#85 |
Sweeper
damn. someone buy my 4k used primacies from my 2015. Got it in Oct. Have 3 left, because one ran over a nail. Seattle!
#86 |
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
I don't find the limits all that high on the Primacy's - but you're right, I do corner slower in the WRX (wagon) bc it can't take a turn like the Twins. The WRX will understeer at first, and then turn in and be neutral. The Twins you can gas it mid corner and bring the back around. Doing so in the Primacys will make them squeal (even at 20mph, say at a u-turn at an intersection). You try that with AWD and you'll just push outwards. So yeah, I drive differently, but not "slower" per se. (The WRX may see 80mph on an on-ramp with ease, while the BRZ doesn't build speed as fast.)
| The Following User Says Thank You to ashtray For This Useful Post: | EAGLE5 (02-17-2015) |
#87 |
Drives: 84 CJ7, 08 Duramax, 2014 FRS
New tire choices
I'll be finding a stickier set of tires when I wear these OEM Prius tires out. They're nice and greasy when it's wet and that's fun, but when your charging a corner on your commute and it's wet, these tires definitely don't do you any favors, the traction control does.
| The Following User Says Thank You to jeepmor For This Useful Post: | Tcoat (02-19-2015) |
#88 |
Drives: 13 FRS Satin
The only realy problem is the price of these tires. I like the mild grip setup of the car but the tires are more expensive than all the extreme sport summer tires out there. I'm starting to look around at different brands for a similar tire but much lower price. Found some Pirellis and Falkens that are summer eco styled. They seem to be the only ones who make these. I'm just trying to find price and availability now. Going back to school after finding a full time job so I'm gonna have to save.
#89 | |
Drives: FRS-RS1, Triumph Speed Triple, Lola
| The Following User Says Thank You to Caspeed For This Useful Post: | torqdork (03-01-2015) |
#90 |
CAMBAM
Drives: '13 Whiteout FRS
I personally think some of you guys are giving stock tires to much credit...Put them on a car with economy tuned suspension. Our stock suspension plays a huge role, any cheap non grippy skinny tires can probably provide the same "fun" factor
If you think the FRS/BRZ isn't fast enough, the roads you're driving on are too straight.
| The Following User Says Thank You to CAMBAM_6 For This Useful Post: | torqdork (03-01-2015) |
#91 | |
Sweeper
Personal opinions are nice and all, but physics and chemical compounds are more important to discern the performance of a part.. in this case, a tire. they're specifically designed for fuel economy and dry grip. They're actually quite amazing dry compared to everything up to PSS-caliber compounds (< opinion ).In the wet, they tail off FAST due to little surface area to work with. Coefficient of friction works hard against these buggers |
#92 |
Drives: Toyota GT86 Coupe Red (UK)
I went for winters at the start of Feb. Trouble is it warmed up and these particular tyres just don't like warm, damp, salty roads much. If the weather gets worse, they grip like glue, but when it's "Mild" they are unpredictable, they can go from glue to soapy in 100 yards and back again. Makes my mornings interesting, but some of those days I just wish I had my Michelins back on.
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
#93 | |
#94 |
Drives: Asphalt FR-S MT
I would buy the stock tires over and over again!
I just checked my back tires and they look like slicks. Oops
Time to get some new ones soon |
| The Following User Says Thank You to Kronos For This Useful Post: | Tcoat (03-01-2015) |
#95 |
Benched 86lb
Drives: Ultramarine FR-S
Not terribly impressed with the stock tires. More than once on the track, I'd have my instructor tell me that I should be able to push harder, and I'd say, "no, this really is the limit". This would later be verified by the instructor.
They're expensive to replace, and they wore out quite a bit last summer too. I already sold what was left of them in order to force myself to buy new ones. As for enjoying their low limits: nah. I'd rather have high limits. |
#96 |
Sarcastic SOB
I have a second set of almost unused Primacys for when my first set goes. They are stupid expensive to buy new and I can think of several tire models I'd buy new before these ones for the money.
