#925 | |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
I believe this means they are still waiting for certification if you wanted the CARB kit. |
| The Following User Says Thank You to BigFatFlip For This Useful Post: | clayrush (02-21-2016) |
#926 | |
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
I'm having Performance in frame Tuning in Napa do the install. It will be my third car getting a supercharger installed by them. |
| The Following 2 Users Say Thank You to clayrush For This Useful Post: | BigFatFlip (02-21-2016), CSG Mike (02-22-2016) |
#927 |
e85!
Drives: 2013 Scion FR-S M/T
Sweet! I'm curious for numbers and the curve with e85 as that's the setup I currently run. Hopefully the install and tune go smoothly. Keep us updated if you can please
Scion FR-S M/T | HRI Tuned - AMS Catted Header - DW 700cc injectors - DW 265lph Fuel Pump - MotoEast Flex Fuel Kit - Greddy Evolution GT Catback Exhaust - Exedy Stage 2 Clutch - Edelbrock Supercharger
#928 | |
Drives: '13 BRZ | '04 E55
I don't have numbers from when I was on pump gas though, just NA, for comparison.
#929 | |
Drives: GT86 Cosworth
Given that we've seen 50C-60C IATs in 23C ambient on track, it would be safe to assume they will be higher if you run more boost..... that basically means the different between cruising and hammering it on the track will be higher and you'll lose a bit more power as it heats up to equilibrium temperatures. |
| The Following User Says Thank You to ajc209 For This Useful Post: | Toyota86.ir (02-23-2016) |
#930 | |
Drives: 2015 Scion FR-S 6M Ultramarine
Not California smog legal. Once Edelbrock receives a CARB Exemption Order #, the kit will be considered smog legal. Until an actual EO # exists though, this setup will not pass California smog checks. Edelbrock has stated that the kit is in review and they have not had any issues in the past, so this kit SHOULD pass as well. Take that with as much salt as you please. |
#931 |
Drives: 2013 Subaru BRZ
#932 |
Drives: 2013 Firestorm FRS
eh, it'll pass. Carb likes money. Edelbrock pays money to Carb.
Carb will approve kit. |
| The Following User Says Thank You to continuecrushing For This Useful Post: | CSG Mike (05-10-2016) |
#933 |
Drives: 2013 FRS
#934 |
#935 |
From what I have heard, if carb wants the manufacture to adjust something in the tune. The manufacturer has to go back, make a change then wait for a new appointment.
#936 |
Drives: 2016 BRZ
Just think Zootopia, and the DMV department, hahahahaha, that's how long will take for the CARB approval.
| The Following 6 Users Say Thank You to GT86Asia For This Useful Post: | Bach415 (05-12-2016), BrahmaBull1990 (07-31-2021), clayrush (05-11-2016), continuecrushing (05-11-2016), ravisraval (05-11-2016), trd87t (05-11-2016) |
#937 |
Drives: Silver Scion FRS
PowerNation's Engine Power FR-S
Pro engine builders and hosts of the automotive how-to show Engine Power, Pat Topolinski and Mike Galley, give viewers the secrets on assembling and tuning everything from mild performance street machines to full race monsters. They have a Scion FR-S in the shop they're working on for next season and have an Edelbrock supercharger kit to put in it! Here are some teaser photos from behind the scenes.
| The Following User Says Thank You to PowerNation For This Useful Post: | BrahmaBull1990 (07-31-2021) |
#938 | |
Lost in the twisties
Drives: 2014 BRZ Dark Gray Metallic
Maybe have to go custom?
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft Aztec's Build Thread ![]() |
| Tags |
| boost, byebye jackson racing, e-force, edelbrock, forced induction, supercharger |
| Trunk needs a bit of force to close..... | Hachiroku14 | Issues | Warranty | Recalls / TSB | 30 | 06-19-2018 07:09 PM |
| X-Force 3" Exhaust | mwjcyber | Engine, Exhaust, Transmission | 19 | 03-13-2017 03:55 PM |
| The force is strong with this one (2015 STi) | blackhawkdown | FR-S / BRZ vs.... | 39 | 08-01-2014 02:26 AM |
| X force or Invidia N1 | JakeG | AUSTRALIA | 8 | 01-18-2014 06:16 AM |
| G-force meter | mikepaul21 | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 03-17-2013 03:24 PM |
