86WORX
Old 08-17-2015, 01:35 PM   #197
JS + BRZ
Drives: 2010 MS3
Originally Posted by N1rve View Post
Try recording it... My sound only came on after the car was hot. It doesn't happen when it's cold.
It also happened when I reved in neutral/park. But under load, the car noises drowns it out so it's hard to listen for it.
I'll try to record it next time I hear. My friend was in the car with me. He noticed it right away too. It would make the sound upon part throttle/full throttle.
I think I posted in here earlier (getting old) but I have heard/felt the hard knock but it only happens at around, IIRC, 3500 RPM. I wonder if it isn't a bubble trapped in the valve timing mechanism. I've only heard it twice and both times it was super hot and immediately following some "spirited" twisties.
Hmm.. mine was making the noise throughout the powerband. But this only happens when I have my A/C on, super hot outside, and during/after the spirited runs.
JS + BRZ is offline   Reply With Quote
Old 08-17-2015, 01:52 PM   #198
Ultramaroon
fabulous
Ultramaroon's Avatar
My wife heard it immediately. Like you, only during partial-to-full throttle.
JS + BRZ (08-17-2015)
Old 08-17-2015, 02:08 PM   #199
JS + BRZ
Drives: 2010 MS3
Yep! No noise when coasting. Not sure what it is.
Old 08-18-2015, 06:43 PM   #200
jflogerzi
jflogerzi's Avatar
The ticking/tapping sound came on again the other day during the canyon run. It was HOT outside around 100. Had my A/C on. The tapping sound was pronounced on throttle and no sound when coasting.
Anyone knows about this? Thank you!
I have this exact same sound! Please if you find out let me know.
Thanks
The Following User Says Thank You to jflogerzi For This Useful Post:
JS + BRZ (08-18-2015)
Old 02-07-2016, 02:59 PM   #201
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Thanks
If its not when ac kicks in, it's a unbalanced or not symmetric rocker arm. Eventually it sticks or clicks wrong and bye bye engine. Could also be a pump issue.
Packofcrows is offline   Reply With Quote
Old 02-07-2016, 04:26 PM   #202
jflogerzi
jflogerzi's Avatar
Well I no longer have the car. Someone else problem now.
Old 02-07-2016, 04:28 PM   #203
Packofcrows
You get a new car?
Old 02-07-2016, 04:52 PM   #204
Ultramaroon
fabulous
Thaaat's the spirit.
Old 02-08-2016, 11:46 PM   #205
pantdino
Drives: Firestorm 2013 FR-S
Sounds suspicious for oil that has gotten too hot and is now too low in viscosity. Perhaps the hydraulic lifters are not staying pumped up. I assume your car does not have an oil temp gauge.
I know we are supposed to run 0W-20 oil regardless of temp or use, but that is illogical, really.
I was running 5W-40 oil in my Abarth in the Los Angeles winter (if you can call it that) but in the summer when the oil got to near 100C the oil pressure at idle was only about 1/2 bar (so about 7psi). So I switched to 5W-50 Castrol. Problem gone.
I suspect if you had an oil temp gauge you would have seen 100 or over *C.
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
pantdino is offline   Reply With Quote
Old 02-08-2016, 11:56 PM   #206
JS + BRZ
Drives: 2010 MS3
I do a lot of canyon runs and track days. Sometimes I see the oil temp go up to 250-260F. I'm running Motul 8100 5W-30.
Old 02-09-2016, 12:14 AM   #207
pantdino
I noted on another thread these engines don't have hydraulic lifters, so that's not what you're hearing
You might want to research online or go to bobistheoilguy.com to see what the viscosity of 5W-30 wt oil is at 260F. If the engine is designed to run on whatever the viscosity is at 212F, you will see how far below that you are at 260.
IIRC the twin-turbo BMW 335i was programmed to go into limp home mode at 260F because the oil cannot lubricate adequately at that temp. Don't know what viscosity that car used.
Old 02-09-2016, 02:09 AM   #208
chas3wba0
chas3wba0's Avatar
Drives: Yes
Mine turned out to be a loose bolt in one of the header flanges. Torqued it down and the noise was gone. It's worth a try.
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 02-09-2016, 09:09 PM   #209
BRZnut
Drives: BRZ DGM Limited
I've noticed the sound similar to what the OP posted on page one (that he found was rocker failure) once or twice but only after car is fully warmed up , with lots of stop and go driving, and when the car is at idle but only when the idle is at its lowest point.(which would be when oil pressure is at its lowest)
Which makes me wonder if this is an oil pressure issue from using the 0w-20 oil and if moving up to 5W-30 would help.
Old 02-12-2016, 08:02 PM   #210
jflogerzi
jflogerzi's Avatar
You get a new car?
Yea a 1999 Alero 4 door car for now.(Free so can't complain) Wife is due in 5 months(first kid) and we will be going on my income only for a while. So I have been saving up as much money as we can while she is still working. Thus the car was an easy choice. I was positive on the car plus lower insurance and no car payment.
Packofcrows (02-12-2016)
Search this Thread:
Advanced Search
loud knocking constant with engine speed whatsmynameagain Issues | Warranty | Recalls / TSB 34 12-09-2014 10:58 PM
2013 scion frs engine scion123 Engine, Exhaust, Bolt-Ons 16 10-13-2014 10:03 PM
Engine knocking after flash Tenchi Software Tuning 10 09-26-2014 12:50 AM
tapping sound coming from engine forgotten93 Issues | Warranty | Recalls / TSB 11 12-23-2013 10:54 PM
Scion FR-S (2013 2.0L) - Cusco Strengthened Engine Mounts ptuning Engine, Exhaust, Bolt-Ons 0 02-04-2013 11:24 AM
