions being older, I have created a compete set of G series (all based on A01G) and C series (all based on B01C). This is using my newer defs and I've added LC/FFS to them all.
OFT C Series Defs
OFT G Series Defs
I assume that even the old ZA1J700# files are still based on these newer files, correct me if I'm wrong and I'll update the zip files.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 2 Users Say Thank You to Kodename47 For This Useful Post:
H1C (10-04-2017), steve99 (07-24-2015)
Old 07-24-2015, 05:21 AM   #24
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Because you're mixing the OFT defs with mine. None of the tables I modified are missing from my defs because I made them all consistent. The OFT defs have table name inconsistencies between regions and transmission types.
Ensure User Level is 5 Debug Mode
Select Edit > Copy Table
Paste
The Following User Says Thank You to Wayno For This Useful Post:
Old 07-24-2015, 05:49 AM   #25
steve99
OFT C Series Defs
OFT G Series Defs
Thanks
as far as i know all OFT the G series roms 700/900/A00 and even A02G are based on the A01G rom
D00G is actually D00G 2015
700I/900I are acrually A01I
E00I not yet defined does Ecutek have a def ? 2015 auto Europe/australia/SA
700/900/A00/A01/B00 in C series are all B01C
D00C is D00C 2015
Old 07-24-2015, 06:16 AM   #26
Kodename47
Kodename47's Avatar
Drives: UK GT86
I've just made the D series defs in line with my C/G series naming. I've also confirmed that these now include:
Engine Load Limits A + B
Requested Torque Base (DBW)
These are OFT definitions but will also work with normal ZA1JB01D ROMs:
OFT D Series Defs
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-24-2015, 09:09 AM   #27
mid_life_crisis
Paste
I've been set to level 4. Debug options always scare me a little because they often assume the user knows what they are doing and remove all safeties.
The odd thing is that I seem to be able to copy and paste tables that have two axes, but not those with only one.
Well, I just loaded the Wayno-improved tune and the car started, so that's a good sign, but I had to come in and won't drive it for a few hours. I'm having trouble getting datalogging to start, so I'm a little nervous.
I don't care about the startup noise so I ignored those tables. They don't affect anything else, do they?
Old 07-24-2015, 10:12 AM   #28
Kodename47
Kodename47's Avatar
Drives: UK GT86
If its just 2/3 cells then you have to highlight and then copy and paste that way.
Anyway, I have just added a couple of missed tables to the auto definitions and now included I series below:
OFT I Series Defs
This now means that you can compare across any of the 2 biggest markets (US & Euro/Aus/JDM), both Auto and Manual. I have also named the base definition file RR_CALID which means that that definition can be used on any opensource ROM, OFT_CALID are OFT definitions only. That was done to remove any confusion. If you downloaded the zip files before now, please re-download as they have just been updated. These are setup with my own categories, designed to make navigation a little easier.
.: Stealth 86 :.
Kodename 47 DJ:
Using RomRaider to edit tunes ( ROM) files OFT and non- OFT steve99 Software Tuning 56 11-18-2020 09:41 PM
First romraider defs are up jamesm Software Tuning 95 01-13-2015 06:29 AM
need some help with romraider logger toyotaAlex Software Tuning 2 07-06-2014 08:07 PM
romraider/OFTquestion/problem? bkblitzed Software Tuning 10 06-08-2014 03:30 AM
RomRaider XML definitions. wparsons Software Tuning 9 03-25-2014 12:24 PM
