#71 |
Hotlink Terrorist
Drives: 2015 WRB BRZ Spec S
| The Following 5 Users Say Thank You to themadscientist For This Useful Post: | Hyper4mance2k (04-26-2015), PWBRZ (02-23-2015), Shit Luck (02-23-2015), Sideways&Smiling (02-23-2015), strat61caster (02-23-2015) |
#72 |
This is a great swap option for the people looking for more power with more reliability! @Speedhead, one thing that still worries me is the stock transmission and the amount of people that have had issues with adding more power. You mentioned there were ways of strengthening it, could you elaborate a bit on this?
| The Following User Says Thank You to fika84 For This Useful Post: | anthros (02-23-2015) |
#73 |
JHerbert Racing
Drives: 2013 Scion FRS
I know what I will be doing when the stock engine blows. Sub'd
#74 | |
Drives: BRZ DIT;VX220 T;'85 Silvia S12 FJ20
![]() On the german board I already started a "wishlist" topic for a potential full gearkit. Will do so here, as I am sure to get more info (already just because of more users total and sure also more guys from teh "got boost" fraction )We are taking a deep look on that topic with our specialist gearbox partner, which also supplies us with the 600 Nm + capability rally gearboxes. |
| The Following User Says Thank You to Speedhead For This Useful Post: | fika84 (02-23-2015) |
#75 | |
Drives: GT86, SQ5, RS3
What ecu is this running? Did Michael use a Motec for the build? |
#76 |
Hi Tim
![]() shhh, canīt tell everything not yet, but no, itīs not a samsonas! and yes, itīs a M142 inside. Plug n Play!!
#77 |
Drives: 2013 Ultramarine FR-S
Sub'd. This looks great, and can't wait to see more
#78 | |
Drives: 2015 Series.Blue
And you apparently think the engine uses forged pistons (it doesn't) There's more power to be had in the D4S injection system than DIT and the DIT has shown it's not as knock resistant as our motor. But believe what you want. |
#79 |
1) Never said anything about forged internals. The forged internals statement was done by another user. 2) Knock resistance is not only about how much ignition advance you can apply. The question at which BMEP levels, you can do so. 3) what hp can you get from the UNmodified D4S system? I guess below 350 hp which is what you can get from the DIT stock system. So I guess you should revise your statement. + I donīt care about the port injection system. can be retrofitted with ease to DIT. The bigger dimesnioned DI system is what makes the sex. => better mixture, higher combustion chamber cooling due to more vaporation enthalpy inside the chamber. 4) and finally... here the proof re block FA20D against DIT. With a few examples (there is more) while it might be the same family, itīs not the same block ![]() additionally the gearbox flange is different. Last edited by Speedhead; 02-23-2015 at 07:57 PM. |
| The Following 4 Users Say Thank You to Speedhead For This Useful Post: |
#80 |
Ok well the M142 is a proper DI ecu so that means you don't need to run the original DI injector controller that comes with the GT86. Also this ecu can run port injection should someone wish to add port injection. Not really sure why they would want to as i've run DI only engines to 860bhp so far.
Gearbox mount different? Ok tell me more
#81 |
Drives: 2014 Subaru BRZ Limited 6smt
Sub'd
Can't wait for some more details |
#82 |
Drives: 2014 BRZ Limited CBS
So many people told me it couldn't be done or it was not worth doing. This is awesome! I can't wait to see more progress.
#83 |
Sweeper
who told you it couldn't be done? This is one of the easier swaps to do given you had the time and resources.....
#84 |
So elite I'm 1338
Drives: WRB Subaru BRZ
Anything can be done if you have $$$$. Most people say it shouldn't be done, just because of the R.O.I. For the amount of $$ you spent on the swap, you could have had a higher HP car (if #s is your thing).
-Jack Burton |
| FA20DIT vs FA20 D4-s? | hmong337 | Forced Induction | 31 | 07-26-2020 03:11 AM |
| *** Feal Suspension, Megan Racing, BC Racing, KSport, ISIS Coilovers - ON SALE!!! *** | Sonic Motor | Brakes, Suspension, Chassis | 489 | 07-29-2016 03:15 PM |
| Convert NA FA20 to FA20DIT in the WRX | SunkenFRS | Forced Induction | 21 | 03-15-2015 09:59 PM |
| FA20DIT parts | glorydays | Forced Induction | 8 | 03-14-2014 06:03 PM |
| FA20DIT vs EJ25 - 2015 WRX and STI get dyno tested | kbye | Other Vehicles & General Automotive Discussions | 7 | 02-27-2014 10:40 AM |
