Old 12-24-2014, 05:40 PM   #1
PrimeMotoring
PrimeMotoring's Avatar
Drives: FRS with 2jz, 2015 STI 9.68@147
Prime Motoring's 1000whp RB26 + AWD FRS?
This is a project of ours we have kept under wraps since the beginning of October. I loved the way the car turned out. Forward facing kit was super fast to spool, 420whp, lightweight and fun. I was planning on building the FA20 for 700+ and doing a T56 swap but my mind kept swaying.
I hated the uncertainty of the FA20 motor beyond 500hp and also HATED my trans options because I really like the way the stock 6speed shifted and the way the car drove. But I wanted more....way more. So 2jz was decided upon.
The original intentions of this build was for a 1000whp+ 2jz FRS intended for roll racing. My goal was to take the car to Texas 2k15 or Texas Invitational next year and compete, not keep up but compete with fast cars. I knew it would not hang with the lambos and gtr's down there but the ability to scare some other big toys would be great and fun. I purchased the mount kit for the 2jz, the 2jz itself, the v160 etc etc etc.
Until plans changed drastically. Having acquired a fully built 900+whp RB26 and drivetrain someone laughed at the idea of swapping the entire drivetrain including the Attessa AWD system from the Skyline to the FRS. We said "what the hell" lets test fit it in there and see what happens.
Well it fit, and fit surprisingly well. We were in business. I apologize for the crappy pics before hand because this was not intended to be a documented build but as we have gone along, I have noticed more and more people mention the RB thing so I felt pressured to post because we are MUCH further along than the pictures entail.
Test fitment:
This motor is already built to handle 900+ and we fully intend to make over 1000 horsepower. Garrett GT4294r would take care of pushing air. Knowing we would need just a bit more to get to our goals though, the turbo was sent to Forced Performance to be upgraded to their HTA4505 and 76mm Billet Wheel.
Here it is compared to my 6766 and HTA3586 before it was sent out.
HKS GT II 60mm Wastegate came in to help regulate the 40+psi we are planning on running effectively
Axles were made and mocked up before being sent to DSS to get beefed up. Waiting on those to return now. Should have more updates after Christmas.
Before everyone asks how we got the four wheel drive to work. Let me just say it involved A LOT of cutting and welding. The center diff and propshaft require a nice piece of passenger side floor to be trimmed. Subframe had to be boxed out and modified to make the axles clear with enough room to allow them to move when cornering. Custom coilovers were made along with hubs and wheel bearings.
Here you will see the Axles Mounted:
Again sorry for crappy pics. Once everything is back from DSS and also parts from ceramic/powdercoating I will sure to update with better pics.
Everything comes out and cutting/fabbing begins on motor, trans and rear diff mounts. With a custom adapter we were able to make the rear skyline differential bolt right up to the stock rear subframe.
The Axle Exchange in locally in Fairfield NJ made me a custom aluminum driveshaft capable of holding over 1200hp.
We are not using any premade harnesses. We will be completely custom wiring the entire vehicle for the RB26 with AEM V2 ECU. This is from last month though. The new harness is finished and waiting for the motor to be put back in before getting wired up and integrated with the chassis harness.
In terms of the engine bay, we decided to keep everything super clean and simple. No fusebox, brake booster and make sure as much wiring as possible is tucked away.
Also I do not like the fully shaven look of the engine bay but we did fill in some holes and smooth out some things. OEM+ if you will.
That is all I have currently for you guys. Like i mentioned before, these pictures really do not do justice on how far along we actually are with the car and currently just waiting for the axles to be back from DSS as well as all the engine parts to be back from powder/ceramic to assemble accesories back together and show you the complete motor inside the car.
Once that is finished, it is up to fab work. The exhaust manifold is already made but I did not grab a pic before I sent it to powder so again, once I have that back youll be able to see the turbo mounted and how it sits in the engine bay.
Exhaust and wastegate dump will be routed through the driver side fender FYI. More update to follow after the Christmas holiday.
Happy Holidays to you all.
PrimeMotoring is offline   Reply With Quote
The Following 66 Users Say Thank You to PrimeMotoring For This Useful Post:
4Running Daily (12-27-2014), Acree (06-17-2015), acro (12-26-2014), akahenry (12-31-2014), Amaya (12-26-2014), Ammunition (01-29-2016), Bobblehead (12-25-2014), BRZeer (12-30-2014), Captain Insano (03-13-2015), carbonBLUE (01-02-2015), chimera118 (12-26-2014), Choco (01-04-2015), craigpitts7 (01-06-2015), Creole (12-28-2014), CSG Mike (12-26-2014), DAEMANO (12-26-2014), deliroast (01-07-2015), Diode Dynamics (12-26-2014), Draco_PR23 (01-08-2015), Drakiv (05-14-2015), Drift&Drag (12-29-2014), D_Thissen (12-25-2014), Eski (01-30-2015), evan (01-26-2015), feldy (12-30-2014), flippy (12-31-2014), Freshfrs86 (12-31-2014), fx35s (12-26-2014), GT86meMR2 (12-25-2014), Guff (12-31-2014), iSnack0nEmoKidz (02-01-2015), JEFFSTYLE (12-28-2014), Jmonty (12-27-2014), JonAvalon (12-25-2014), Lonewolf (12-24-2014), lukey86 (12-25-2014), Marat (06-13-2016), meWant (12-27-2014), midnight23 (12-25-2014), MidnightRunner (12-25-2014), MisterSheep (05-04-2016), Pat.Thornton (07-07-2015), Pete156 (12-25-2014), Pooverdam (12-29-2014), R2RO (12-24-2014), rcm47 (12-25-2014), Redlinedfrs86 (12-27-2014), rusty959 (12-29-2014), S84kam (11-29-2018), Scalzo (12-29-2014), SciOnDrifTtSlIdeR (12-26-2014), shiro (10-22-2015), Sle (12-25-2014), Sportsguy83 (12-25-2014), tahdizzle (12-24-2014), tigermack (12-29-2014), tinma (12-30-2014), tnle (02-24-2015), TSC19 (12-26-2014), Turbowned (02-01-2015), Ultramaroon (12-26-2014), Valentino (03-28-2015), WallsAndFoundations (12-25-2014), WazzuGrad (01-07-2015), whataboutbob (02-18-2022), zkv476 (12-26-2014)
Old 12-24-2014, 05:58 PM   #2
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Impressive. Now I know there are people with too much time and too much money on their hands.
