#15 | |
Drives: FRS
110/105 interchange area is straight hood. thats where you see all them stupid ass donuts and skid marks on the freeways from their stupid ass "crenshaw takeover" bs.
| The Following User Says Thank You to 8R6 For This Useful Post: | Tcoat (01-26-2015) |
#16 | |
Needless to say I destroyed a tire and rim!
#17 |
Drives: LS Swapped BRZ
LOL, I feel for you when your in a bad area and don't want to stop... but you drive with the needle pegged in H your going to have a bigger problem (ie cylinder head warpage) more times than not.
Another option for next time is call the police and say your car broke down and your blocking traffic you need a tow truck and assistance immediately. |
#18 |
I got stuck in a ditch with my 240sx one time in the mountains, and the tow truck guys for that area were really lazy and didn't want to come, Cop came out and he called it in and told them they better get their ass up their in 20 minutes or he would fine them... sure enough 15 minutes later they showed up LOL.
#19 |
Did you boil the coolant from the overheat? If so you could have easily warped the heads.
#20 | |
Thupercharged
I always pictured California to be one big episode of Full House, that sounds rough.
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
#21 |
Boosted Noob
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
I bought another belt (Gates - non-racing) but decided to just slip the OEM one back on since I didn't notice any real damage to it. Also, it is a bit of a pain in the ass to replace the accessory belt because I'd have to remove the Kraftwerks /Rotrex blower assembly to get at and remove/replace the belt. I was careful to ensure the belt was seated properly before cranking. But unfortunately immediately after cranking the engine back up, the accessory belt fell off again. Must be a pulley seizing or misalignment issue. Any further thoughts?
#23 |
Shriveled Old Member
Drives: 14 Hot Lava FR-S
Yes. Time to stop guessing and get out the wrenches. That's the only way you're going to get this fixed.
#24 |
Boosted Noob
Found the problem. It wasn't the tensioner. It was this OEM idler pulley. The right most idler pulley in the figure below.
Sent from my iPhone using Tapatalk Last edited by mit_peid; 01-31-2015 at 06:33 PM. |
| The Following User Says Thank You to mit_peid For This Useful Post: | wheelhaus (01-31-2015) |
#25 |
Looks crooked.. Bearing failure? Cross threaded?
#26 |
Boosted Noob
Bad night for the boosted FRS last night...
Yeah it is crooked. I'm guessing it is bearing failure because of the torque/stress from being adjacent to the crank/supercharger adapter. I don't think it'd be a cross threading issue because I was really careful installing the Kraftwerks bracket onto the engine mount (or in this case is also one of the idler pulley holes).
#27 | |
if its only the adapter, then the problem could be something that just happens over time with added stress from the kit/adapter. if its a combination, cusco/perrin/etc. engine mounts might alleviate some of the stress, and maybe it won't happen again. hopefully it doesn't go out again, but if it does, it probably won't be for a while. either way if it does happen again, and is more frequent than bearing failure on non-SC twins, it might be a useful consideration for other owners in terms of additional maintenance. out of curiosity, how many miles/how long have you had your kit?
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
#28 | |
Edit: Motor mounts are a fine upgrade, but no use spending money for the wrong reasons. Last edited by strat61caster; 02-08-2015 at 04:14 AM. |
| TSD night rally thru Westchester, this Sat night, starts in Mt Kisco | TurboMike | NY / NJ / CT / PA | 0 | 11-19-2014 06:22 PM |
| FRS/BRZ Night in the GTA | GYNXxx | CANADA | 15 | 06-20-2014 04:33 PM |
| DRL at night? | arleewa | BRZ First-Gen (2012+) -- General Topics | 17 | 11-26-2013 01:21 AM |
| Mike Vu from MVDesignz will be at Tuesday Night Irvine FR-S/BRZ Meet tomorrow night! | DNAPoPo | Southern California | 1 | 03-11-2013 07:12 PM |
| Coverage of Subaru BRZ Debut at Re-Mix Night at Tokyo Night Club and Music Video | mockngbrd | BRZ First-Gen (2012+) -- General Topics | 36 | 01-04-2012 07:15 PM |