The pros of using the Primacys I can think of are good fuel economy, quiet in a straight line, decent wear life for a summer compound, well matched for playful but not extreme spirited driving. Cons, not the best rain performer, not the absolute best or highest grip limit. If I ever decide to switch to extreme performance tires, no doubt the replacement life will be far shorter. Not sure I want that unless I start doing track days and have them mounted on spare rims. Then, I see a lot of high end track tires get heated up and end up with grazing. A friend who has some track time tells me it wears off with daily driving afterward. So, in Canada we basically have to drop about $1k for a set of PSS that probably wont last too long. Wouldn't care if I didn't have 2 cars on the go.
#97 |
Drives: 2013 Scion FRS 6 Speed Raven Black
The stock tires were fun but sometimes I want grip. Taking a local SoCal canyon road one day (on the stockers) I came up behind a Boxter. We were having a little fun, enjoying the beautiful summer weather and I was playing a little chase. Were weren't racing just driving "spiritedly". It was fun when getting the back end loose but when you want that little extra grip so you can get back on the throttle exiting the corner a little earlier it wasn't there and they were not confidence inspiring at all.
Once I finally bought some new wheels I went to 18s and put on some Federal SS595 in 235/40/18 (purely due to price at the time of purchasing the wheels). The tires have a nice aggressive tread pattern that I liked and on the street they actually gripped awesome. However that is where the good stopped! The response, ride quality, and noise were abysmal! You turned the wheel and the tires had to play catch up. Any little bump in the road and the tires said "The bump wasn't that big but I wanted to make sure you knew it was there!". Took them for one track day and once they heated up, they were pushed and didn't even know what the word traction meant. They followed every groove in the freeway and the noise made me feel like I was on 35" super swampers! Even though I got 20k out of them they were cupped on all four and coming to a stop the car would bounce. Just replaced them yesterday with 245/40/18 Continental Extreme Contact DW's and so far night and day difference! Ride quality is amazing, they grip very well for being a 340 TW but they are a AAA rating. My only complaint is that they are a little round on the sidewall. Even though they are only supposed to be approx. 1/5 of an inch taller than the Federals they replaced they look much taller to me on the car. At this point that is a small price to pay for in my eyes much better all around performance. Still have yet to really put them through their paces though. Since it has been raining. Damn Southern California weather Sorry all of my eastern friends!On a side note, my stock Primacys had quite a bit of life left in them so I sold them to my buddy when he needed some tires for his 2006 Civic Si so he could put it back to stock. He put them on and immediately called me after he left the tire shop and told me he was coming by my house and I had to drive it. Got in and headed down the street. He told me to just gas it in 1st. Mind you at this point the only thing he had on the car still was his intake, headers, motor mounts and a light weight flywheel. I gas it from about 3500 and the tires immediately break loose and cannot find traction. I shift into second, get back on it and again the tires spin effortlessly. I thought it was really funny. Made his car seemed like it had a ton of power. |
| The Following User Says Thank You to ohnoitsthefuzz For This Useful Post: | FRSapex (03-10-2015) |
#98 |
Drives: 2014 Satin White Pearl GTS auto
Since i have an auto, and cannot really hoon the car, I prefer to have fun with grip, andI have easily found the limit of the stock tires under braking and cornering, and the limit is not high at all......
2002 MR2 Spyder 2zz-GE Apexi PFC PPE Race header 8500 RPM of FUN
2014 37J 86 Auto |
| Stock FRS Wheels with New Stock Tires | gbgracer | Wheels and Tires | 2 | 10-05-2014 04:38 AM |
| FS: 2x stock rims with stock tires $120 | retrosmiths | Wheels and Tires | 21 | 04-13-2014 04:20 AM |
| Stay safe in snow 86ers. Don't go out with crap stock tires, only snow tires | stockysnail | Northwest | 36 | 12-19-2013 02:12 PM |
| stock tires on 17 x 9 | andrew5826 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 11-12-2013 12:26 AM |
| FS: Stock Wheels+Stock Tires+TPMS sensor | Pin Flare | Wheels and Tires | 1 | 03-26-2013 12:07 PM |
