#925 |
Drives: 2015 AOZORA EDITION
#926 |
Drives: 2015 FRS
The OFT and EcuTek through Counterspace Garage and Delicious Tuning has OTS tunes for ACE headers though. I'm currently running OFT with a custom tune with my type B 350 header but when I go flexfuel I'm going to switch over to DT and EcuTek. I don't have personal experience with the OTS tunes yet, but I hear they're solid in the meantime of getting it tuned on a dyno.
Sent from my ONE E1005 using Tapatalk |
#927 |
Drives: 2016 Halo FRS
I got a remote tune from Moto east, was planning on getting a dyno tune through them in 3 weeks... would the dyno tune be worth it? Or can CSG do the same if not better remotely? If so how much would it cost for an revised tune through CSG? Moto east is 6+ hours away, that's why I did a remote tune in the first place. My car is not a DD anymore.... Bought it brand new a year ago and already have over 31,000 miles lol
#928 | |
#929 |
PM sent!
#931 |
Drives: 2013 Red BRZ Limited
Any thoughts/experience on the 350 with OEM front pipe, midpipe & nameless axleback.
#932 | |
Drives: Rb25 neo brz
. Without being biased its obvious we will make more power with your car here on the dyno than a remote tune.
#933 |
Drives: Subaru BRZ SE Lux
I've just had an ACE CS400 fitted to my car, here is the dyno graph. Showing the car before and after.
Green is stock with panel filter Purple is ACE CS400, AVO 2.5" Cat back and panel filter |
#934 | |
Drives: Subaru BRZ
Sent from my SAMSUNG-SM-G900A using Tapatalk
#935 |
Drives: 13 frs red
Peak difference on graph doesn't show 32 hp. Is that pre and post tune?
#936 | |
The spike in the beginning could be a dyno anomaly. |
#937 | |
Drives: Toyota 86 GTS Auto
If green is before, why is there a 164 & a 197 HP written in green a the top? And why both green & purple lines show a 197 HP max?
Toyota 86 GTS A/T, ACE 250/B header + OP, Apexi air filter, Whiteline camber bolts
#938 |
Drives: GT86
Green is before 164hp at the wheels, 197hp at the fly. Both green and purple show a 197hp max as the after figure was no higher than the before but the after has a lot more area under the curve for power and torque apart from at the start which, as stated earlier, is probably a dyno anomaly.
| Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 11:41 PM |
| RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 06:42 PM |
| Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 82 | 04-14-2014 09:16 PM |
| Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 05:12 PM |
| Wanted: UEL header with Perrin header back and tune. | skye67 | Engine, Exhaust, Transmission | 7 | 12-21-2013 11:34 PM |
