#211 |
Drives: GTS 86
My header is down to the ceramic coater! Can't wait to put it on.
#212 |
Drives: 2013 Black FR-S
Flex fuel and ace FP.
#213 |
Drives: MR Spyder/GT86
So the tuned jdl uel made 187whp on E85 and you made 217-223whp on that Same dyno or on Virtual Dyno?
GT86
Current Mods: Ace Header with 350 OP-Berk Frontpipe-Miltek Resonated Catback-OFT-k&n drop in filter |
#214 |
The results here
http://www.ft86club.com/forums/showthread.php?t=88696 would be a better estimate of what you would expect with ace header and E85 which is just over 200hp or about 39hp over stock car on stock car & tune on 91 petrol, if stock car/tune was on 93 petrol would probably make 5 or 6hp more so about 33hp over a stock car on 93 petrol. The ace header really stands out when used with petrol as you can get close to the E85 gains. ie your only about 5 hp down on E85 gains on 91 petrol, be interesting to see what they could get with 93 petrol suspect it would be very close to E85 gains. But if your prepared to run E85 full time you can get very close to the ACE number's on E85 with a less expensive header. Last edited by steve99; 09-04-2015 at 03:32 AM. |
| The Following User Says Thank You to steve99 For This Useful Post: | raven1231 (09-04-2015) |
#215 | |
Even just 245ish whp straight up NA..
#216 |
Drives: FR-S Whiteout
All else stock?! Man... we got to get @juliog on the E85 for a shootout.
Intent > Content
cowardice is the mother of cruelty. |
#217 | |
Ace on 91 made 169. Ace on e85 made 187. Ace on e85 virtual made 220 (baseline was 160).
| The Following User Says Thank You to sw20kosh For This Useful Post: | GT86meMR2 (09-04-2015) |
#218 | |
Also, they achieved a gain of 46.5 whp on e70 in the link you provided. See post # 2
#219 |
True , but they added a front pipe into the equation to achieve that :-)
#220 |
#221 |
#222 |
You did say virtual dyno right?
#223 |
Did you apply all the corrections for baro pressure and ambient temps? You can make it read falsely high if you dont apply the corrections. Otherwise, virtual dyno seems to be very close to what you'd get on a dynojet if done correctly (within 1% error). Also do you have the graphs with and without smoothing? Wheel slip or a non-level surface will also produce a falsely high number (or falsely low if your chugging uphill). You can tell whether if the graph is falsely high by seeing if the graph has unusual spikes in it (along with the datalog if there are rpm spikes in a middle of a pull). If you see this in the graph you need to throw away that piece of data as it's no good.
Intent > Content
#224 |
Drives: 13' Scion FRS Track car
I am curious to see more people switching from JDL UEL to the ACE header and see who much more power can be made...
2013 Scion Frs Track Car - Sold.
| Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 11:41 PM |
| RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 06:42 PM |
| Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 82 | 04-14-2014 09:16 PM |
| Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 05:12 PM |
| Wanted: UEL header with Perrin header back and tune. | skye67 | Engine, Exhaust, Transmission | 7 | 12-21-2013 11:34 PM |
