86WORX
go_a_way1
Old 01-14-2016, 06:26 PM   #883
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Originally Posted by Paulo86 View Post
I will order mine by the end of january and i will take a tune from delicious tuning because i live in france and we have 98ron octane gas here... i will dyno it after the install, i've dyno it before, results are in my computer. I will put here the 2 results on the same graf, so you will see how much more horsepower and torque i get from this supercharger with the delicious tuning tune on ron98.
I'm mostly interested in driveability and the racerom features more so than dyno figures (don't really care, I'm already happy with the "feel" of the car), but your impressions are appreciated either way
Originally Posted by shiumai View Post
I'm doubtful that any strut bar will fit. when you install the e-force, you even have to remove the hood liner to provide clearance. so, unless the strut bar also requires the hood liner to be removed, it's probably not going to clear the supercharger.
^Agreed. Just about any strut bar that goes across the engine bay and over the intake manifold wouldn't work. The only one that remotely might work is the STI strut bar, since it "goes around" the manifold, but even that may not clear.
Old 01-14-2016, 07:01 PM   #884
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
The Sprintex kit also requires the hood liner removal. Too bad you don't live close to me otherwise we could slap it on. If anyone in my area has the Edlebrock and wants to try them I'm happy to assist.
stockysnail is offline   Reply With Quote
Old 01-14-2016, 07:13 PM   #885
Paulo86
Paulo86's Avatar
Drives: Toyota GT86 euro version
I drive an at, i think ecutek won't have any racerom features for me ^^
I already have flat foot shifting and auto blip stock ^^ but for launch control as we no it's dead for me ..
Paulo86 is offline   Reply With Quote
Old 01-14-2016, 08:12 PM   #886
sam69
Drives: GT 86
The hood lining doesn't need to be removed for the Sprintex kit you only need to cut a hole in it where the pulley is.
sam69 is offline   Reply With Quote
Old 01-17-2016, 06:09 PM   #887
tracerit
Drives: '13 SSM BRZ Limited 6MT
Are there any preparations one should check to before getting boosted? I had a leak (timing chain cover area) due to weak factory sealant that has been fixed. In the back of my mind, I feel like my engine has been "compromised" a bit and just isn't the same. Would an engine oil analysis provide any reassurances?
I'll be taking a look under the car hopefully next weekend to make sure there aren't any leaks, I have no reason to believe there to be any however.
The cam plate seems to be a weak area of the engine as well, would replacing this with say the Raceseng cam plate as preventative maintenance be of any worth?
tracerit is offline   Reply With Quote
Old 01-17-2016, 07:09 PM   #888
BigFatFlip
BigFatFlip's Avatar
Probably the best prep is to have your mechanic do a thorough look over your car/engine. I wouldn't worry too much about the cover leak if its fixed. An oil analysis really just tells you is how much more life is left in the oil and maybe any traces of metals, which could mean anywhere from normal engine break-in to your oil failing.
From what I've read about the cam plates, due to the way they seal it, it either leaks or it doesn't. I have the stock cam plate and have had no problems with it. I'd skip on the cam plate if I were you.
Of course, its your car, do your research and make your own educated decisions. I'm no expert, I'm just some guy on the internet
The Following 2 Users Say Thank You to BigFatFlip For This Useful Post:
ajc209 (01-18-2016), tracerit (01-17-2016)
Old 02-07-2016, 12:37 AM   #889
Originally Posted by JellyForSale View Post
Hey everybody.
Ok so long story short I installed my brand new Supercharger on my 2013 Manual FRS.
We triple checked everything we did, were super careful,etc. So I don't believe anything is done incorrectly. BUT, we are unsure of which Tune to use. I tried every "US BRZ MANUAL" Tune there was, but no luck. The car will turn over, fire and then stall out, almost like it does have the right tune.
If @Edelbrock LLC or anyone else could respond with how you learned which tune to use, that would be appreciated.
Did your vendor provide you with the tune for your car? If not, please email the following to sales at counterspacegarage.com
Ecutek Dongle ID
Ecutek Registration code
Copy of your invoice for the purchase of the kit
We will supply you with the tune.
