86WORX
Old 01-20-2015, 04:06 PM   #57
Originally Posted by ImBatman View Post
Sweet hubs Tcoat! Tell your wife that next time you want the spinners
OHHHHH good idea
Then just some flat black spray paint on the hood, some stickers for parts I don't have and poke some holes in my muffler and I can pretend I am driving a Neon.
ImBatman (01-20-2015)
Old 01-20-2015, 04:25 PM   #58
ImBatman
My Tumbler is an FRS
Drives: exclusively in the fast lane
OHHHHH good idea
ImBatman is offline   Reply With Quote
Old 01-20-2015, 05:36 PM   #59
Zanwald
Drives:
Sounds OK. Price depends a lot on where you are though.
You may already know all this stuff but just in case:
If you look at it in person check the engine cover bolts and see if they are all marked up or there are misplaced washer indents in the cover's tabs. This will let you know if it has been on and off a pile.
Same thing with the exhaust fasteners just look and see if they are beat up. These things can tell you if there were any mods on the car which may have caused some premature wear.
Also ask if the service records show any of the TSBs being done and confirm if the maintenance was done on schedule.
I used to be a body tech so I know how to find any body damage but I'm no expert in the mechanical department. At the risk of sounding like a moron, What exactly are TSBs?
Zanwald is offline   Reply With Quote
Old 01-20-2015, 05:41 PM   #60
strat61caster
strat61caster's Avatar
I didn't know till I started browsing here either: Technical Service Bulletins, they are established solutions to established problems that are model or part unique: leaky taillights (replace, make sure they are torqued to these values otherwise they will crack) idle dip/melting injector seals (reflash to new tune), chirping fuel pump (replace to new fuel pump which won't fix it either) etc.
Old 01-20-2015, 05:52 PM   #61
This!
There is a list of them on this forum but as strange as this may sound I would stay away from it!
Far to often people read the bulletins and then start to think that their car has all those issues (ask me how I know). If you notice something that may be a problem then look it up. To do it before hand will just start messing with your own head.
Old 01-20-2015, 05:54 PM   #62
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
They're all the same, lol I don't see any difference between the 2013-2015. They all drive the same at the end of the day. The only difference are the trims. The Scions have the Monograms and RS 1.0 while the BRZ has the limited and Blue editions.
Alltezza is offline   Reply With Quote
Old 01-20-2015, 06:00 PM   #63
There is a difference between the 13-14 and 15's handling because of the changes but it isn't massive. Other then that ya about the same.
Old 01-20-2015, 06:58 PM   #64
Alltezza
Alltezza's Avatar
Yeah but you wouldn't notice it unless you're pushing it to its limits on a track. The RS 1.0 has the TRD springs on it last time I checked I don't know how much of a difference those make, maybe a little stiffer.
If it was up to me I'd get the 2013 model if I could. It's the same as the newer ones and you should be able to find one for a steal price.
The Following User Says Thank You to Alltezza For This Useful Post:
Zanwald (01-20-2015)
Old 01-20-2015, 07:33 PM   #65
Zanwald
Drives:
That's what I'm doing. Going for dat '13.
The Following User Says Thank You to Zanwald For This Useful Post:
Tcoat (01-20-2015)
Old 01-20-2015, 08:36 PM   #66
You can notice it even with some mid level road driving but like I said it is minimal. Good call on the RS and the TRD spring as they will ride closer to mine which falls in the middle between the stock 13/14s and 15s.
Old 01-20-2015, 08:37 PM   #67
Nice!
Search this Thread:
Advanced Search
One year in....who else?! luscious Scion FR-S / Toyota 86 GT86 General Forum 24 07-17-2013 04:49 PM
One year down, many more to go. FLIPs_FR-S Southeast 1 06-04-2013 03:01 PM
car of the year Vladror AFRICA 12 03-07-2013 03:50 PM
Limited number this year and next year? manonastick AUSTRALIA 4 06-24-2012 07:32 AM
Anticipating year to year changes 86fanatic Scion FR-S / Toyota 86 GT86 General Forum 23 03-14-2012 03:07 PM
