#15 |
The Stig's African Cousin
Drives: 2014 wrb brz
#16 |
A.K.A. Starlord
Drives: 2015 Series.Blue
I'm an Aerospace Engineer (at least, that's my degree) and so I shall settle this debate once and for all:
Microwave. |
| The Following 2 Users Say Thank You to Stang70Fastback For This Useful Post: | brandonblt2 (12-11-2014), SkAsphalt (12-11-2014) |
#17 | |
I Love custom Turbo kits
Drives: Limited BRZ
Sent from my SM-N900A using Tapatalk
#18 |
rpf1? do it!
It makes everything more efficient. Brakes, Suspension, Acceleration, etc. 18x9.5 is much wheel. go 17x9 for racecar because racecar. If you are near the limit with your current setup I would say its worth the money. Otherwise I would say spend money on consumables/track time/ stuff you don't have. There is a reason why almost everyone runs 17's, even 17x8 or 17x8.5. And many run 225/45-17 instead of 245/40-17, car benefits more from acceleration(which it lacks) and nimbleness over outright grip. Tires are also lighter in smaller sizes. maybe a tenth or two per lap. |
#19 | |
Drives: Limited BRZ
I hate having the same wheels everyone has.... I am looking at TWS T66-F which are even lighter than RPF1s. But, they have two downsides. One more expensive than my current wheels, second, uglier than my current wheels. That's why I'm trying to gauge real actual quantifiable benefit of them. ![]() Sent from my SM-N900A using Tapatalk
#20 |
rpf1's. DO EEEET. ONE OF US> ONE OF US.
seriously though, .1 up to maybe .2 per lap. +slightly faster with 17's. And tires are much cheaper, meaning you can get a better compound which is more important than the weight imo. Your car is pretty built. I would suggest a lsd and maybe some aero instead. |
| The Following User Says Thank You to swarb For This Useful Post: | Sportsguy83 (12-11-2014) |
#21 | |
Drives: Limited BRZ
![]() The benefits I'm thinking about are, acceleration, specifically before the turbo spools up. The response from the car on initial WOT, and cutting down spool up time. Once I hit full boost, the wheel weight don't matter much. The transition phase when its spooling up is when I think these lighter wheels could make a big difference acceleration and response performance wise.
#22 |
Drives: '23 BRZ Limited
In the real world, it's not that big of a deal.
Grassroots Motorsports did a test on this in a past issue using a Miata (even lighter and more sensitive to wheel weight) and the changes didn't amount to anything more than statistical noise. In other words, don't worry about it. It's just bench racing. |
| The Following 4 Users Say Thank You to OkieSnuffBox For This Useful Post: |
#23 |
I hear ya on this.
Have a look at the PF01. They are much better looking than the RPF1 and according to Enkei site they are also stronger so should handle track abuse better. They are a little more expensive, which means you don't see many around. Depending on the size you are looking at they are only marginally heavier than the RPF1. |
| The Following 2 Users Say Thank You to jvincent For This Useful Post: | Campo (12-12-2014), Sportsguy83 (12-11-2014) |
#24 |
Drives: BRZ SWP Limited -6MT
#25 |
Drives: 2014 BRZ Limited
#26 | |
| The Following User Says Thank You to brandonblt2 For This Useful Post: | Sportsguy83 (12-11-2014) |
#27 |
Drives: Limited BRZ
There was a good thread going for this already but I just found it today.. ooopps....
http://www.ft86club.com/forums/showthread.php?t=32858
#28 |
Drives: Whiteout 6Sp FR-S
If I remember correctly its also harder to slow down the weight at the end then at the center. Hmmm ...
| Should I dyno tests after installing lighter wheels? | makesdrivingfunagain | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 25 | 06-10-2014 05:17 PM |
| Five Axis S5:F wheels "GUN METAL" on a lighter color FR-S or BRZ? | OICU812 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 0 | 03-30-2013 11:38 PM |
| Increased whp by having lighter wheels | mechaghost | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 26 | 07-03-2012 01:46 AM |
| What return from going with lighter wheels? | bazguitarman | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 30 | 06-01-2012 10:35 AM |
| Is it wise to buy an all-new model car when it first comes out? | Raiden | Scion FR-S / Toyota 86 GT86 General Forum | 39 | 01-29-2011 11:57 AM |