Edelbrock LLC (02-08-2016), phm14 (02-08-2016)
Old 02-08-2016, 05:37 PM   #890
@JellyForSale just checking in...
Old 02-09-2016, 10:48 PM   #891
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
When I first got the kit installed in December, I noticed the throttle wasn't as responsive accelerating from a stop in the first couple thousand RPMs as before I got the kit. Figured the ECU needs to relearn throttle mapping and fix itself (also did the dead pedal fix procedure which I've done years ago when I installed an intake and noticed the procedure made a difference). But last night I drove a friend's stock FR-S and it is clear that his car was more smooth and responsive from take off. My car still has noticeably less response during the lull than his car followed by a surge of power/torque. This is with the smog tune. Are others seeing this?
@NotSoJDM, @BigFatFlip, @shiumai
Old 02-09-2016, 10:53 PM   #892
djdnz
1337
Drives: 2013 BRZ WRB S/C
Originally Posted by switchlanez View Post
When I first got the kit installed in December, I noticed the throttle wasn't as responsive accelerating from a stop in the first couple thousand RPMs as before I got the kit. Figured the ECU needs to relearn throttle mapping and fix itself (also did the dead pedal fix procedure which I've done years ago when I installed an intake and noticed the procedure made a difference). But last night I drove a friend's stock FR-S and it is clear that his car was more smooth and responsive from take off. My car still has a noticeably less response during a lull followed by a surge of power/torque. Are others seeing this?
Yup, I've had trouble with smooth take offs ever since installing the s/c. Not sure if it's something wrong with my install, tune related, or s/c related though. If I take it extra slow, I find modulation is easier. When I do a normal/quick take off, I usually end up bogging slightly and then a surge of power. I'm sure it looks like a newbie driving stick from outside the car.
djdnz is offline   Reply With Quote
Old 02-10-2016, 12:58 AM   #893
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
I have an auto, so no stalling or lull. I just didn't notice much increase in throttle response below 2k rpm after the SC install; but then i didn't expect to. it just feels pretty much like it did before. definitely no worse. maybe i should do the dead pedal thing and see what happens?
i'm wondering whether i don't notice it because i seldom launch it from a standing start - i just meander off the line then floor it. it really does come alive after about 3k rpm.
shiumai is offline   Reply With Quote
Old 02-10-2016, 01:00 AM   #894
86fun
Drives: 2013 FRS
I have this exact behavior as well, but I recently found my manifold gasket was damaged during install, so I'm in the process of replacing them and will have results soon to see if that's what the problem was. If so, you guys might have a clue that something similar happened to yours. If not, well then, we keep searching, or maybe just that's the way it is with this kit.
86fun is offline   Reply With Quote
Old 02-10-2016, 01:01 AM   #895
switchlanez
I'm not launching it either. Applying 1/4 to 1/3 throttle like for everyday civilized driving I notice a momentary lull compared to none in my friend's stock FR-S below ~2.5k RPMs.
Old 02-10-2016, 01:44 AM   #896
switchlanez
Also, the lull has become very subtle and I didn't think anything of it these past few months. That's because it improved with the ECU adjusting over time til I accepted it as back to normal. I could never tell whether the response fully adjusted all the way back to normal til I drove my friend's FR-S last night. It should have adjusted by now but there is still a difference.
boost, byebye jackson racing, e-force, edelbrock, forced induction, supercharger
Trunk needs a bit of force to close..... Hachiroku14 Issues | Warranty | Recalls / TSB 30 06-19-2018 07:09 PM
X-Force 3" Exhaust mwjcyber Engine, Exhaust, Transmission 19 03-13-2017 03:55 PM
The force is strong with this one (2015 STi) blackhawkdown FR-S / BRZ vs.... 39 08-01-2014 02:26 AM
X force or Invidia N1 JakeG AUSTRALIA 8 01-18-2014 06:16 AM
G-force meter mikepaul21 Cosmetic Modification (Interior/Exterior/Lighting) 2 03-17-2013 03:24 PM
