Old 04-12-2015, 01:30 PM   #155
spatcha88
Drives: 2013 Scion FRS Whiteout
Originally Posted by Low&Slow View Post
Check this out fellas, car is currently in the dealership.
Shit!! Best of luck with that man
spatcha88 is offline   Reply With Quote
Old 04-12-2015, 03:36 PM   #156
Ultramaroon
fabulous
Ultramaroon's Avatar
After listening to this a few times I'm going to make an armchair troubleshooting call of a bent valve. How in the world it fades when driving is beyond me.
Old 04-13-2015, 12:25 AM   #157
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Originally Posted by spatcha88 View Post
I second this. Not to be a ****... But I've had two 350zs one being an 03 coupe and 07 roadster. Never had a single damn issue and those cars were meant to take beatings.. Our frs is a beautiful car but I'm seriously considering selling her due to something always being wrong with these cars!!
I mean if you don't have an issue with your current FRS, I'd just leave it alone and keep it.
Unless you got money to blow...that's a different question.
N1rve
Old 04-13-2015, 05:19 AM   #158
Low&Slow
Low&Slow's Avatar
Drives: 10 Series #845
Originally Posted by Itzed View Post
Ouch! Not good.
Not at all..
Originally Posted by BRZnut View Post
Wow!!!! How many miles? When did it start?? Any engine mods?
If this is referring to me; started at about 36,xxx miles after i put my catless front pipe on, and over pipe. I've found out what the issues were.. (i'lll explain at the end of this message.)
Originally Posted by PWBRZ View Post
That's a fairly loud ticking - have you tried to isolate the location using an engine stethoscope or listening using a long screwdriver?
Yes i have, found out the issue (i'lll explain at the end of this message.)
Originally Posted by 914_WHITE_FRS View Post
DUDE!!! I HAVE THIS SAME ISSUE!!!! My car is a the toyota service now and is about to be tear down tomorrow to find the cause. Toyota will let me know if they are going to claim it or nah
Me too!
Originally Posted by ZZT86 View Post
Codes suggest VVT system abnormality, sounds like a bearing issue though.
i found out the issue from the dealer.
Thank you
It's not a bent valve, So i got word from the dealer that it was from excess silicone that got into the oil. (I had a leak coming from timing cover and cam cover.) I guess the "technician" put too much silicone on the cover which led to excess silicone getting into the oil, clogged an oil line/ oil passage and deprived oil from the left head. Results were scorched cams.. They said they were either going to replace a rocker arm or a new motor, but I do not want their work on this same motor. I paid for a new car hoping for no problems, and whenever i brought the car back, i've always had issues with the car after their "Work". I've taken my car back there 6+ times and I want the new motor. The question now is; do I trust them installing that motor? No.. hopefully i can try to get a new car lol
Low&Slow is offline   Reply With Quote
The Following 3 Users Say Thank You to Low&Slow For This Useful Post:
Tcoat (04-13-2015), Ultramaroon (04-13-2015), ZZT86 (04-13-2015)
Old 04-13-2015, 08:21 AM   #159
ZZT86
ZZT86's Avatar
Drives: BR86
Let Toyota know of your concerns with the dealer & their shoddy work, that may have a positive influence on them to do it properly or you could go elsewhere.
ZZT86 is offline   Reply With Quote
The Following User Says Thank You to ZZT86 For This Useful Post:
Tcoat (04-13-2015)
Old 04-13-2015, 09:40 AM   #160
Itzed
Drives: 2014 BRZ Limited
Makes perfect sense, and this is actually quite a relief that it's not a defect or something prone to repeat in other people's vehicles. A lot to VW turbo owners who used conventional oil had similar clog issues, but it was little white pieces of coked oil that would float around and eventually clog an oil passage.
I've also read on this forum about other "oil starvation" issues. When I owned a Porsche 944, some people had this happen during hard G cornering at autocross events, where the oil would slosh to one side and the pump couldn't pick up enough to keep the flow going. The simple solution was to make sure your oil level was either full, or slightly above full, and that would ensure it didn't happen.
I guess we are all still learning about this new engine, trying to figure things out. I'm hoping to get hundreds of thousands of miles out of mine, so I hope there are no inherent design flaws.
Itzed is offline   Reply With Quote
Old 06-24-2015, 07:17 PM   #161
8ighty6
Drives: WRB BRZ
Experiencing a similar sound.
Skimmed the thread...guess it could be the vacuum pump, rocker arm or contaminated oil. Sigh. Just bought the car used and warranty hasn't transferred yet, so hopefully it's not something that needs immediate attention.
8ighty6 is offline   Reply With Quote
Old 06-24-2015, 09:17 PM   #162
Itzed
I don't hear anything unusual there.
Old 06-24-2015, 09:24 PM   #163
BRZnut
Drives: BRZ DGM Limited
Sounds normal to me too
Old 06-28-2015, 10:40 PM   #164
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
Nothing wrong there, bub. Here comes the hypochondriacs.
AVodka14 is offline   Reply With Quote
Old 06-28-2015, 11:43 PM   #165
yaguphire
Drives: white-out FR-S
i dont hear anything strange. sounds normal.
yaguphire is offline   Reply With Quote
Old 07-06-2015, 11:39 AM   #166
T182graff
Drives: Scion FR-S
Since so many people are starting to have this issue how can we get Scion/Toyota's attention, I had the same issue with my car, on my way to the dealers my car broke down all the oil left the engine. The dealership said they saw that the oil filter was too loose and that was the cause of the engine malfunction, I told them there was a rattling/Knocking sound the day before and I was bringing it up to you guys to take a look. I asked them for the engine codes but they didn't pull them they said they saw the oil filter loose so they didn't investigate any further. They said it won't be covered under my warranty.
T182graff is offline   Reply With Quote
Old 07-06-2015, 12:03 PM   #167
Itzed
What is "This Issue" you refer to? Loose oil filters?
Old 07-06-2015, 12:21 PM   #168
T182graff
Drives: Scion FR-S
The knocking sound that I had the night before and on my way to the dealers. It is similar to this noise.
[ame="https://www.youtube.com/watch?v=jHUuQ-b-25E"]Scion FR-S bad motor noises, lifter noise, no CEL - YouTube[/ame]
Search this Thread:
Advanced Search
loud knocking constant with engine speed whatsmynameagain Issues | Warranty | Recalls / TSB 34 12-09-2014 10:58 PM
2013 scion frs engine scion123 Engine, Exhaust, Bolt-Ons 16 10-13-2014 10:03 PM
Engine knocking after flash Tenchi Software Tuning 10 09-26-2014 12:50 AM
tapping sound coming from engine forgotten93 Issues | Warranty | Recalls / TSB 11 12-23-2013 10:54 PM
Scion FR-S (2013 2.0L) - Cusco Strengthened Engine Mounts ptuning Engine, Exhaust, Bolt-Ons 0 02-04-2013 11:24 AM
