#267 |
Drives: 13' Scion FRS Track car
I drove my car without the brake booster connected to see if that would help brake modulation ... forget it, the pedal becomes so hard it is dangerous to drive.
After a few lap at the track the skin under my feet was bruised. You can remove the brake booster but might as well remove all 4 brake caliper, rotors, abs system and simply use the handbrake to stop, that might actually be more effective than without the brake booster
2013 Scion Frs Track Car - Sold.
| The Following 2 Users Say Thank You to philooo For This Useful Post: | juliog (08-09-2015), nickmerronesucks (05-02-2016) |
#268 |
Drives: 2015 brz
lol
#269 |
Curious cat.
Drives: 86 GT base M/T - Red
Has anyone tried emptying or removing the the washer fluid bottle up front?
My searching indicates that the capacity of that thing is 4 gallons or so, which works out to roughly 8lbs or so of water weight sitting right on the nose of the car. Am thinking of getting the PTuning reservoir to shave that down a bit...or I suppose I could just empty the thing.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold) 1991 Mazda MX5 Miata (sold) 2007 Mitsubishi Evo 9 RS (sold) 2006 VW Golf R32 (sold) |
#270 |
Curious cat.
I'm a huge fan of weight savings.
I've done a basic amount of weight saving already but am curious what else I can do. There are a few key considerations I need to keep in mind though: • I need to keep my car daily driveable and girlfriend friendly (so hardcore stripping is out) • Cost/benefit is important. I'm willing to spend a bit but I'm not willing to waste money. • My key interest is overall performance so I'm curious how weight reduction compares to FI/power adding. For this I decided to look at power/weight as a metric. So I went full nerd. First off, my currrent and possible/planned weight savings: ![]() Second, I expanded on the power to weight charts that @hamzam did. I added a few new cars to the 'competition' list and calculated the power/weight ratio of various combinations of weight reduction. For fun, I also calculated the power/weight of adding FI, keeping cost in mind. Note: everything is crank hp. Power to weight ratios of the 'competition' (note: added the TRD Griffon - interesting!) ![]() What I found was interesting: • Significant power/weight improvements from targeted weight reduction are possible without spending ridiculous amounts of money. • Beyond a certain point major weight reduction gets expensive and the cost/benefit goes south fast. Still, if cost is no object and/or you do go extreme then weight savings CAN be a killer mod - just check out the TRD Griffon stats. ![]() • For a typical street driven FRS/BRZ/GT86 it seems that going FI influences the power/weight ratio more per dollar than extreme weight reduction. Power alone, however, doesn't tell the full story because a lighter car will almost always handle better. ![]() • For a typical street driven FRS/BRZ/GT86 it seems that if cost was no object then you could go pretty far in terms of improving this platform from a power and weight perspective...but even so there will be a certain limit/tipping point somewhere along the line in terms of cost/benefit versus just buying a faster car (I'll let you decide where the tipping point is). Note: I did try to source accurate info from various sources. I'm pretty sure that my math is technically correct but I'm no stats genius and I'm well aware that I'm missing out certain key factors, including additional installation/tuning costs etc. So please relax and take these with a grain of salt. If folks want to play around a bit then the raw excel sheet can be downloaded here: https://dl.dropboxusercontent.com/u/...20savings.xlsx
2009 Renault Clio Sport R27 Team F1 Edition (sold) 1991 Mazda MX5 Miata (sold) 2007 Mitsubishi Evo 9 RS (sold) 2006 VW Golf R32 (sold) Last edited by ultra; 10-07-2015 at 04:13 PM. |
| The Following 5 Users Say Thank You to ultra For This Useful Post: | FT_86_SM_GP (10-30-2015), hamzam (10-09-2015), juliog (10-07-2015), makesdrivingfunagain (10-07-2015), Slysdexia (11-06-2015) |
#271 |
Weight Nazi
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Look at my build thread, post number two. I don't think the reservoir is 4 gallons.
| The Following User Says Thank You to Anthony For This Useful Post: | ultra (10-07-2015) |
#272 | |
Curious cat.
Edit: your stats (simple ballpark calc) are looking pretty impressive, @Anthony Anthony's FRS/BRZ HP 210 LBS 2430.923 Ratio 11.6
| The Following User Says Thank You to ultra For This Useful Post: | Anthony (10-07-2015) |
#273 | |
Weight Nazi
Just looking at that, I'd guess just a bit over a gallon? Where'd you get 210hp from? I've never dynoed my car, but I always assume it's probably at around 170whp.
| The Following User Says Thank You to Anthony For This Useful Post: | supra2nv (11-06-2015) |
#274 | |
Only happy when it rains.
Drives: series.blue
| The Following User Says Thank You to why? For This Useful Post: | supra2nv (11-06-2015) |
#275 | |
Curious cat.
If we go with one gallon of fluid in the washer reservoir that seems to work out to 8.14 lbs of fluid or so.
#276 |
Weight Nazi
Yeah, I figured that was crank hp. I guess I was mostly curious about how in-depth you went on the calculation.
Next time I come across it, I'll measure the volume. I just saw it a few weeks ago too. Dang it.
| The Following User Says Thank You to Anthony For This Useful Post: | ultra (10-08-2015) |
#277 |
Drives: 2015 FR-S
3 pound battery....damn! Need to have
#278 |
Drives: 2013 Frs
heres one nobody seems to have thought of. what about ditching those cast iron hub carriers for aluminum ones. it would have to be custom since noone seems to make them but i was thinking of hopping on solid works tonight and sarting to design a set. aluminum should be more than strong enough for that job. my cobalt has aluminum hub carriers in the front and they have never been an issue despite years of racing and some very harsh potholes.
my thinking is that switching those big hunks of cast iron to aluminum would save a substantial amount of weight. if somone could weigh a set of hub cariers front and back would be great. i could calculate the weight saving from going to aluminum based on that |
| The Following 2 Users Say Thank You to rustyfender For This Useful Post: | strat61caster (11-12-2015), SuperTom (12-28-2019) |
#279 | |
Drives: GT86-ACE-JRZ-RPF1-Essex
That's some expensive parts anyway. Like 2k for all four corners. edit : the Lotus version : https://www.eliseparts.com/products/...-s2-rear-pair/
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
#280 | |
The NSX control arms still blow my mind looking at them: ![]() ![]() Keeping my fingers crossed for Titanium 3D printing to come together and be available to a 'pro-sumer' in 5-10 years, potentially a big win on the uprights in terms of weight savings, however at that point you may be able to buy a used 86 for the amount of money someone would charge for a pre-engineered solution.
| Tags |
| diet, heavy, light, reduction, weight |
| So what is the official weight? | brillo | Scion FR-S / Toyota 86 GT86 General Forum | 76 | 05-03-2020 06:11 PM |
| Official Weight Reduction Thread - Sort of... | merlin2111 | Off-Topic Lounge [WARNING: NO POLITICS] | 77 | 10-07-2012 06:09 PM |
| 2012 Geneva - Toyota GT86 in Black, Blue, White, Orange. Official weight & 0-60 Shown | Hachiroku | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 124 | 05-28-2012 01:20 PM |
| Official JDM BRZ weight and MPG | ayau | BRZ First-Gen (2012+) -- General Topics | 50 | 02-08-2012 03:04 AM |
| Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 11:59 PM |
