#477 |
Drives: Honda Element
Edelbrock provides a completely custom tune thats provided with the ECUtek tuner. If a customer wants to do their own tune, you will NOT be able to modify the tune from Edelbrock. You would have to start with stock tune or one from scratch. (I been talking to someone at Edelbrock)
| The Following User Says Thank You to ConElite For This Useful Post: | JoeC (08-23-2015) |
#478 | |
Drives: Subaru BRZ Limited
Thanks for responding, ConElite |
#479 |
Drives: 2014 BRZ Limited
That is correct, a custom tune is specific to your car, using info and logs from your car
| The Following User Says Thank You to sactownbwoy For This Useful Post: | JoeC (08-23-2015) |
#480 |
#481 |
Drives: FR-S black. Buell XB12s 25th anniv.
so what types of internal mods need to be done to go beyond 320 whp safely? how expensive are these mods in ballpark range? is there some good literature to read about this type of thing?
He who shall be last shall be sideways and smiling
#482 |
looks like a bad fitment here, no?
(fyi: i'm not trolling, I'm really hoping this kit lives up to the expectations). |
#483 | |
Drives: FRS, Supra, Colorado D, GLC63
Here is a good read, although suited more towards track cars, it will still give you a good idea for whats required. http://elementtuning.com/2015/01/08/...20-or-fa20dit/ "The Achilles heal to our beloved OEM FA20 motors have been the OEM connecting rods. While these rods are perfectly suited for OEM hp levels, when the power increases above 300 and RPM exceeds 7500 they are no longer reliable. We experienced OEM rod failure under racing conditions in the 350 ft/lbs of torque range". -Element Tuning- |
| The Following 3 Users Say Thank You to The Racers Line For This Useful Post: |
#484 |
in orbe terrum non visi
Drives: violent
There is alot of misinformation here. With e85 the fa20 is reliable past 350whp. I've been at 450+whp for 23,000 miles on a stock engine.
Valves springs are on the weak side for anything past 16 psi and the rocker arms seem to eject themselves from the engine past 8200 pretty consistently. If you have a supercharger or a larger turbo (i.e. gtx30) you'll be more likely to be using more rpms. My longevity is probably partially related to the fact that I make peak wtq of almost 400 under 4400 rpm and peak hp before 7200. I really like the gtx2867r. I rarely shift past 7300 unless i need to avoid a shift on a long straight . The factory rods have been doing fine in a few engines past 600whp and over 400wtq. The weak link is the factory pistons. They are not boxed and have very short skirts. Every engine I've seen window a block or bend a rod was because the piston came apart first. Not the other way around. The piston broke first. Usually from too much rpm. The pistons break at the wrist pin. The oiling system becomes a problem when you combine high heat, more than 400whp and you start taking away oil volume when it gets stuck in the wrong places during long high G corners. A good 40w and a good oil cooler will be fine for anyone under 420whp on streetbtires. Slicks and 400hp start causing oiling issues. But you'll also start breaking transmissions every track day too. Transmissions on the other hand......
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
| The Following 5 Users Say Thank You to Reaper For This Useful Post: | ATL BRZ (08-24-2015), CxG (01-21-2016), Jaden (08-25-2015), Ultramaroon (08-24-2015), xxscaxx (08-25-2015) |
#485 | ||
Will it be 100% as good as a custom tune for getting every last bit? No. Will it get the majority? Absolutely. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | JoeC (08-24-2015) |
#486 |
"With tuner" means with an Ecutek license/cable/dongle so that you can tune your own car (with the Edelbrock supplied tune, or with a tuner of your choice)
#487 | |
Reducing air pressure is okay, but overpressurizing usually is bad. |
#488 |
#489 | |
I do agree that the valve springs are sketchy (even NA), but raising boost pressure is not the only way to increase power output, and is not always the easiest or best solution. Understandably, your situation is a bit different since you're turbocharged. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | CxG (01-21-2016) |
#490 | |
Drives: violent
| The Following 4 Users Say Thank You to Reaper For This Useful Post: |
| Tags |
| boost, byebye jackson racing, e-force, edelbrock, forced induction, supercharger |
| Trunk needs a bit of force to close..... | Hachiroku14 | Issues | Warranty | Recalls / TSB | 30 | 06-19-2018 07:09 PM |
| X-Force 3" Exhaust | mwjcyber | Engine, Exhaust, Transmission | 19 | 03-13-2017 03:55 PM |
| The force is strong with this one (2015 STi) | blackhawkdown | FR-S / BRZ vs.... | 39 | 08-01-2014 02:26 AM |
| X force or Invidia N1 | JakeG | AUSTRALIA | 8 | 01-18-2014 06:16 AM |
| G-force meter | mikepaul21 | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 03-17-2013 03:24 PM |
