Old 05-06-2015, 08:54 PM   #85
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by uspspro View Post
Any more info about the contact you are getting? Just wondering if it's something that will be revised, or can be fixed with a hammer
Its been covered. They are happy with the design. The only time they encountered contact was with bad engine mounts.
Disclaimer, I'm just paraphrasing what I remember reading.
Old 05-07-2015, 06:54 AM   #86
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
I remember them saying something about "bad mounts"... but I am just wondering how any 0-3 year old car could have mounts worn that bad. As such, I am wondering if anyone with stock mounts is going to get the contact issues.
uspspro is offline   Reply With Quote
The Following User Says Thank You to uspspro For This Useful Post:
Calum (05-07-2015)
Old 05-12-2015, 07:34 AM   #87
Fricke
Drives: Toyota GT86
I have the ACE 4-2-1 race header whit oem motor mounts, and no problem too report no kontakt on the track ider.
Fricke is offline   Reply With Quote
The Following User Says Thank You to Fricke For This Useful Post:
AceHeader-MT (05-13-2015)
Old 05-12-2015, 07:41 AM   #88
churchx
churchx's Avatar
Drives: 2014 GT86
Fricke: you don't happen to have dyno charts from stock baseline before / with header installed?
Old 05-12-2015, 10:22 AM   #89
Fricke
Drives: Toyota GT86
Unfortunately I have to disappoint you, have not had time to do a before and after comparison, as race season approaching fast . but on Thursday, the car going to be mapped on E85, i can of course post the results here. the most I can say so far is that the header has pickt upp som power in mid range and on top
The Following 2 Users Say Thank You to Fricke For This Useful Post:
AceHeader-MT (05-13-2015), Hyper4mance2k (05-12-2015)
Old 05-12-2015, 10:25 AM   #90
Teseo
Drives: frs
Can you make a sound clips, maybe?
Thanks
Old 05-12-2015, 10:52 AM   #91
churchx
churchx's Avatar
Drives: 2014 GT86
Fricke: it's obvious, that it will bring gains .. but i wished to find out how big gains for it+tune numbers vs stock so to be able to compare with gains brought by other headers
Old 05-18-2015, 02:35 AM   #92
churchx
churchx's Avatar
Drives: 2014 GT86
Hmm, still no numbers by anyone?
Old 05-18-2015, 05:20 AM   #93
AceHeader-MT
AceHeader-MT's Avatar
Drives: 2012 FR-S
Good things to those who wait...
Here we go:
All pulls done with Delicious stage 2 NA
Airaid intake
DimSport Italian rolling-road.
35*C
92% humidity
oil temp 80-90*C (for each pull)
Graph 1- Full OEM stock
Graph 2- USA EL LongRunner and USA matching front pipe
Graph 3- ACE 4-1 with stock Frontpipe
Graph 4- ACE 4-2-1 with stock Frontpipe
Graph 5- ACE 4-2-1 with ACE frontpipe (*frontpipe is built for specific tune)
Graph 6- ACE crossfire concept
Graph 7- ACE crossfire concept with ACE frontpipe
Graph 8- combination chart
Graph 9- combination chart
Results show USA made has highest numbers in both HP and Torque. Ace 4-2-1 has largest area under curve in torque.
ACE Frontpipe works better with custom tuned car.
For stock tune, 4-2-1 and stock frontpipe looks pretty good.
AceHeader-MT is offline   Reply With Quote
The Following 3 Users Say Thank You to AceHeader-MT For This Useful Post:
R2 (05-20-2015), solidONE (05-18-2015), WRB-DZA-BRZ (02-26-2016)
Old 05-18-2015, 06:01 AM   #94
churchx
churchx's Avatar
Drives: 2014 GT86
Big thanks, AceHeader.
Hmm, very interesting. Merged header seems concentrated on middle of the band, and now it's not torque dip, but rather torque hill .
But something seems off. I somewhat expected much-much higher gains with header and ecu tune over stock, as in most catless headers show +20-30whp with tune over tune-less oem stock.
"All pulls done with Delicious stage 2 NA", and stock is "Graph 1- Full OEM stock" <- stock including w/o tune, isn't it? Yet numbers of just +5whp .. it's as if they were done at stock ecu firmware. From what i see in pictures of your headers, both your EL 4-1 & 4-2-1, they both seem seem quality made, with nice large radius bends, shallow angle merge collector, no cat .. there should be nothing to keep them from at very least comparable gains as that for the others if not better.
Your 4-2-1 seems somewhat close to Nameless one, as in both have very long runner lengths, just that formed in different shapes. That Delicious stg2 tune .. might it be some OTS tune? For which header it was made for? Not by chance for stock twins with stock exhaust? Or OEM baseline is also with tune?
P.S.
What is Crossfire concept?
The Following User Says Thank You to churchx For This Useful Post:
AceHeader-MT (05-18-2015)
Old 05-18-2015, 07:53 AM   #95
twag4
Drives: frs
He mentioned all with delicious stage 2 NA tune. Even stock exhaust.
twag4 is offline   Reply With Quote
The Following User Says Thank You to twag4 For This Useful Post:
Old 05-18-2015, 08:19 AM   #96
AceHeader-MT
Drives: 2012 FR-S
P.S.
This dyno has always produced very low figures. What we hope to show is all of these different exhaust systems on the same day, same car, same conditions. I would focus more on the % change and areas under the curves (derivatives) rather then the actual numbers themselves.
We've tested on a Mustang and had this same 4-2-1 system and tune come in above 200hp, so the numbers truly are relative.
The crossfire is an experiment switching the primary's order into the merged collector areas. This is only a one off at the moment as we're still playing around.
We have photos of all the systems and will post shortly
Old 05-18-2015, 08:25 AM   #97
burdickjp
Drives: 2013 ultramarine Scion FR-S
You mean integrals.
burdickjp is offline   Reply With Quote
The Following User Says Thank You to burdickjp For This Useful Post:
Old 05-18-2015, 09:05 AM   #98
DarkSunrise
DarkSunrise's Avatar
Looks like the "USA EL long runner" header makes the most power from 4500-7400 RPM. Would probably be my choice for a track-only car. But gives up a lot of torque under 4500 RPM.
For a daily driver or DD/track mix, the "4-2-1 full 02" seems to be a good compromise.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 11:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 06:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 09:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 05:12 PM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 11:34 PM
