Addicted
Drives: 2013 Asphalt FR-S 6MT
OEM Audio+ Enclosure squeaking?
I started noticing my sub enclosure with amp is squeaking at freeway speeds. It's barely noticable with the backseats up but with them down and volume off it can be pretty annoying. Tightening the screws seemed to help a little bit but it's definitely still there. Also with extremely high bass (I'm on full profile) and loud volumes it definitely rattles a bit. Anyone else have a similar experience?
Not sure if it's just mine since I took out my amplifier to send it in before; I've definitely tightened them to the max with a t10 but maybe something went wrong. edit: looking more into it, I realized that there might be a part missing from my enclosure causing it to squeak. Was this support piece not included in the earlier batches? Is it even in the later ones?
Drives: FRS
Mayhaps some dynamat?
Addicted
I've tried deadening it, filling the gaps, etc but no good. The amp heats up a good amount and might cause some expansion and contraction softening up any soft materials in contact.
| Windows Squeaking | Froylavin | Issues | Warranty | Recalls / TSB | 164 | 02-24-2018 02:41 PM |
| Audio Equipment Part out! AVH-x4500bt, illusion audio, OEM amp, arc audio and more!!! | CamryDS | Audio/Visual, Electronics, Infotainment, NAV | 25 | 10-23-2015 10:10 AM |
| Alpine audio system upgrade w/ custom sub enclosure | rjm86 | Electronics | Audio | NAV | Infotainment | 11 | 06-24-2014 12:16 AM |
| Squeaking noise | oinkoinkpig | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 12-25-2013 05:26 PM |
| Squeaking windows | bdanisi | Scion FR-S / Toyota 86 GT86 General Forum | 29 | 02-10-2013 11:54 AM |
