#183 | |
Drives: 2013 ultramarine Scion FR-S
Tracking your car does not void your warranty. |
#184 | |
Drives: 2018 Golf R
/sarcasm I agree with you 100%, but for someone that either doesn't know any better or would've been too frightened to say anything would've just bent to the pressure. I made it perfectly clear after the car was returned to me that they will never see me again and I will recommend no one to their store. And yes, it was very expensive. Below is the parts list: 110011 CYL HD SUBASSY (W/O ALL VLV) 1 SU003-00328 PMP AY-FUEL, H PRS 1 SU003-00342 PIPE AY-FUEL DLVY 1 SU003-00347 GSKT-FUEL PIPE 2 SU003-00290 GSKT-INT MANIF 1 SU003-00316 GSKT-THROT CHMBR 6 00279-0W201-01 OW20 BULK OIL-W 1 SU003-00311 FILTER 1 SU003-00115 HEAD ASSY-CYL LH 1 SU003-00099 GSKT-CYL HEAD, 2 1 SU003-00196 VALVE-INT 2 SU003-00278 ROCKER CP-VALVE 1 SU003-00182 CAMSHAFT CP-INT LH 1 SU003-00182 CAMSHAFT CP-EXH LH 1 SU003-04240 PIVOT-ROCKER ARM 1 SU003-00281 GSKT-ROCKER COVERLH 1 SU003-00282 COVER-VALVE ROC LH 1 SU003-04237 CARR AY-CAMSHAFT 1 SU003-00289 COVER-COLLECTOR 1 SU003-00221 SHIM-VALVE 1 SU003-00220 SHIM-VALVE 1 SU003-00222 SHIM-VALVE 1 00295-00103 FIPG OIL PAN 1 00272-GTBC1 GT SUPER LLC BLUE 002449 ENGINE OIL 11679 WT
Parting out HERE
#185 | |
Drives: 2019 BMW ///M4
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
#186 | |
Sent from my XT1045 using Tapatalk |
| The Following 2 Users Say Thank You to burdickjp For This Useful Post: | civicdrivr (07-21-2015), yo joshman (02-08-2016) |
#187 |
Drives: BRZ DGM Limited
I'd say take them to small claims court to get your money back for the repairs ,and file complaints with the FTC and NHTSA (safecar.gov)
#188 | |
Drives: Scion FR-S
Who supplied you with the letter stating the warranty was voided? |
| The Following User Says Thank You to T182graff For This Useful Post: | civicdrivr (07-21-2015) |
#189 | |
Drives: 2018 Golf R
Sent from my victara using Tapatalk
Parting out HERE
#190 |
Drives: ae86/frs
Its sad to hear such service. Hopefully in the future you dont run into a similar situation. Its hard to make the system work properly when certain individuals either abuse it or simply dont know how to do their jobs.
| The Following 3 Users Say Thank You to yo joshman For This Useful Post: |
#191 |
Drives: Yes
So as far as the expected "ticking" noises in this engine go... is it normal that I only hear it with the engine under load, between 2000-3000 rpm? Could it be an exhaust leak at the manifold?
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
#192 |
Exhaust manifold leak was on my list as well, but it turned out to be a rocker and grenaded the engine.
#193 |
Drives: 2010 MS3
I get this ticking/tapping sound from the engine sometimes when I do HARD driving under very hot weather (+90F). The frequency of the tapping sound goes along with the engine speed too.
It goes away after awhile though. |
#194 |
Drives: 2010 MS3
The ticking/tapping sound came on again the other day during the canyon run. It was HOT outside around 100. Had my A/C on. The tapping sound was pronounced on throttle and no sound when coasting.
Anyone knows about this? Thank you! |
| The Following User Says Thank You to JS + BRZ For This Useful Post: | jflogerzi (08-18-2015) |
#195 | |
It also happened when I reved in neutral/park. But under load, the car noises drowns it out so it's hard to listen for it.
N1rve
#196 |
fabulous
I think I posted in here earlier (getting old) but I have heard/felt the hard knock but it only happens at around, IIRC, 3500 RPM. I wonder if it isn't a bubble trapped in the valve timing mechanism. I've only heard it twice and both times it was super hot and immediately following some "spirited" twisties.
| loud knocking constant with engine speed | whatsmynameagain | Issues | Warranty | Recalls / TSB | 34 | 12-09-2014 10:58 PM |
| 2013 scion frs engine | scion123 | Engine, Exhaust, Bolt-Ons | 16 | 10-13-2014 10:03 PM |
| Engine knocking after flash | Tenchi | Software Tuning | 10 | 09-26-2014 12:50 AM |
| tapping sound coming from engine | forgotten93 | Issues | Warranty | Recalls / TSB | 11 | 12-23-2013 10:54 PM |
| Scion FR-S (2013 2.0L) - Cusco Strengthened Engine Mounts | ptuning | Engine, Exhaust, Bolt-Ons | 0 | 02-04-2013 11:24 AM |
