#449 |
Probably an uneducated question here but how would a header designed for FI, ie supercharged, be different from the current 4-2-1 EL header with 350/250 overpipe options?
#450 | |
Quick question, can you feel the reduced torque between 350 vs 150 overpipe (7Nm difference). If not the 150 would make a very good deal for the price. Sent from my SM-G920I using Tapatalk |
#451 |
Drives: 2014 GT86
dj2020: header for supercharged FI probably wouldn't differ, any would fit including stock. But for turbo FI, where turbine has to be spun up by exhaust gases thus placed there and probably where runners from all cylinders met?
| The Following User Says Thank You to churchx For This Useful Post: | dj2020 (10-22-2015) |
#452 | |
Drives: BRZ. R34 GT-T
/ SARD / ENKEI / GREDDY / RACESENG / CUSCO / PERRIN / KW / POWERED BY MAX / SPARCO / STOPTECH / BREMBO / ROCKET BUNNY / FULL-RACE twin scroll / OS GIKEN / WHITELINE
| The Following 2 Users Say Thank You to olsonpg For This Useful Post: | NotSoJDM (10-22-2015), Tekno Virus (10-22-2015) |
#453 | |
Forced Induction means more exhaust gases need to be pushed out, a larger volume of fluid over unit time. While it's likely that the gains are minimal, re-evaluating the fluid dynamics will likely yield some benefit as there are a lot of complex effects that can take place in an exhaust, a bad resonance (as exhausts are analyzed as fluids and waves they are analogous to sounds) that is unforeseen if you just slap exhaust X on application Y could be a noticeable detriment to performance (or sound), conversely there might be a desirable characteristic target that isn't hit with their existing products when you push more exhaust through it. Unlocking that extra few percent performance is likely worth it for many people. |
| The Following 4 Users Say Thank You to strat61caster For This Useful Post: |
#454 |
Drives: 2014 BRZ sterling silver
how do you like the 150 spec2, and are you running a tune? I just a greddy supreme SP, and i'm about to order an new open flash tablet. I'm planning on after that getting an ace header but don't know if I wan't the 150 or the 250. If the 150 doesn't rub and it still does well on the street i may go with it.
#455 | |
We've been getting mixed results where some people have zero issues, and others have a slight amount of rubbing. Thing is, all the headers are *identical* so the variation is in the cars, not the header... |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Lord09 (10-23-2015) |
#456 | |
I really like the 150. At the time they weren't offering the overpipes separately so i got the type B header that came standard with the 150. I think down the road I will want to swap it out for the 350 or 250 because I think the low end torque in relation to the high end hp would be better put to use. The differences i'm sure are negligible in the grand scheme of things. Overpipe aside, at the end of the day your getting the best header/op on the market with whichever you choose and the differences between the three overpipes are very small. I think csgmike told me that maybe the 150 is 2-3 more hp in high end rpm range and the 350 is 3-5 more low end torque (somewhere around that range), and then the 250 is kind of a mix of the two. Interested in hearing how the header will pair up with your greddy exhaust. Still brainstorming for a good catback that sounds good with the EL and isn't too loud.
| The Following User Says Thank You to olsonpg For This Useful Post: | CSG Mike (10-23-2015) |
#457 |
Drives: GTS 86
Got some time today to get under the car and adjust couple of things and could not help to take another picture of these header (chrome ceramic coated).
I had to change my clutch as it was slipping like a bar of soap so I couldn't give the car some action, but I managed to do it a bit today! Low end torque is amazing really! It just pulls like a bull!1. 1st, 2nd and 3rd are just too good. Overtaking on highway became a breeze 4th feels a bit better too!2. Sound - here it is a bit subjective and also it depends what the rest of the set up is. I have 2.75 all the way so the sound is different. Catback is Evo 3 (with silencers in) and I love the sound. Sounds like is got a good flow - I know, hard to explain but over 2800-3000 is where you feel and hear the power! Sounds angry and yet easy to get up to speed quickly! So far so good! |
| The Following 7 Users Say Thank You to Hawk77FT For This Useful Post: | AceHeader-MT (10-25-2015), CSG Mike (10-25-2015), jasonc (10-25-2015), Kotu100 (10-26-2015), smg1138 (08-22-2018), solidONE (10-28-2015), Stumpygt86 (10-26-2015) |
#458 |
Drives: 2012 FR-S
Here are some dyno figures from a tuner in the UK. This should be helpful for all those RHD folks out there
Thanks to Abbey Motorsports for the data Test car: Stock 2012 GT86 ACE 4-2-1 250 2nd CAT de-cat pipe cobra exhaust system NO TUNE Graph 1: ACE vs. Stock Graph 2: ACE vs. Japan brand1 4-2-1 Graph 3: ACE vs. Japan brand2 UEL Again, car has no tune. The 250 torque dip can be modified easily with a good tune from Delicious or some of the master tuners we have on the board. |
| The Following 6 Users Say Thank You to AceHeader-MT For This Useful Post: | freerunner (05-20-2016), Hawk77FT (10-28-2015), jasonc (10-28-2015), MaximeT (10-28-2015), sw20kosh (10-28-2015), Tekno Virus (10-28-2015) |
#459 |
Drives: 2012 FR-S
We normally don't like to post quickly and obstruct dyno data.... but we had a visit from Top Speed Insurance (who actually race one of the few Fxx's) and they dropped off a pretty cool car for a new project with us.
Backstory- before there was Ace there was Vintage Speed and Carrera Parts. Don't run away from your roots! @CSGMike get your a** over here and show these guys what to do with this thing! Happy Driving Team Ace |
| The Following 4 Users Say Thank You to AceHeader-MT For This Useful Post: |
#460 |
Drives: frs
Got a tracking number today. Supposed to deliver next Tuesday
#461 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | AceHeader-MT (10-29-2015) |
#462 | |
Drives: FR-S Whiteout
Intent > Content
cowardice is the mother of cruelty. |
| The Following User Says Thank You to solidONE For This Useful Post: | AceHeader-MT (10-29-2015) |
| Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 11:41 PM |
| RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 06:42 PM |
| Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 82 | 04-14-2014 09:16 PM |
| Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 05:12 PM |
| Wanted: UEL header with Perrin header back and tune. | skye67 | Engine, Exhaust, Transmission | 7 | 12-21-2013 11:34 PM |
