#29 | |
Check all your wire harness connections. You may have half locked one. Just disconnect and reconnect all of em. Happens a lot more than you think. |
#30 |
Drives: FRS
Figured as much. And I think that is likely what happened. Are there any connections under the manifold I should look at? Or are they all exposed?
#31 |
Hotlink Terrorist
Drives: 2015 WRB BRZ Spec S
#32 |
Drives: 2013 fr-s
Does it stay running if you give it a little bit of throttle?
#33 |
Drives: FRS
#34 | |
Drives: 2017 BRZ
If it's any consolation, I once had the tube between the TB and manifold on a previous car sucked off the TB. It happened in the middle of stop-n-go Chicago rush hour traffic in a construction zone (was a 4" drop to pavement they'd carved off, no shoulder)... I was running a prototype CAI, and we learned something about just how much vacuum the car generates... also, that it's a bad (factory!) design to put a rubber tube between the TB and IM. In hindsight, it was a bad design on that first round of the CAI but ... There's a BRZ FSM CD available for download in the BRZ forum if nothing else, should be the same for your troubles. This is something you're up to solving, it will just take patience, which is really hard to come by when your car has decided to stop working right after you tried to give it a little extra care... FWIW, the smoke suggestion would be motor off. It does not take a lot of pressure to get smoke to show up where it shouldn't. Sometimes no pressure at all. |
| The Following User Says Thank You to cjd For This Useful Post: | wootwoot (12-13-2014) |
#35 |
Drives: 2015 Scion FR-S 6MT
It is not a vacuum leak, if it was it would have to very large and therefore obvious. It's going to be a sensor or wire that is damaged or not connected. Check the throttle connection and wires, then MAF/MAP sensors and associated wires. Also check the pins in the connectors, sometimes they get damaged when disconnecting/connecting them.
| The Following User Says Thank You to Amaya For This Useful Post: | wootwoot (12-13-2014) |
#36 | |
The last guy with similar problem had a mouse chew throgh his airfilter and bits of filter got stuck in MAF sensor in intake tube causing car to stall after start. |
| The Following User Says Thank You to steve99 For This Useful Post: | wootwoot (12-13-2014) |
#37 |
Drives: FRS
Success. Read first post.
#38 |
#39 |
Stig's dark passenger
Did you call the fire department?
#40 |
Drives: 2012 86
Agree with bolded part. Been reading up on BPBs since they were released, but still hesitant to buy them as their instructions don't give me any confidence in doing the installation myself.
#41 |
Drives: FRS
Ya. I will likely make a new thread this weekend outlining some tips for the install as I just got done with it. There is a lot that can go wrong with this one...
#42 |
Drives: 99 mazda miata sport
Having this exact problem but I have triple checked everything including the grounding bracket. Any other thoughts?
| OpenFlash Tuning Tutorial: Crawford Billet Power Block Mapping changes | Shiv@Openflash | Software Tuning | 209 | 12-28-2022 10:21 AM |
| Scion FR-S Crawford Performance Turbo/Block Build | newfienorthca | CANADA | 12 | 11-29-2014 11:24 PM |
| BRZ, FR-S, GT86 | Power Block Manifold Riser by Crawford Performance | UP TO 25% OFF! | iA Performance | Groupbuys | 18 | 11-04-2014 05:25 PM |
| Crawford Power Blocks like new | oTaGGeDo | Engine, Exhaust, Bolt-Ons | 0 | 07-27-2014 10:22 AM |
| **Crawford Power Block Install Special -- R/T Tuning -- Call Today** | R/T Tuning | Engine, Exhaust, Bolt-Ons | 3 | 05-21-2014 12:18 PM |
