Old 05-18-2015, 09:31 AM   #99
churchx
churchx's Avatar
Drives: 2014 GT86
AceHeader-MT: i meant - low gains shown not due dyno (that's very common problem with trying to compare results from different dynos and going just for numbers, not +%), but low gains shown relative on baseline oem stock. Of course, some dynos may show much higher relative to others, but if baseline is done on same dyno and at similar weather (air temp/pressure wise), then relative % gains should be same no matter what dyno is used for both baseline & with header+tune.
And i don't get - why. Maybe baseline is too high for some reason (mixed up with chart from different configuration? Or not stock, but with tune?), maybe something wrong with aftermarked parts installed runs (wrong or no tune? bad install with leaking gaskets?). I fail to see why there is just 172.4 whp stock 176.4 4-2-1(+FP) (+2.3%), 200.3 Nm stock 202.8 4-2-1(+FP) (+1.2%), when for example with custom tunes Nameless or PTuning headers can get from 175 whp baseline to 200 header+tune (+14%).
It's not +5whp vs +25whp, that might be due different dynos, that seems wrong to me. It's +2.3 vs +14% that seems wrong.
And i have no clue for reasons, as i see nothing wrong with how header is designed, it even seems more promising design wise to me then other headers with sharper bends, shorter runner lengths, with collectors of runners at wider angle. Magic
IIRC, even just and only off-the-shelf tune on full-oem-stock can give at least +10whp/+5% on petrol, twice what your header+tune shown. I just don't get what might be wrong. Tune + catted header should give +15whp. Your uncutted one SHOULD be much better :/
LOL, usually some unbelieving customers distrust vendor supplied results being too high .. now it's other way around, with me trying to distrust too low ones
The Following 3 Users Say Thank You to churchx For This Useful Post:
AceHeader-MT (05-18-2015), CSG Mike (05-19-2015), steve99 (05-25-2015)
Old 05-18-2015, 10:04 AM   #100
Teseo
Drives: frs
The combo #4 looks promising, nice work and thanks for the effort.
Where is the sounds clips lol
The Following User Says Thank You to Teseo For This Useful Post:
Old 05-18-2015, 10:26 AM   #101
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by DarkSunrise View Post
Looks like the "USA EL long runner" header makes the most power from 4500-7400 RPM. Would probably be my choice for a track-only car. But gives up a lot of torque under 4500 RPM.
For a daily driver or DD/track mix, the "4-2-1 full 02" seems to be a good compromise.
The 4-2-1 OEFP looks great to me. Less money and it gains significantly down low while only giving up about 5 hp in the mid upper range.
Old 05-18-2015, 10:59 AM   #102
AceHeader-MT
AceHeader-MT's Avatar
Drives: 2012 FR-S
Originally Posted by bur****jp View Post
You mean integrals.
haha, good catch
Yes, for our track car Delicious has given us a specific tune for our set-up which produces smoother torque curves and more power.
For the DD and HPDE drivers this may not happen.
I agree, and we were slightly dis-heartened by the figures, I can tell you most cars with these upgrades (header+tune from anywhere) should produce close to 200hp and higher torque figures...
Thanks, we took some video but with the rolling road sound and massive blower to keep the car cool it was tough to get exhaust sound.
You can check out on-board sounds from the GT car here. Only difference is we have a custom muffler, different from the OE one used for dyno testing: [ame="https://www.youtube.com/watch?v=o5f-fCfZExI"]2015 TSF rd.1 - YouTube[/ame]
We can work on getting good sounds bites next
AceHeader-MT is offline   Reply With Quote
The Following 2 Users Say Thank You to AceHeader-MT For This Useful Post:
Calum (05-18-2015), Teseo (05-18-2015)
Old 05-18-2015, 11:29 AM   #103
churchx
churchx's Avatar
Drives: 2014 GT86
AceHeader-MT: btw, couldn't it be, that dynos were performed right after reflashing, and maybe it's when ECU still relearns fuel trims or something along the lines, thus not showing full results, unlike stock, which, as done prior any reflash/ecu reset/exhaust parts upgrade, ran at full, not throttled back prior dyno runs power? In some tunes for dynoing purposes it might be taken care of, but in some - maybe not, and just maybe that was the reason for lower results? Well, however it be, i don't believe that your header isn't capable of much more, and imho first results by other users of these headers with independently performed tuning should show much better results.
Old 05-19-2015, 01:40 AM   #104
AceHeader-MT
Drives: 2012 FR-S
Could be, the car originally had a specialized stage 2 NA, for this it had the stage 2 NA Flex Fuel (without E85) installed recently... shit.... anyway, at least all systems were tested in the same conditions.
There are a few arriving in the US soon and maybe dyno numbers will be released by them? No promises though
Old 05-19-2015, 01:42 AM   #105
AceHeader-MT
Drives: 2012 FR-S
Here's some photos of the day
The Following User Says Thank You to AceHeader-MT For This Useful Post:
Hyper4mance2k (05-19-2015)
Old 05-19-2015, 01:58 AM   #106
This looks promising. Perhaps the flow is so good that an off the shelf tune wasn't able to keep up?
was the ECU reset between setups and how many pulls were performed for each combination? I understand this is a lot of combos and dyno time is not cheap!
Old 05-19-2015, 02:47 AM   #107
AceHeader-MT
Drives: 2012 FR-S
Hope that's the case
ECU was reset over the weekend. Car drove about 150miles to the dyno on the new tune. Very possible this is the reason as the witchcraft of ECU communication was still being sorted.
We did 2 pulls of each set-up and 3 pulls with the prototype cross system = 15 pulls
(USA x2, 4-2-1 OEFP x2, 4-2-1 ACEFP x2, 4-1 OEFP x2, Cross OEFP x2, Cross ACEFP x3, Full OEM x2)
Combined with the time to swap of each system...it was a long hot day.
Calum (05-19-2015)
Old 05-20-2015, 06:54 AM   #108
AceHeader-MT
Drives: 2012 FR-S
Here's some dyno numbers from Fricke in Sweden. He put these together for us before his opening event at Sweden Time Attack this weekend.
He's running 4-2-1 and a custom 2.5 exhaust with a 200cel catalytic converter and a stuffed muffler for 95dB
Give 'em hell buddy!
Old 05-20-2015, 08:33 AM   #109
churchx
churchx's Avatar
Drives: 2014 GT86
AceHeader-MT: you don't happen to have his baseline header-less stock numbers/dyno results, do you?
Old 05-20-2015, 12:43 PM   #110
AceHeader-MT
Drives: 2012 FR-S
Sorry, we don't. He took these after the 4-2-1 was installed and was nice enough to pass along the data.
Old 05-20-2015, 09:41 PM   #111
Dimman
Kuruma Otaku
Dimman's Avatar
Is USA EL, a Nameless setup?
Because titanium.
Old 05-20-2015, 09:49 PM   #112
DarkSunrise
DarkSunrise's Avatar
That's my guess, but haven't seen confirmation on that.
BTW if you look at CSG's Ace header thread, CSG lists results as tested against a "leading UEL header", but no name given. I think that might be Tomei. They also post a dyno (different car, same dyno) showing results from PTuning's 4-1 header.
2022 BRZ Build
2013 FR-S Build
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 11:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 06:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 09:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 05:12 PM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 11:34 PM
