#43 |
Drives: 2013 frs red
#44 |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Clutch Dog (09-07-2019) |
#45 |
Drives: 2017 BRZ PP , 2005 Saab 97X
Literally
I ignored the instructions and went off a video with some common engineering practises and had no issues with the car. Since then had a modified OFT tune and wow, it really shoves the torque dip down below usable rpm range |
#46 |
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
#47 |
#48 |
#49 |
Drives: 99 mazda miata sport
No the bracket is on. I just took it off and wire brushed the block a little bit and the bracket it's self just a bit to see and it actually stayed on longer and idled better but then it dies after about a minute. I'm going to do it again I guess and clean it up even more but idk what else to do. The bracket I have does seem to be heavily coated in zinc or something. Not sure if that is really a problem or not but but a little with brush helped a little.
#50 |
Found what I believe to be the issue. Sanding down the bracket actually did make it idle much better and longer but still was going up to about 2k rpm then dropping to about 400 rpm and shooting up to 1500 rpm then dying. This time I took out the orange rubber gaskets from the underside of the plastic manifold and there was a decent cunck missing from one. So I just ordered new gaskets and I'll try this again. Really hope that's my problem.
#51 |
mine keeps haveing this issue, but the ignition control unit is bolted down
| OpenFlash Tuning Tutorial: Crawford Billet Power Block Mapping changes | Shiv@Openflash | Software Tuning | 209 | 12-28-2022 10:21 AM |
| Scion FR-S Crawford Performance Turbo/Block Build | newfienorthca | CANADA | 12 | 11-29-2014 11:24 PM |
| BRZ, FR-S, GT86 | Power Block Manifold Riser by Crawford Performance | UP TO 25% OFF! | iA Performance | Groupbuys | 18 | 11-04-2014 05:25 PM |
| Crawford Power Blocks like new | oTaGGeDo | Engine, Exhaust, Bolt-Ons | 0 | 07-27-2014 10:22 AM |
| **Crawford Power Block Install Special -- R/T Tuning -- Call Today** | R/T Tuning | Engine, Exhaust, Bolt-Ons | 3 | 05-21-2014 12:18 PM |
