Old 12-13-2014, 03:32 PM   #15
xwd
No CEL or anything?
Old 12-13-2014, 03:34 PM   #16
wootwoot
Drives: FRS
No. If I plug in a code reader after it dies it doesn't read anything.
wootwoot is offline   Reply With Quote
Old 12-13-2014, 04:18 PM   #17
cjd
cjd's Avatar
Drives: 2017 BRZ
Grab the FSM and start going through step by step - start with a read through. If you're lucky, you may identify something you may have forgotten without pulling everything apart again. Otherwise...
Old 12-13-2014, 04:45 PM   #18
wootwoot
Drives: FRS
Where can I find a copy of the FSM?
Old 12-13-2014, 04:53 PM   #19
D K
Stig's dark passenger
Originally Posted by wootwoot View Post
Where? Which side? Where does it go?
For sure, set them on fire.
D K is offline   Reply With Quote
Old 12-13-2014, 05:18 PM   #20
Calum
That Guy
Drives: 2013 asphalt FRS MT
Car revs to 2k and then dies. The passenger side intake valves closest to the front of the car look dirtier than the rest of the valves. I didn't disconnect any electrical plugs. I did have to pull up hard on the manifold on the drivers side to get the blocks in. If I start the car and give it some gas it has no effect. That's all I can think of...
What were you pulling against?
After it dies did you try to restart or just start looking for a problem.
Old 12-13-2014, 05:18 PM   #21
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Get a smoker to blow smoke all around the intake system and look for vacuum leaks
Sleepless is offline   Reply With Quote
Old 12-13-2014, 05:28 PM   #22
wootwoot
Drives: FRS
Started looking for a problem after it didn't start.
Lifting up on the intake manifold closest to the driver side headlight. That was where I put the most pressure I would think. I wasn't on top of the car like a silver back, but I had to get the manifold elevated.
Old 12-13-2014, 05:31 PM   #23
wootwoot
Drives: FRS
If the car won't stay running will this still work? It only runs for two seconds...
Old 12-13-2014, 05:34 PM   #24
wootwoot
Drives: FRS
I think when I get home I will pull the manifold again. Pull out the manifold gaskets to make sure they are ok. Double check all my electrical connections once again. Double check my vac lines. And then try it once more. If it doesn't start its off to the mechanic. The only possibility left would be a damaged wire or sensor and I don't think I can hunt that down on my own. Out of ideas...
Old 12-13-2014, 06:00 PM   #25
connorlug
Drives: #1553 10 Series FRS
Drop anything in the motor?
connorlug is offline   Reply With Quote
Old 12-13-2014, 06:05 PM   #26
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Forgot to connect MAP sensor?
Old 12-13-2014, 06:05 PM   #27
wootwoot
Drives: FRS
I hope not. I am missing one of the power block gaskets. But I think that is too big to fall in the motor.... It's likely on the floor someplace.
If I did have something in the block, what would the car do? I confirmed nothing was in the intake valves visually after it didn't start the first time.
Old 12-13-2014, 06:27 PM   #28
wootwoot
Drives: FRS
It's connected. But I will double check the wires.
The Following User Says Thank You to wootwoot For This Useful Post:
Sportsguy83 (12-14-2014)
OpenFlash Tuning Tutorial: Crawford Billet Power Block Mapping changes Shiv@Openflash Software Tuning 209 12-28-2022 10:21 AM
Scion FR-S Crawford Performance Turbo/Block Build newfienorthca CANADA 12 11-29-2014 11:24 PM
BRZ, FR-S, GT86 | Power Block Manifold Riser by Crawford Performance | UP TO 25% OFF! iA Performance Groupbuys 18 11-04-2014 05:25 PM
Crawford Power Blocks like new oTaGGeDo Engine, Exhaust, Bolt-Ons 0 07-27-2014 10:22 AM
**Crawford Power Block Install Special -- R/T Tuning -- Call Today** R/T Tuning Engine, Exhaust, Bolt-Ons 3 05-21-2014 12:18 PM