Keep the good work!
-Jack Burton
Old 12-24-2014, 05:59 PM   #3
zachseidy39
Drives: 2014 base manual Raven FR-S
That's amazing... cant wait to see it all done!
zachseidy39 is offline   Reply With Quote
Old 12-24-2014, 07:52 PM   #4
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
NLSP is offline   Reply With Quote
The Following 5 Users Say Thank You to NLSP For This Useful Post:
akahenry (12-31-2014), cdrazic93 (01-29-2015), evan (01-26-2015), MisterSheep (05-04-2016), WallsAndFoundations (12-25-2014)
Old 12-25-2014, 04:07 AM   #5
Joakim3
Joakim3's Avatar
Drives: 04' Saab 9-5 Aero
Well...... fuck
_____________________
You know what they say... pick two: cheap, fast, reliable.
Joakim3 is offline   Reply With Quote
Old 12-25-2014, 04:12 AM   #6
WallsAndFoundations
WallsAndFoundations's Avatar
Drives:
Subbed. Holy fuck
WallsAndFoundations is offline   Reply With Quote
Old 12-25-2014, 04:51 AM   #7
JonAvalon
SCBYD0
JonAvalon's Avatar
Drives: 18 BRZ (WRB)
Oh my!
JonAvalon is offline   Reply With Quote
Old 12-25-2014, 05:37 AM   #8
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline   Reply With Quote
The Following 3 Users Say Thank You to Floggin Tires For This Useful Post:
Cop (07-01-2015), evan (01-26-2015), SlammedSilly (05-04-2016)
Old 12-25-2014, 12:57 PM   #9
jay1989
Drives: 2014 Subaru BRZ
Well shit u stole my idea lol
jay1989 is offline   Reply With Quote
Old 12-25-2014, 04:28 PM   #10
skye67
skye67's Avatar
Drives: 2013 black AT, OFT, 4.65
OMG!!!!!!
Living the dream in a nightmare.
skye67 is offline   Reply With Quote
Old 12-25-2014, 05:00 PM   #11
MidnightRunner
MidnightRunner's Avatar
Jesus, that's some high level shit. Keep up the good work. Love that blue label too. I'm stuck with red and black.
Sent from my LG-P769 using Tapatalk
There is no great genius without a mixture of madness - Aristotle
MidnightRunner is offline   Reply With Quote
The Following User Says Thank You to MidnightRunner For This Useful Post:
PrimeMotoring (12-25-2014)
Old 12-25-2014, 07:48 PM   #12
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Well I'm still here... havent changed my shitty underwear since last weekend
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
The Following 3 Users Say Thank You to OmarGC For This Useful Post:
Diode Dynamics (12-26-2014), evan (01-26-2015), Guff (12-31-2014)
Old 12-26-2014, 02:30 AM   #13
Drift&Drag
TURBOLICIOUS
Drift&Drag's Avatar
Drives: a machine :]
Nice build man! It will be wicked with AWD! Let me know if you make it to TX2K15. It is definitely going to be interesting this event!
Drift&Drag is offline   Reply With Quote
Old 12-26-2014, 10:02 AM   #14
praneetn7
Drives: 2014 GTS - Pegasus White
HOOORRY SHEEEIIT!!
praneetn7 is offline   Reply With Quote
Anyone had any problems with Prime Motoring Frs300 User/Vendor/Sponsor Reviews, Feedback, Comments 40 01-19-2016 04:08 PM
Prime Motoring Shop Life Thread PrimeMotoring NY / NJ / CT / PA 313 04-19-2015 12:34 PM
Prime Motoring and JR Tuned....NOT the best vgi User/Vendor/Sponsor Reviews, Feedback, Comments 65 07-29-2014 10:46 AM
Prime Motoring and JR Tuned....the best whitefrs User/Vendor/Sponsor Reviews, Feedback, Comments 25 02-12-2014 07:58 PM
Prime Motoring No.1 in customer service satisfaction!!!!! 1RonM3n User/Vendor/Sponsor Reviews, Feedback, Comments 1 11-07-2013 09:54 AM
