#155 | |
Hail Magnet
![]() Those look great, thanks for the pictures! |
#156 |
The Stig's African Cousin
Drives: 2014 wrb brz
Here's mine
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386 Flickr: brandonblt567 |
#157 |
Drives: 2013 Firestorm FRS
every color is awesome haha. I almost wanna buy multiple sets and switch them out as I feel like it lol
#158 |
Hail Magnet
So is install fairly straightforward, or are there certain tips or warnings you would give when it comes to removing/installing?
#159 |
Drives: 2015 Subaru BRZ
The install is really easy but there are no instructions with the lights. All you do is pop the trunk take out the three little pins holding the plastic trunk center, remove the carpet spare tire cover and than pull back the carpet lining behind the brake lights by taking more little pins out. You can remove the whole trunk carpet lining to make it even easier but I was too lazy. On the bolts it's hard to get a socket on them so I had to use an open wrench but be careful not to let the nuts fall in to the abyss of the wheel well and make sure the lights are snug. Lastly the wires are held in to the old lights by a clip i broke both of mine which is not suppose to happen but I just zip tied it. There is a YouTube video of how to do it here it is [ame="https://www.youtube.com/watch?v=nuGqKRxEVbE"]Toms Tail light install - Subaru BRZ - YouTube[/ame].
TLDR The install is easy just use an open wrench and be careful with the nuts and clips holding the wires. |
| The Following User Says Thank You to sexyvortex711 For This Useful Post: | HunterGreene (04-30-2015) |
#160 | ||
Hail Magnet
If not, besides a google search, where is a place I could find a replacement relay for a good price? |
#161 |
Drives: 2014 FR-S Whiteout, 2018 BMW M2
No need to do anything with the indicators. Plug 'n play......the indicators will still flash
#162 | ||
No relay is need, as the tail lights have the proper resistors already installed inside. If you do need a relay though(switchbacks etc) a Diode Dynamics relay is always a solid bet(warranty, easy install). Hit up Jurrian @ModBargains.com if you need assistance. @Diode Dynamics |
| The Following User Says Thank You to continuecrushing For This Useful Post: | HunterGreene (04-30-2015) |
#163 |
Drives: Kia Stinger GT2
Hope their new gaskets work as advertised. I have some of the original CRs that turned in to fish bowls (literally over 1.5" of water in the lens overnight) and the condensation just never dissipated, so now I'm back to stock.
Make sure you get them replaced ASAP if you have a problem because they will not after 1yr. 6 months after purchase, passenger side: ![]() 14 months later, driver's side:
#164 |
Drives: 2014 Scion FR-S Monogram
Don't forget the rubber piece behind it. I for some reason didn't realize they should stay on to keep water out. Other than that, it's a really easy install
| The Following User Says Thank You to chubky For This Useful Post: | HunterGreene (04-30-2015) |
#165 | |
Hail Magnet
#166 | |||
Drives: 2015 Series.Blue
The harness holders won't attach to the end of the studs on the new lights (stock studs are threaded all the way to the end, Valenti's aren't). It's not really an issue though as you can use other ways to fix them if needed. The lower reverse light is the hardest part of the install if you end up doing it. Quote:
I will say it's a bit odd how everyone ignored Valenti's post... One only has to look at Valenti's official page to see what versions they make. |
| The Following 2 Users Say Thank You to Poodles For This Useful Post: | HunterGreene (05-01-2015), LED86 (05-07-2015) |
#167 | |
#168 |
Hail Magnet
Funny enough that I have them, but just in case...
(there should be a photo, not sure why it didn't work) |
| Tags |
| lighting, tail light, taillight, valenti |
| Valenti tail light signal light issue | djdnz | Cosmetic Modification (Interior/Exterior/Lighting) | 70 | 12-03-2017 01:49 AM |
| Valenti Bumper Light $179.99 Tail Light $299.99 Fog Light Kit $90.99 | nigel-jdmparts | Exterior Parts - Lighting | 14 | 06-23-2015 07:32 AM |
| Valenti tail light problem | EpidemicFRS | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 12-13-2014 02:47 AM |
| Valenti Tail light on GBS | alpine | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-24-2014 11:16 PM |
| **Valenti Japan LED Tail Light & Rear Bumper Reverse LED Light** | nigel-jdmparts | Exterior Parts - Lighting | 13 | 04-30-2013 01:14 PM |
